03-13-2016, 07:14 PM | #121 | |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Re: CFM drops a Bomb: Bomber Fab build and upgrades Quote:
Sent from my SM-N910V using Tapatalk | |
03-13-2016, 09:19 PM | #122 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Yes. It doesn't change any of the material being used. You're basically just drilling the front hole to be a through hole which is just enough to clear the diameter of the screw. More than enough material still there for both shocks.
03-13-2016, 09:52 PM | #123 | |
03-13-2016, 09:54 PM | #124 |
Set screw from factory are 3mm as well. Just have to thread into both halves of the shock mount and doesn't allow any clamping force to the upper ball to eliminate slop.
03-13-2016, 10:01 PM | #125 | |
Sent from my SM-N910V using Tapatalk Last edited by DowntownScience; 03-13-2016 at 10:11 PM. | |
03-30-2016, 09:43 AM | #126 |
Quarry Creeper Join Date: Apr 2015 Location: Georgia
Any idea if you'll ever produce the vanquish wheel cans again?
04-05-2016, 05:54 AM | #127 |
| Re: CFM drops a Bomb: Bomber Fab build and upgrades |
04-07-2016, 10:39 AM | #128 |
Well that didn't go as planned, they came back at a cost that was more than I was charging for the entire kits at retail with all the hardware included. So that said, and since people are still asking for them and there is a need, I'm going to make them on my manual machines at the same cost as before but only plan to do the 1" kits for now and see how things go. Material order is going in tomorrow morning and will start these next week. I will add them back to my website with a preorder option. First come first serve. I will cut it off if demand exceeds a reasonable turn around until it gets caught up and then open it back up. |
04-07-2016, 11:05 AM | #129 |
They're live http://carterfabmachine.com/?product=1-true-can-kit |
04-07-2016, 12:13 PM | #130 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Ordered. Thanks Clay!
10-12-2016, 02:31 PM | #131 |
I love the hex links. Sweet Bomber!
01-24-2018, 09:31 PM | #132 |
Quarry Creeper Join Date: Aug 2017 Location: Surface of the Sun
NICE Bombers!! Yours and your Kid's! :thumbup: :thumbup: Great examples of what CAN be done. I'm a Disabled Veteran....... so I really can't see me doing something of that magnitude - but I'm building a Wraith, and I want it to be unique among millions, and at least strong enough, not to break every time I take her Bouncing over southern Arizona Rocks!!! I MIGHT be able to do about 20% of what you've done here..... And from what I'm seeing, a good part of the Body is probably coming from YOU! I'm going to look at your website now. |
01-24-2018, 09:42 PM | #133 |
...... I already know what my first two pieces will be! Your Wraith Ultimate Front Inner Fenders, probably ASAP, so I can work it into the build with the Wertymade Battery Plate. Then, the Half Roof.... Then see what I'm able to do after that. ;) |
CFM drops a Bomb: Bomber Fab build and upgrades - Similar Threads | ||||
Bomber Fabrication Aluminum Panel Upgrades from CFM | CarterFab | Vendors Paint and Body | 28 | 09-26-2018 12:03 PM |
Bomber Fab KOH Buggy V2 | PANDAbox | 1.9 Scale Rigs | 62 | 02-18-2015 01:38 PM |
Bomber Fab KOH Buggy | Wrecker | 1.9 Scale Rigs | 92 | 08-10-2011 12:18 AM |
