Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Levior* - Becher's Bomber Build
Old 01-20-2017, 05:08 PM   #81
Default Re: Levior* - Becher's Bomber Build
THE GOOD:
I took the 1.9's out for their first real trial today and so far I'm pleasantly surprised. The increased clearance of the AR44 differentials almost completely makes up for the smaller tires compared to 2.2's on AR60 axles. The narrower stance makes the rig a bit more tipsy but it's also able to squeeze through smaller gaps. I can't go barreling through the river rock sections like before but I was able to clear all the major obstacles with only minor changes in the lines. The Pitbull Growlers hook up great, dare I say almost as good as my well-worn KLRs (almost). There is one obstacle that is a tire trap though and it swallows up the 1.9's easily. It's going to require a bit of practice. My home-grown CMS trusses didn't falter and overall the setup performed well.
THE BAD:
There were only a couple problems with the rig itself. First, the drag link pulled out of the rod end early on, which I knew was likely. The drag and panhard links are just prototypes that I cut too short. Second, the tires came off the wheels 5 or 6 times. This was also no surprise since I haven't even glued them up. On another sad note, I miss the OD/UD diff gearing available on the AR60 axles. Climbing ability and turn radius are noticeably affected. I recall reading a while back that Axial was going to offer an underdrive version of the AR44 gears but I'm unable to find anything current. Hopefully it's still on the radar because IMO it's one of the best mods there is to improve overall crawling ability.
WHAT'S NEXT:
I'll shorten the wheelbase by 1/2" to 3/4" starting with 3/8" on the front which will afford some clearance to move the CMS servo back a bit. The motor needs a larger pinion since the lower gearing in the diffs and smaller tires reduce the wheelspeed too much. I finished printing my wheels last night so I'll get those installed and widen up the rear axle along with a new drag link.
Name:  1.9 Conversion First Run 01.jpg
Name:  1.9 Conversion First Run 02.jpg
Name:  1.9 Conversion First Run 03.jpg
Name:  1.9 Conversion First Run 04.jpg
mikebecher is offline   Reply With Quote
Old 01-28-2017, 06:53 PM   #82
Conversion to 1.9 is complete except for tuning. I modded the stock SCX 10.2 wheels for SLW hubs to be compliant with the updated SORCCA rules. The end result is lighter and looks better than the wheels I was building. New Proline Hyrax tires round out the new wheels nicely. The wheelbase is about 13.4", track width is 10" and the weight has come down to just 1912 g or 4.2 lb. The stock Bomber looks and feels like a monster compared to this one now.
Name:  1.9 Complete 01.jpg
Name:  1.9 Complete 02.jpg
Name:  1.9 Complete 03.jpg
Name:  1.9 Complete 04.jpg
Name:  1.9 Complete 05.jpg
Name:  1.9 Complete 06.jpg
Name:  1.9 Complete 07.jpg
Name:  1.9 Complete 08.jpg
Name:  1.9 Complete 09.jpg
Name:  1.9 Complete 10.jpg
Name:  1.9 Complete 11.jpg
Old 01-30-2017, 03:53 PM   #83
Lunch time play time.
Name:  Play Time 01.jpg
Name:  Play Time 02.jpg
Name:  Play Time 03.jpg
Name:  Play Time 04.jpg
Old 02-02-2017, 07:45 AM   #84
Moderator
JatoTheRipper's Avatar
This is such a nice looking Bomber. It looks light, agile and fun too.
Old 02-02-2017, 12:40 PM   #85
Thanks Jato. I haven't made any aesthetic upgrades to this rig, it's all very stock thus far. I am planning to put some SSD Assassins on it however. It could use some weight down low and I don't like the AR44 Beeftubes. After that maybe I'll even skin it and paint the interior dudes.
Old 02-03-2017, 09:26 AM   #86
Awesome looking build. This was exactly what I intended to do also.
Tom_Swanson is offline   Reply With Quote
Old 02-04-2017, 08:43 PM   #87
Got my new SSD Assassins today. After putting loctite on all 136 screws they're ready to rock.
Name:  SSD Wheels 01.jpg
Name:  SSD Wheels 02.jpg
Name:  SSD Wheels 03.jpg
Old 02-05-2017, 06:31 AM   #88
Why don't you like the beef tubes?
Drm31078 is offline   Reply With Quote
Old 02-05-2017, 10:26 AM   #89
Just the new design for AR44s..."Due to the machining required on the axle housing to allow the fitment of the Beef Tubes, we will only offer these pre-installed in a new axle housing."
I wear through housings every few months and I don't mind spending $10 or $15 for new ones but $55 a pop is a deal breaker for me.
Old 02-11-2017, 07:17 PM   #90
I discovered this monster downstream of the spot I usually crawl. If you look closely on the right side there's some makeshift concrete steps. Weaving in and out of those I was able to find a line to the top. You can spot my rig in the last two photos.
Name:  Lower Waiakea 01.jpg
Name:  Lower Waiakea 02.jpg
Name:  Lower Waiakea 03.jpg
Old 02-11-2017, 08:01 PM   #91
Default Re: Levior - Becher's not-a-Bomber Build
Cool spot for sure.
Brake Weight is online now   Reply With Quote
Old 02-15-2017, 11:34 AM   #92
Just a couple photos from yesterday, 2.5 hours and 13,835 vertical feet apart...
Name:  Summit Elevation.png
(my usual elevation app didn't work at the summit since there's no data connection so I had to use this GPS-based app)
Name:  Beach Elevation.png
Old 02-15-2017, 12:01 PM   #93
There's snow in Hawaii??
calcagno45 is offline   Reply With Quote
Old 02-15-2017, 01:17 PM   #94
Mauna Kea gets a fair amount of snow almost every winter.
Google Images
Old 02-16-2017, 08:50 AM   #95
Attachment 355508
Attachment 355510
Attachment 355509
Attachment 355511
I'm like, "where is this dude with snow in one pic and palm trees in another?"
Oh, Hawaii
Very interesting concept to your builds. Very nice. Looks like you have a lot of different terrain options to choose from...super jealous
*Old* is offline   Reply With Quote
Old 02-19-2017, 09:14 AM   #96
Old Lava River...On the way back down from the summit of Mauna Kea last week I saw what looked like a good spot for crawling. It turned out to be a lava river that suddenly cooled. This doesn't happen often, at least at this magnitude, and it's the first one I've seen. The banks have some really interesting features and good challenges while the floor of the river was fairly smooth and even for walking. This would be an ideal spot for an event.
Name:  Lava River 01.jpg
Name:  Lava River 02.jpg
Name:  Lava River 03.jpg
Name:  Lava River 04.jpg
Mauna Kea in the background
Name:  Lava River 05.jpg
Name:  Lava River 06.jpg
Name:  Lava River 07.jpg
Name:  Lava River 08.jpg
Name:  Lava River 09.jpg
Mauna Loa in the background
Name:  Lava River 10.jpg
Old 02-19-2017, 09:37 AM   #97
Looks like a great spot.
Isn't that lava rock high traction?
Old 02-19-2017, 09:43 AM   #98
I've always liked the look of the PB Growlers. I hear negative things about their performance. I hear great things about Hyrax performance. Have you noticed any hit to crawling ability since switching? I assume almost anything will stick to that lava rock though.
The design of the AR44 Beef Tubes is what is keeping from making the switch. I wonder how hard it actually is to move them to a new housing when the included one wears out?
I really like this rig, the pics, and most importantly the information you packed into this post. This has been a great resource for my 1.9 Bomber build and even my 1.9 Wraith build. Thanks.
Deckard is offline   Reply With Quote
Old 02-19-2017, 10:04 AM   #99
Yeah, it's like driving on sandpaper. It's fun but it also eats tires, rod ends and axle housings. I had to replace my AR60 housings every few months. I won't know about the AR44s until this first set wears through.
I run both on this rig, Growlers and Hyrax. For this type of terrain the Growlers are better. The Hyrax outperform if there is any sort of loose material - sand, dirt, mud. The Hyrax do almost as good on this stuff but they will also get torn up faster. The 2.2 KLRs I used to run attest to that fact.
I'm in the same boat with the AR44 Beeftubes - not going to get them if they can't be moved to new housings. Maybe if someone who has some reads this they could chime in. Or I guess I could, gasp, search.
It's good to hear that this thread has been helpful. I've done some outside-the-box stuff on this rig and it seems to be paying off. Even my home-grown CMS is still going strong.
Old 02-19-2017, 11:12 AM   #100
Can you mold a piece of kydex or something similar to protect the diff housings better?
Levior* - Becher's Bomber Build - Similar Threads
Jayn Bomber Build Jayn Axial RR10 Bomber 31 03-07-2017 07:02 PM
Ca. Off Roader's Bomber Build up... Ca. Off Roader Axial RR10 Bomber 10 03-27-2016 08:46 PM
Bomber Build - DBW dbw Axial RR10 Bomber 11 02-27-2016 08:34 AM
Forestbumpr's RR10 Bomber Build forestbumpr Axial RR10 Bomber 29 12-28-2015 09:12 PM
My Bomber build bredmx Axial RR10 Bomber 8 12-28-2015 11:51 AM
