Thread: Axle gear noise
Old 10-20-2012, 05:40 PM   #1
Default Axle gear noise
Does anybody else have, or experienced noise coming from the gear set in the axle? I just built my SCX10 kit, and in the rear axle there seems to be a rough spot or something on the ring gear because it clicks and then it's fine for the rest of the revolution. Both pinion bearings are seated as far as they can go, and the mesh is good, and it has lots of grease for it.
canadianbacon is offline   Reply With Quote
Old 10-20-2012, 09:24 PM   #2
Default Re: Axle gear noise
I had the same exact problem after I built my dingo. I tore the axle back down, pulled everything put (including bearings) looking for something wrong - rebuilt it and it was (and still is) fine after that. Best guess is that something was just slightly mis-aligned somehow? /shrug
But, it worked for me - so maybe just pull it all apart and rebuild it - maybe the gremlin falls out when you do that...
B94Cast is offline   Reply With Quote
Old 10-20-2012, 09:35 PM   #3
Check to see that all of the screws that holds the ring gear to the carrier are seated properly, I had a simmilar noise with some WK diffs and one screw wasn't seated and was rubbing one the housing.
greenjk is offline   Reply With Quote
Old 10-20-2012, 09:38 PM   #4
I'll take a look at it tomorrow. What I'm thinking is I might not have snugged down all the bolts holding the diff case to the ring gear, since it only makes the noise on a certain point in the revolution.
Old 10-20-2012, 09:40 PM   #5
Just noticed your post after posting mine, that's what I'm thinking too.
Axle gear noise - Similar Threads
Gear noise Hardline Axial AX-10 Scorpion 2 08-18-2012 06:58 PM
7955 gear noise... a little different mudn_1 Electronics 1 02-10-2012 10:20 PM
Wraith Gear noise cumminsdzl Axial Wraith 7 08-12-2011 09:15 PM
Gear noise elitecrawler HPI Wheely King 8 06-29-2010 11:26 AM
gear noise? 93'wrangler Axial AX-10 Scorpion 7 12-08-2008 11:36 AM
