Thread: Scx10 shock leaking who's got the right fix?
Old 02-02-2013, 07:12 PM   #1
Default Scx10 shock leaking who's got the right fix?
I have some scx10 alum body shock I built with green slime and it worked for a little bit but again leaking then I heard pack bottom with gear science but I heard theres an o ring you and use in the bottom that stops it anyone know or have the part# I love these shocks on my comp but need to keep the oil in
Thanks j
J-Money is offline   Reply With Quote
Old 02-02-2013, 08:00 PM   #2
Default Re: Scx10 shock leaking who's got the right fix?
The part number for the bottom o-rings is axa1179. There are 2 o-rings in the bottom separated by a spacer.
Make sure to use the green slime on the o-rings when installing them and to be slow and gentle while pushing the shaft thru the o-rings.
k7zpj is offline   Reply With Quote
Old 02-02-2013, 10:47 PM   #3
I saw someone mention there was a Traxxas o-ring that was a tighter fit and cured leaking. I cant remember which o-rings they were though. My fronts are leaking like a sumbish.
05Fronty4x is offline   Reply With Quote
Old 02-03-2013, 11:33 AM   #4
I tried a traxxas blue x-ring but couldn't get it to fit in place of the stock orange o-ring. I ended up leaving the x-ring on the shock shaft and screwing the cap back on with all stock o-rings in place still. It won't screw on fully, but it has stopped all leaking till i get new shocks.
JBryant is offline   Reply With Quote
Old 02-05-2013, 01:10 PM   #5
Any other tips goin on with this?
winnerone23 is offline   Reply With Quote
Old 02-05-2013, 01:31 PM   #6
I used the correct axial o-rings and instead of useing the spacer I used one of the old o-rings in each shock as the bottom seal and havn't had a problem with them leaking yet. I did it about a month ago and taken it out for a few good runs.
craddock35 is offline   Reply With Quote
Old 02-05-2013, 05:01 PM   #7
Natedog's Avatar
I build all my shocks that way, but the Axials won't stop leaking no matter what. I even went so far as to slide the o-rings onto the shaft and then into the shock body and then install the lower screw on seal retainer...they still leak. I just refill them every so often, but it's a pita and messy. I removed the travel limiters which I think makes them more prone to leak because they are such small displacement that there is nowhere for the oil to go when the shaft and piston compress into the shock body, therefore oil eventually just leaks out little by little. All four of mine have wetness covered with dirt around the lower spring cup etc, I clean em off with an old toothbrush to keep the dirt from damaging the o-rings.
Hmmm...good idea I'll have to try that.
Old 02-05-2013, 05:20 PM   #8
the solution is to go with proline shocks
theloudone is offline   Reply With Quote
Old 02-05-2013, 05:22 PM   #9
Are everyone's leaking from the top or bottom? If from the top, bleed some oil or quit flipping your rig on it's head so dang much, lol.
Old 02-05-2013, 05:32 PM   #10
You could always stop putting oil in them.
Really for the 5mph mine goes I'm not going to bother with the oil in the shocks.
65BAJA is offline   Reply With Quote
Old 02-05-2013, 05:42 PM   #11
I think It's a little diff when a lot of us are using them for our comp rigs.. its even slower but its more for performance an tuning, not in a scaler..
As for proline shocks.. that's personal opinion. Like most things..
I rebuilt two of them with 3 o-rings an building the other two with green slime.. I'm goin to see which lasts longer. I'll report back once the first one leaks.
Old 02-08-2013, 12:50 AM   #12
Both pairs of shocks rebuilt an on rig.. now to get to run them when the snow melts..
Any other leak stopping ideas out there?
Old 02-08-2013, 12:57 AM   #13
The green slime is to use when you slide the seals on I use it on my seals also. I put it on all 3 seals before I put them on. The deal I see with the 3 seals makes the seals squash together and seems to make them a little tighter fit.
Old 02-08-2013, 07:18 AM   #14
MY wraith shocks leaked,tried green slime,extra orings,ended up going to lowes store an bought some plumbers pipe dope, the brush on kind,slow setting, no more leaks oh and did go with associated silicone 30wt oil.
crawlernut is offline   Reply With Quote
Old 04-10-2013, 05:12 AM   #15
Looking for anything new someone is trying..
I'm running 3 o-rings an slime on them. Works good, I just run a slightly lighter shock oil to compensate for the nice snug fit of the rings..
Old 04-10-2013, 05:45 AM   #16
What about shock socks? See No Evil, Hear No Evil.
o0wiz0o is offline   Reply With Quote
Old 04-15-2013, 10:37 AM   #17
I have this same problem with my SCX10 Rubicon kit. Oil leaked out before I even drove it.
J_Fitz is offline   Reply With Quote
Old 04-15-2013, 10:39 AM   #18
Scale Detail Engineering
they work better empty!
johnnyh66 is offline   Reply With Quote
Old 04-15-2013, 10:58 AM   #19
Maybe for a scaler.. Don't try it on a comp rig tho.. Anywho....
Get some green slime an O-rings.. Then they just seep oil... after use..
Old 04-24-2013, 03:13 AM   #20
I run this set up works good for me
StEv0 is offline   Reply With Quote
Scx10 shock leaking who's got the right fix? - Similar Threads
shock fix bubbaskyjacker Newbie General 5 11-18-2010 01:28 AM
Leaking shock caps - Al Replacements? bigstu Axial XR10 16 10-12-2010 05:50 PM
ax10 leaking shock caps racenut Axial AX-10 Scorpion 8 07-08-2010 09:03 AM
TLT shock fix eron Scale Accessories 0 12-31-2009 09:09 PM
RTC leaking shock Chuki Axial AX-10 Scorpion 11 06-20-2009 12:33 AM
