12-14-2013, 09:10 PM | #21 |
Pebble Pounder Join Date: Dec 2013 Location: brockville
| Re: Stock SCX10 Performance Tech.
Thanks for taking the time to do this, I'll def be reading as you go along
12-15-2013, 04:05 AM | #22 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Stock SCX10 Performance Tech. Quote:
This may not be for everyone but hopefully it will help someone along the way who may not have the expendable money but still wants a great performing SCX10. And even if you did this is still another alternative route. Last edited by 6sharky9; 12-15-2013 at 04:33 AM. | |
12-15-2013, 02:10 PM | #23 |
Newbie Join Date: Dec 2013 Location: NW AR
Great thread for me as a new rc user!!! Thank You for posting this!
12-15-2013, 02:20 PM | #24 |
| Re: Stock SCX10 Performance Tech. |
12-15-2013, 07:01 PM | #25 |
Newbie Join Date: Oct 2013 Location: Sunny Coast - Australia
good stuff mate, thanks for the write up. I have only had my Wrangler for a month or so now and am enjoying making bits for it as well as using parts that are being discarded by others to see what I can come up with. It is an expensive hobby so every little bit helps |
12-18-2013, 08:08 AM | #26 |
It does help quite a bit...Seems a lot think its only about bolting on the latest hi tech parts and its not..Alot has evolved with the scx10 that many have already been through, but not many start with the basics...These basics make your truck better when you decide to chose to put some of those other parts on it down the road..I wish more understood that. Thanks for the compliment..we need more like you on here who get it. |
12-19-2013, 10:54 AM | #27 |
Rock Stacker Join Date: Jan 2012 Location: Winston-Salem
Good thread, I'll definitely be using it once I get my SCX10. Thanks
12-19-2013, 06:45 PM | #28 | |
RCC Addict Join Date: May 2008 Location: Southern,WV
12-20-2013, 09:49 AM | #29 |
Rock Stacker Join Date: Oct 2013 Location: Nampa
Good stuff. I disagree with the need to hack up the rear cross brace to gain up travel but otherwise, some very good tech.
12-20-2013, 10:11 AM | #30 |
Quarry Creeper Join Date: Sep 2012 Location: Emmaus, Pa
I heard where you WV guys can place a double wide w/ a stock honcho , 3racing winch, and your female cousin/mistress! Lol jk guys |
12-20-2013, 03:18 PM | #31 |
| Re: Stock SCX10 Performance Tech. Yep! And work smart enough to where I was able to retire at the age of 31.But any way if you really want to talk about where people are from you need to look up Them boys from up PA. I seen one he had a sheep under each arm. I asked him what he was doing.All he said was pimpin'........LOL
12-20-2013, 06:08 PM | #32 |
Lol..Im actually from bama..but raised in south florida since the age of 2...Moved back to bama when i was 36 now here in WV. But yep..nothing beats learning the old school way and doing things yourself. |
12-20-2013, 06:09 PM | #33 | |
12-20-2013, 06:14 PM | #34 |
12-20-2013, 06:18 PM | #35 |
Put it in there...ill definitely check it out...or Pm it to me if you want.
12-20-2013, 06:32 PM | #36 | |
Only thing i can think of maybe is a rear truss that mounts a lot lower in the center and if it had extended bracing like the stock one it would have to be a lot lower as well. or none at all. But i found the stock truss to hit in 2 places ..The top and the extended bracing...So that was what i come up with to solve that issue without buying parts. | |
12-20-2013, 06:38 PM | #37 | |
But if you want to im cool with it..It should fit in my next thread i do however...ill give you the credit if i use it. you know i have to do the mod and see for myself though before i would recommend it..lol...Im stubborn like that..lol | |
12-20-2013, 07:43 PM | #38 | |
I think if you drive it normal though youll be fine..lol | |
12-21-2013, 09:07 AM | #39 |
Newbie Join Date: Dec 2013 Location: southwest
Def two thumbs up,. Great info for a newb, and yes im definitely a newb. Thanks
12-21-2013, 02:53 PM | #40 |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
It's been said before, but thanks for this thread dude. Great info all in one place. Question: with regards to weight and COG. In the standard setup, you have your battery on the plate above the front axle mounted on the 3 stand off posts. Now different people have different ideas with regards to switching to saddle packs on the rock sliders, and removing the battery plate over the front axle. Then others say to add wheel weights to the stock setup. My question is which is the better option? I have a Dingo that's pretty much stock, except for brushless system, and about 200 grams per front tire. Thanks for your help... |
Stock SCX10 Performance Tech. - Similar Threads | ||||
Vanquish Currie axle vs stock performance | uclabruins89 | Axial SCX-10 | 3 | 07-05-2013 01:18 AM |
Does angling the shocks on scx10 help with performance | raiders32 | Axial SCX-10 | 4 | 11-17-2011 08:46 PM |
Stock RTR Honcho Performance*Questions. | Bryan732 | Axial SCX-10 | 7 | 07-04-2010 06:21 PM |
Stock Bully ARTR Kit Performance Question | Paul97 | RC4WD Bully | 11 | 01-28-2010 02:08 PM |
stock cr-01 tire performance | Defender | Tires and Wheels | 1 | 06-18-2008 09:08 AM |
