01-02-2014, 07:39 AM | #61 |
| Re: Stock SCX10 Performance Tech.
I've been pointing some noobs on other forums to your basic SCX write-up, and it's been very well received. Yes, it's been covered here in the past, but not in a single thread (and the search function doesn't work right) and it's VERY refreshing to see a basic write up that's not just bolting on $$ parts and calling it a build. Lots of new guys just want to learn and tinker, and this is a great way for them to do so. Then later, if they want to start banging away on upgrades, they can. Well done. |
01-02-2014, 08:00 AM | #62 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Stock SCX10 Performance Tech. Quote:
01-02-2014, 11:50 AM | #63 | |
Quarry Creeper Join Date: Jan 2013 Location: Benicia/Vallejo
01-02-2014, 06:26 PM | #64 | |
I made my links form 8-32 steel all thread with 1/4 aluminum tubing as sleeves and traxxas revo ends. Im wishing I had used a more thick tubing though as they bend/dent pretty easily...some don't have tools to make them though so some will have to buy links..Used Axial links are pretty affordable if you can find the right lengths...I would suppose the heavier your rig is the easier it would be to bend links as you slam down on a rock something so stronger links could be warranted...steel/titanium depending on budget Last edited by 6sharky9; 01-02-2014 at 06:32 PM. | |
01-02-2014, 07:08 PM | #65 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: Stock SCX10 Performance Tech. I think he means the ones like top cad, and integy that are one piece and have a pressed in insert with the ball ends in it.
01-02-2014, 08:18 PM | #66 |
Pebble Pounder Join Date: Dec 2013 Location: Marion
Thanks. Gonna order 16t 48 p traxxas pinion gear.
01-04-2014, 01:11 AM | #67 |
Pebble Pounder Join Date: Nov 2013 Location: Corsicana
I went to a 15t Robinson 48P pinion and it has a lot of torque but not enough wheel speed for me. So I moved back up to a 17t Robinson 48P haven't got to try it out yet though!
01-04-2014, 01:17 AM | #68 | |
Not a bad thing to have a few gears with you out on the play ground..if you just want to crawl you can gear down..if you want to mud or climb hills then re gear again...I like the 16T..seems to do everything well enough on my set up as a compromise Last edited by 6sharky9; 01-04-2014 at 01:21 AM. | |
01-04-2014, 01:40 AM | #69 | |
Yeah we were in some really deep ruts we made at the creek I crawl at and just wasn't enough wheel speed in the mud with my 35t. I was wondering too I know everyone's been on your A$$ about running 2s I run a 2s pack too but have you tried 3s yet? I'm sure you're tired of talking about it though! That stuff it nasty! | |
01-04-2014, 01:48 AM | #70 | |
you will gain more though than just wheel speed..you will get from ive read a lot better low end control as well as more run times in general with with a 3s. basicly someone with a 3000mah 3s may get well over an hour run time..where I just barely broke 1 hour using a 4000mah 2s I used...So its got benefits to running 3s..just not without needing to invest more to be safe from breaking driveline parts. Unfortunately for some they cant afford that so I recommend a 2s..Not saying you cant break using a 2s but chances are less likely and to be honest with you I personally have not experienced a 2s not being sufficient enough to do what I see rigs on 3s do...I may not win sled pull contest or a tug a war but I don't care. Last edited by 6sharky9; 01-04-2014 at 02:00 AM. | |
01-04-2014, 02:13 AM | #71 |
Not saying your 35T is a bad decision but maybe try a quality 27T and see what I mean by wheel speed...Also, let me know if you do ;if there was anything you couldn't do with a 27T and a 2s you could do with the 35T on a 3s if you try one.. 35T is better suited to a 3s if you want wheel speed and the added low end control..cant have both with a 35T on a 2s A quality 27T on a 2s with proper gearing is pretty similar I would think...speed and control...works for me anyway. I have a lot more wheel speed than you have with a 27T on a 2s If you want similar wheel speed you need a 3s with your 35T Its not expensive for a 3s at all..can buy a brand new one for less than 20 dollars...get one and see...you may love it..just be prepared to make upgrades should it cause you to break things you were less likely to break on 2s power. Im not against a 3s i just don't think its for everyone. Last edited by 6sharky9; 01-04-2014 at 02:32 AM. |
01-04-2014, 03:44 AM | #72 |
Quarry Creeper Join Date: Jan 2011 Location: Perth, Western Australia, 6108
A year ago I was still running 7.2v NmH in both of my comp rigs. I competed for 3 years wiith them, I had to upgrade to stay competitive. Now I'm running a HH 35T on 3s in my 2.2 AX10, and a HH 27T on 2s in my 1.9 SCX10. The AX10 is much faster and more powerful. The AX10 has MIP drive shafts and metal transmission gears, I shredded the stock idler gear a few comps after the change from 7.2vNmH. The 2s was too much for the stock Axial drive shafts in the SCX10(the old type, I've had it for a few years). Blew out 4 front universals in the last 2 comps. But that might have been because of the change from the stock tin can to the Holmes Hobbies 27T handwound. So I ordered MIPs for that today. I think I'll be running 3s before the end of the year. I'll have to see how I do in the first few comps of the year. I just need to buy another set of Jazrider gears now. Last edited by HyperMark; 01-04-2014 at 03:47 AM. |
01-04-2014, 05:44 AM | #73 | |
Once they did and people started using them I noticed I could no longer keep up in the straights but still denied wanting to use one...Well once I started doing research on them and learned more about them I found the discharge rate was far superior and didn't fall off near as fast as a Nimh battery did..Meaning I had more voltage for a much longer period of time giving a much higher average of power throughout the race..Well its been history and ive used a lipo ever since..Its always a good thing to research something before just jumping into it..Some burned up ESC,s and had lipo fires because they didn't know about you cant run a lipo down in voltage like you can a NiMh...so many had bad experiences for not doing the homework first. My research ive done on 3s vs 2s has stopped me from wanting to use a 3s only because ive learned it can be more costly to do so..Not saying I cant upgrade and use one..i just haven't felt ive needed to to do what I do with my truck...Plenty aware of the benefits but also the down sides for someone with a stock scx10 drivetrain,..You can always set the slipper to slip but then you cant take advantage of the power so it makes no sense to me to add more power I cant use. My slipper is tightened up all the way and still have no breaking issues...Im not sure I would be that lucky with more power without upgrades Last edited by 6sharky9; 01-04-2014 at 05:53 AM. | |
01-06-2014, 01:34 AM | #74 |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
I'm running a Hobbywing Juststock 21.5 brushless with a 20 tooth pinion and 87 tooth spur on a 2s 5000 mah LIPO. She runs great, but I want to try a 17 tooth pinion for finer slow control.
01-06-2014, 05:00 AM | #75 |
Pebble Pounder Join Date: Jan 2014 Location: Adelaide
Great guide! I'm about to order a Dingo kit as my first crawler/scaler and your tips and tricks are an excellent source of information. |
01-06-2014, 05:08 AM | #76 |
| Re: Stock SCX10 Performance Tech. It makes a big difference..If you feel you have plenty of wheel speed already then its not a bad trade off to gear for better low end control...Its not that you make more torque per say but youre basicly shifting the torque curve in favor of lower rpm duty.
01-06-2014, 05:40 AM | #77 |
| Re: Stock SCX10 Performance Tech. Thank you...Most of it has come from reading this site and learning this style of rc fun and my experience in rc in general....If I can help you with anything just ask..will do the best I can.
01-06-2014, 01:52 PM | #78 | |
Rock Crawler Join Date: Mar 2009 Location: Alvin,Texas
01-06-2014, 02:00 PM | #79 |
the stainless steel allthread works the best... no bendy.
01-06-2014, 06:33 PM | #80 |
this should be a sticky
Stock SCX10 Performance Tech. - Similar Threads | ||||
Vanquish Currie axle vs stock performance | uclabruins89 | Axial SCX-10 | 3 | 07-05-2013 01:18 AM |
Does angling the shocks on scx10 help with performance | raiders32 | Axial SCX-10 | 4 | 11-17-2011 08:46 PM |
Stock RTR Honcho Performance*Questions. | Bryan732 | Axial SCX-10 | 7 | 07-04-2010 06:21 PM |
Stock Bully ARTR Kit Performance Question | Paul97 | RC4WD Bully | 11 | 01-28-2010 02:08 PM |
stock cr-01 tire performance | Defender | Tires and Wheels | 1 | 06-18-2008 09:08 AM |
