12-28-2013, 10:25 PM | #61 |
Newbie Join Date: Oct 2013 Location: Tupelo
| Re: Axial SCX10 build - My first kit.
I like it. Looks a lot like mine, ha http://www.rccrawler.com/forum/axial...t-build**.html You are suppose to cut a small round hole through the back window and the piece sticking out from the cage attaches to your spare tire mount with a body clip. Or else your spare tire is going to be bouncing around and it will probably break the mount. I used a body reamer. |
12-28-2013, 11:15 PM | #62 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Looks good |
12-29-2013, 08:45 AM | #63 | |
Pebble Pounder Join Date: Jul 2011 Location: Downingtown, PA
| Re: Axial SCX10 build - My first kit. Quote:
Thanks! I just got out and ran it around the backyard in the rain, and it goes over everything! I'm surprised...its like a monster truck that actually looks good! It was crawling over leaves, dead roots, rocks, divots, etc. Looks like its gonna be a fun truck. Oh one question about something I noticed when driving it. When I give it full throttle, it goes only about as fast as someone who is speed walking. Is this is normal with a 27T motor? Of course, I am not looking for insane speed at all from this truck because its not meant for it, I'm just curious since I'm used to speedy rc cars. Last edited by electricrc68; 12-29-2013 at 08:47 AM. | |
12-29-2013, 10:04 AM | #64 |
Something bizarre just happened with my car. I took it out in the rain again since there was now a big collection of water, so I decided to ford through it slowly, and it got through fine. Well as I was turning back around, I noticed that smoke started coming out the side of the car. Everything is waterproofed, but I still got worried, turned it off, and brought it in. Upon inspection, nothing looks burnt...I don't notice anything on the ESC, Motor, or servo. The weird part is, everything still works perfectly fine! I'm a little confused. Anyone ever have this happen before? It still smells like burnt electronics, but works fine...
12-29-2013, 01:15 PM | #65 | |
Its not going to be a speed demon like race cars or fast bashers..Going with the 16T slowed it down a bit over what a 20T would've been. Only way to get more speed with the 2s is gearing up but you really want the trade off of control over speed..Im gearing down even more to take away speed...trail trucks aren't supposed to be crazy fast. 2 options are a 3s battery which will add a bit of speed or go to a sensored brushless system..Mixing those 2 will give you amazing speed but not so great on the stock drive line When you crawl you barely walk at all till you the truck gets ahead a little ways..Dont worry about the overall speed..Control is more important and you should have good wheel speed to get you up some hills like it is...Way more than you would've had with a 35T on a 2s battery..And if you ran a 3s battery it would be what you have now speed wise with a 35T but faster with the 27T and a 3s..but again possible driveline reliability issue. Last edited by 6sharky9; 12-29-2013 at 01:28 PM. | |
12-29-2013, 01:20 PM | #66 | |
Im not waterproof at all and run through some water just above the axles and haven't had any smoking issues at all...Is the burnt smell coming off the motor or off the esc? | |
12-29-2013, 02:18 PM | #67 | |
Hmm thats odd. I think its coming more from the motor than the ESC. I'm going to go out and avoid as much water as possible and see what happens this time....I hope everything works okay. Maybe it had something to do with the fact that I didn't properly "break in" the motor? | |
12-29-2013, 02:34 PM | #68 | |
Check that your motor connections aren't touching the frame somehow where it gets soldered onto the terminals on the back of the motor..You can sometimes have it positioned where a terminal might hit someplace on the frame..theres 2 sets of holes to mount the motor with..you want the holes that bring the motor terminals farthest away from the frame. | |
12-29-2013, 02:57 PM | #69 | |
12-29-2013, 04:45 PM | #70 |
Newbie Join Date: Nov 2013 Location: st. louis
just have fun and remember if you crash it it isn't like crashing that ember 2
12-29-2013, 04:48 PM | #71 | |
I checked the motor, and it doesn't seem to be touching any metal anywhere...there also doesn't seem to be any frayed wires touching any metal. The one thing I did notice is that the ESC falls off. Whats the best way to get that mounted? Double sided tape isn't cutting it... | |
12-29-2013, 05:29 PM | #72 | |
12-29-2013, 05:31 PM | #73 | |
might can try velcro | |
12-29-2013, 07:26 PM | #74 | |
Lol I wish they made some....or do they? Velcro sounds like a good idea. I can give that a shot...sounds like it should work. | |
12-29-2013, 07:29 PM | #75 |
search "waterproof double sided tape" and see what comes up..lol Velcro is probably cheaper..can get that at the dollar store more than likely...Iuse it to hold my batteries in..working good so far. |
12-30-2013, 11:16 AM | #76 | |
I'll probably use velcro as you said. Seems like a better solution. Time to tidy up some wires. | |
12-30-2013, 02:16 PM | #77 |
Rock Stacker Join Date: Sep 2013 Location: Vancouver
I have my esc mounted to an aluminum plate mounted to a slider using this stuff, works great so far. Parma PSE Pro Servo Tape 1"x36" Roll [PAR8044] | Radios & Accessories - A Main Hobbies |
12-30-2013, 02:34 PM | #78 | |
12-30-2013, 03:04 PM | #79 |
| Re: Axial SCX10 build - My first kit. |
12-30-2013, 03:33 PM | #80 |
Axial SCX10 build - My first kit. - Similar Threads | ||||
NorCal's Axial SCX10 2012 Jeep Wrangler Unlimited Rubicon Kit Build | NorCal 2500HD | Axial SCX-10 | 29 | 06-20-2014 09:59 AM |
Badger's Axial SCX10 Jeep Wrangler G6 kit build | badger | Axial SCX-10 | 122 | 05-01-2014 01:51 PM |
Axial SCX10 Dingo Kit Newb build. | syko_less | Axial SCX-10 | 8 | 04-28-2014 03:15 PM |
Detailed build of Axial Honcho SCX10 Kit - aimed at the person new to RC | rc-Bitz | Axial SCX-10 | 0 | 05-20-2011 04:42 PM |
my axial scx10 honcho kit build | 4goodbuys2 | Axial SCX-10 | 3 | 04-04-2010 12:36 PM |
