12-30-2013, 04:58 PM | #81 |
Rock Stacker Join Date: Sep 2013 Location: Vancouver
| Re: Axial SCX10 build - My first kit.
Ya I used the tape on the esc. The zip tie is just to hold the extra esc wire and the capacitor in place.
12-30-2013, 06:57 PM | #82 |
Pebble Pounder Join Date: Jul 2011 Location: Downingtown, PA
| Re: Axial SCX10 build - My first kit. |
12-31-2013, 12:17 AM | #83 |
The screws go thru the plate into and thru the slider mounts and I put a nut on the bottom of the screw. Then taped the esc to the plate.
12-31-2013, 08:45 AM | #84 |
12-31-2013, 04:47 PM | #85 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
I would look into more options before mounting the esc on the skid...I know its waterproof but its also prone to getting wet or submerged a lot easier than having it mounted above the chassis..A simple styrene plate will give you a solid smooth surface to mount the esc on across the top of the frame rail in front or back...Where it mounts stock you cant use a very tall piece of tape as you wont be able to remove the receiver box top if you did so..I do use a much larger piece as I don't plan to open the top of the box very often..I don't run through water either however where it gets it wet up high so im not having an issue with regular 3m tape. I would leave the sliders available for better space such as the lowest center of gravity you can have by mounting batteries there instead...Just a thought. |
12-31-2013, 04:54 PM | #86 | |
| Re: Axial SCX10 build - My first kit. Quote:
12-31-2013, 05:09 PM | #87 |
01-03-2014, 12:49 PM | #88 |
I think the motors dead on my SCX10...when I move the throttle stick, there is no response. At first it was intermittent. The light on the ESC still goes on, so I know the ESC is fine. Also, the servo works fine. Well this just sucks...I guess I'll take the 20T dynamite motor out of my circuit (which is for sale, so I'd drop the price and let everyone know) for now then...:( I really want to run in this snow so.... |
01-03-2014, 02:34 PM | #89 |
And the problem was from the motor. It runs now! I think I'll be sending in the holmes hobbies motor for warranty...there was a black dust around the outside of the motor! This is not what I expected from an expensive motor....slightly disappointed.
01-03-2014, 02:53 PM | #90 |
Newbie Join Date: Oct 2013 Location: Tupelo
If your going to run brushed motors you really should knoiw how to take them apart and clean them. They are super easy to work on and if you run them in any water or snow they need to be taken apart and cleaned right after or the insides and bearings will just rust. Also the brushes will need to be replaced when they get worn down or you will ruin the comms. I use a cobra lathe and there is an awesome deal on one at rctech right now Cobra Pro Comm Lathe - R/C Tech Forums Also they have a great write up at holmes hobbies website about how to take care of the motors. 540 Brushed Motor Care, Installation, and Troubleshoot | The Search for Power Last edited by daltrey; 01-03-2014 at 03:02 PM. |
01-03-2014, 03:25 PM | #91 | |
I'm gonna go and file for some warranty... | |
01-03-2014, 04:24 PM | #92 | |
Yeah, I had to get a brxl warrantied and I had it back the next week. Anytime you change the gearing it's also a good idea to use a temp gun on the motor the first few minutes to be certain the temps don't go over 160. I use one of these TowerHobbies.com | Duratrax FlashPoint Infrared Temperature Gauge If I know I'm going to be running in water or mudd I just stick in a stock axial 27t. You can find them on ebay for about $10 and I just throw them in the sink and run water through it when I get done and blow it out with the air compressor. | |
01-04-2014, 07:28 AM | #93 | |
01-16-2014, 03:24 PM | #94 |
Not too thrilled with Holmes Hobbies support. No replies to my two emails.... Might be my first and last order with them unfortunately. |
Axial SCX10 build - My first kit. - Similar Threads | ||||
NorCal's Axial SCX10 2012 Jeep Wrangler Unlimited Rubicon Kit Build | NorCal 2500HD | Axial SCX-10 | 29 | 06-20-2014 09:59 AM |
Badger's Axial SCX10 Jeep Wrangler G6 kit build | badger | Axial SCX-10 | 122 | 05-01-2014 01:51 PM |
Axial SCX10 Dingo Kit Newb build. | syko_less | Axial SCX-10 | 8 | 04-28-2014 03:15 PM |
Detailed build of Axial Honcho SCX10 Kit - aimed at the person new to RC | rc-Bitz | Axial SCX-10 | 0 | 05-20-2011 04:42 PM |
my axial scx10 honcho kit build | 4goodbuys2 | Axial SCX-10 | 3 | 04-04-2010 12:36 PM |
