04-28-2014, 01:41 PM | #21 |
RCC Addict Join Date: Aug 2005 Location: Pocatello
OK thanks Ty. I've looked at your JK build and I'll have to take another look at it. I will be running a bumper mounted winch so shouldn't have a problem there. Sent from my XT1080 using Tapatalk |
04-29-2014, 03:48 PM | #22 |
I couldn't stand gluing up a set of wheels and tires, luckily these showed up in the mail today. Sent from my XT1080 using Tapatalk |
04-29-2014, 05:26 PM | #23 |
Got all electronics installed and wired up. Couldn't believe how small the FXR is. I have used mostly Novak products in the past but heard only good things about the Tekin FXR so decided to give it a try. Plus I'm supporting an Idaho based company. Good to support a local company. Also got my winch installed. Now I just need to pick up a winch controller. Sent from my XT1080 using Tapatalk |
04-30-2014, 02:07 PM | #24 |
Rock Crawler Join Date: Aug 2012 Location: Los Angeles, CA
| Re: Mongo's SCX10 Rubicon
Subscribed. I look forward to seeing the rest of your build.
04-30-2014, 02:20 PM | #25 |
04-30-2014, 02:21 PM | #26 |
04-30-2014, 02:38 PM | #27 |
| Re: Mongo's SCX10 Rubicon |
04-30-2014, 05:50 PM | #28 |
04-30-2014, 07:46 PM | #29 |
Newbie Join Date: Apr 2014 Location: Blah Vegas
I plan on running a Vanquish LED bar with my SCX10. How would you recommend I wire this up? My thought were to solder a female deans to the end of the light bar and then use a 'Y' deans harness to connect the battery and light bar to the ESC. Something like this below. http://www.sonicelectric.com/Merchan...onnector-C.jpg |
05-01-2014, 08:03 AM | #30 | |
Sent from my XT1080 using Tapatalk | |
05-01-2014, 10:49 AM | #31 | ||
| Re: Mongo's SCX10 Rubicon Quote:
05-01-2014, 11:15 AM | #32 |
OK so I'm currently installing the beadlocks on my tires, the stock Trepadors. So many screws!!!!!!!!! Anyway I've always vented my rims but I'm thinking I won't this time because I hate drying out foams after any water and I don't want to vent the tires themselves. Any pros and cons? Are my tires gonna be too bouncy? Guess I'll try it and see if I like it. I'm mainly going to be doing trails and rocks. No mud. Sent from my XT1080 using Tapatalk |
05-01-2014, 11:24 AM | #33 | |
05-01-2014, 12:01 PM | #34 | |
Rock Crawler Join Date: Aug 2013 Location: Central Coast
05-01-2014, 12:25 PM | #35 | |
05-01-2014, 12:36 PM | #36 |
| Re: Mongo's SCX10 Rubicon The Trepadors are good tires. I think you'll find out they'll do just fine not vented.
05-01-2014, 12:50 PM | #37 |
I've heard pros and cons on the Treps but for my purposes I think they'll work just fine. They are a great looking scale tire. Sent from my XT1080 using Tapatalk |
05-01-2014, 12:54 PM | #38 |
I've heard that the treps like a heavy truck because of the stiff sidewalls. Some with lighter rigs actually run them without foams, though I'd recommend against that. Whatever works though I just acquired a set from an rtr that I'm going to experiment with on my bronco. Let's see em' mounted up |
05-01-2014, 02:56 PM | #39 | ||
05-01-2014, 03:50 PM | #40 | |
Let's see those treps on the proline beadlocks! | |
Mongo's SCX10 Rubicon - Similar Threads | ||||
The difference between the scx10 rubicon and the scx10 honcho | RC_addict1 | Axial SCX-10 | 14 | 01-06-2015 08:52 AM |
Mongo's Twin Hammers | Mongo | Vaterra Twin Hammers | 17 | 04-15-2014 08:33 PM |
rubicon scx10 for c1 | scale jim | Axial SCX-10 | 1 | 02-11-2014 02:05 PM |
Mongo's Bronco | Mongo | 2.2 Scale Rigs | 170 | 01-30-2009 09:36 AM |
Mongo's Jeep TJ | Mongo | 2.2 Scale Rigs | 28 | 01-28-2009 04:24 PM |
