03-22-2017, 09:31 PM | #1361 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
| Re: New SSD SCX10 axle housings
Thanks for the quick response! Turns out I posted before I really just tried harder. The SSD splines are bigger but they DO in fact line up! Maybe its the anno on the VP stuff but the fitment is really snug. Just took a bit more force than I expected. |
03-22-2017, 10:14 PM | #1362 |
Ok so turns out I was half right. One side went on. Tight but right. Now the second is a different story. This sucker's not going on. Looking at my (now slightly mashed) c hub, it looks like the OD of the tube splines is bigger. Maybe i can spread the c hub enough to get it over the tube but I dont wanna destroy the thing. The other side is on so tight, I cant get it off to compare!
03-22-2017, 10:27 PM | #1363 |
Quarry Creeper Join Date: Aug 2014 Location: Orange County
Which chubs to you have. Is it the clamping ones? If it is then they may be become deformed and that may be why they don't fit right. Sent from my SM-G920T using Tapatalk |
03-23-2017, 03:09 PM | #1364 |
Yep, theyre the clamping ones. Ill take a pic when I get home tonight.
03-23-2017, 09:56 PM | #1365 |
I did use a round edged jewelers file to fix the splines and knock down the marring I caused last night. Anyone else ever run into this?
04-12-2017, 01:04 PM | #1366 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
I purchased a set from RPP with the alu diff covers and alu bearing caps, then put the vp stage 1 kit on them and couldn't be happier with them. I will be replacing all of my axial housings with these. I LOVE THESE HOUSINGS!!!! |
04-14-2017, 06:45 AM | #1367 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
| Re: New SSD SCX10 axle housings |
05-08-2017, 10:55 AM | #1368 |
Newbie Join Date: Feb 2017 Location: Huntington Beach
| Re: New SSD SCX10 axle housings SSD I was wondering if Im able to use the 3 link stock Axial set up front. I purchased the D60 Axels and ran into this problem. I do in fact also have the Axel mounted servo plate as well. But where does the end to the 3 point link go ? PLEASE HELP!!!
05-08-2017, 11:44 AM | #1369 |
Axles come with a 3 link truss Sent from my VS986 using Tapatalk |
05-08-2017, 06:37 PM | #1370 | |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
| Re: New SSD SCX10 axle housings Quote:
Sent from my SM-G930F using Tapatalk | |
05-09-2017, 03:55 AM | #1371 | |
RCC Addict Join Date: Oct 2014 Location: UK
As others have said, the D60s are not compatible with the old Y 3 link setup. So you have to convert to 4 link or CMS with panhard. | |
05-27-2017, 02:32 PM | #1372 | |
Pebble Pounder Join Date: Mar 2013 Location: Chesapeake
Sent from my SM-N920T using Tapatalk | |
06-02-2017, 04:18 PM | #1373 |
Pebble Pounder Join Date: Apr 2014 Location: South Jersey
I want three sets for me and the kids scx10's BUT did SSD fix the issue with the pinion bearings not fitting correctly?
06-02-2017, 04:25 PM | #1374 |
Yes.
06-02-2017, 05:07 PM | #1375 |
^ how do I know I'm getting the new proper housings or the older one's? You know how suppliers have old stock laying around
06-02-2017, 05:10 PM | #1376 |
06-05-2017, 04:32 PM | #1377 |
Ah ok, I get the bug ever couple months and I come back on here look around, buy some new parts for me and the kids. Then after a couple months we put them back on the shelf and then repeat LOLOLOL
06-21-2017, 07:40 AM | #1378 |
Quarry Creeper Join Date: Sep 2010 Location: appleton
Does anyone offer a panhard/3link axle mount for this in aluminum. I've broken 2 now. I am very rough on my truck so I am not surprised that I have broken it, just would like something stronger Sent from my SAMSUNG-SM-G935A using Tapatalk |
06-21-2017, 11:11 AM | #1379 | |
Rock Stacker Join Date: Jul 2016 Location: In the shadows
There is an option for alum on the scx10 axle housing, but not on your own D60 housing? Is that correct? Is this a part that you could add to your D60 option parts? | |
06-26-2017, 03:02 AM | #1380 |
The 3 link mount really has not been a common/easy part to break so there was no need to make an aluminum one. RPP have spare link mounts in stock: SSD RC D60 Axle Link Mount Set for SCX10 |
New SSD SCX10 axle housings - Similar Threads | ||||
VP Scx10 axle housings | Jeep_Crawler | Axial SCX-10 | 15 | 04-08-2016 06:35 AM |
