01-30-2018, 08:31 PM | #101 |
Rock Stacker Join Date: Jan 2018 Location: oregon coast
| Re: SSD Scale Transmission for SCX10
2600 kv, i think. p sure i read that kv is roughly the turn size x 200 (double the turns and add a couple zeros)
01-30-2018, 11:41 PM | #102 |
RCC Addict Join Date: Jun 2004 Location: ORegon
| Re: SSD Scale Transmission for SCX10 Nope. kv increases as turns decreases (all other factors held constant). Also there are other variables that affect kv that a universal turn-kv relation is not possible.
01-31-2018, 08:46 PM | #103 |
yeah idk, just read it somewhere. on these forums i think. they are definitely "roughly" comparable, depending on where you look anyway. the chart that comes to mind is from holmes' motor recommendation guide, though i couldn't tell you how i got it in my head that kv is roughly the turn size x 200 https://holmeshobbies.com/motor-recommendations |
02-02-2018, 01:19 PM | #104 | |
Rock Crawler Join Date: Dec 2014 Location: Union Bridge, MD
| Re: SSD Scale Transmission for SCX10 Quote:
https://youtu.be/E2TmoPT371c Sent from my XT1585 using Tapatalk | |
02-02-2018, 09:10 PM | #105 |
Rock Crawler Join Date: May 2013 Location: Uniontown
Sounds about right, there's a lot of steel gears in a metal case, gonna make some noise. Sent from my XT1585 using Tapatalk |
02-03-2018, 04:41 AM | #106 |
| Re: SSD Scale Transmission for SCX10 |
02-08-2018, 08:31 AM | #107 |
Has anybody stuffed one of these transmissions in a TF2?
02-08-2018, 08:34 AM | #108 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
02-08-2018, 10:04 AM | #109 |
02-08-2018, 10:14 AM | #110 | |
The T-case doesn’t have overdrive nor can you swap the case to change which side is the output. However, the SSD’s t-case is flatter, and the output shafts are inline, where the GCM has a drop. The drop is an advantage when the GCM trans in one of their chassis, but when putting the GCM into a scx10 or TF2 chassis, it raises the trans up a bit and the t-case has to sit on a little mount. While you do give up overdrive and are locked into left hand output, it’s easier to fit the SSD into A TF2. I have both transmissions here if ya need to se pics. | |
02-20-2018, 04:20 PM | #111 |
Can anyone at SSD tell me when these will be in stock again? They seem to be out of stock almost everywhere. Perhaps a new version is in the works? |
02-20-2018, 04:22 PM | #112 |
02-26-2018, 03:43 PM | #113 |
Quarry Creeper Join Date: Feb 2018 Location: Melbourne Australia
From what I have read this may be a silly question, but.... Will an 8th scale motor fit? say a 4268? trying to find a way to get one into an SCX10 |
03-02-2018, 11:59 AM | #114 |
Newbie Join Date: Jan 2007 Location: springfield
03-02-2018, 12:06 PM | #115 |
RCC Addict Join Date: Oct 2014 Location: UK
No there isn't a new model coming out. We just ran out this week as Amain took the last ones. More in a few weeks...
06-03-2018, 09:30 PM | #116 |
Pebble Pounder Join Date: Jan 2018 Location: US
Where do I buy gears for this transmission? The gears that mesh with pinion somehow chipped some teeth. Sent from my Z982 using Tapatalk |
06-09-2018, 11:37 PM | #117 |
This the new one? I kid. I made a new shaft and the new setup reduced the total length by about 1.25”. Needed it to be shorter for a build. Not sure if I lost or gain gearing but that can be tuned with the motor later. Still need to drill /tap two 2mm holes. |
12-13-2018, 11:29 PM | #118 |
Newbie Join Date: Sep 2011 Location: spanaway
What grease, or lube is recommended for the internal gears? I broke a drive pin on the bigger gear internally so while I have it apart fixing that I thought I would try to quiet this noisy pig down with some more lubrication, but would like to know what I should use. thanks in advance
12-14-2018, 04:51 AM | #119 | |
12-14-2018, 12:36 PM | #120 | |
Engine looks to be a great print. Did you make it or buy it? Did you make the jack stands? | |
SSD Scale Transmission for SCX10 - Similar Threads | ||||
New SSD 2 Speed Transmission kit for Wraith | SSD | Axial Wraith | 43 | 12-28-2016 04:06 PM |
The New SSD-RC High Ratio Wraith Transmission Kit | KRAWLR4life | Axial Wraith | 18 | 08-22-2016 05:14 AM |
Question: SSD SCX10 drive shaft and Vanquish transmission outputs | KellyC | Newbie General | 3 | 07-26-2016 10:58 AM |
