12-29-2016, 02:45 PM | #21 |
Quarry Creeper Join Date: Dec 2016 Location: FL
| Re: Gmade RSD Suspension?
Hmm. Whats the Piston Range, Like say SCX10-II kits Stock Piston Range is 61-90mm. From the sounds if it, these ought to help my 10.2 stop doing throttle squats when I am accelerating. HH 2700KV gives me a bit of torque squat in the right rear when giving it throttle. Might try to put 60 weight oil in the rear for a temporary fix until I can afford these ones if they perform well.
12-30-2016, 12:01 PM | #22 | |
Quarry Creeper Join Date: Dec 2011 Location: spokane
| Re: Gmade RSD Suspension? Quote:
12-30-2016, 12:58 PM | #23 |
Hmmm, not too bad on the travel. Not quite as much travel as the stock but I think these sound like they should do a little better, the piggyback ones I mean because I would be able to increase and decrease oil pressure depending on the situation which would be a nice change.
01-24-2017, 11:00 AM | #24 |
Newbie Join Date: Oct 2016 Location: Mesa
So what's the take on these guys? I've been eyeing the RDS shocks since a guy in our local club shared the YouTube pre-release video on the group page on FB.
01-24-2017, 04:56 PM | #25 |
Quarry Creeper Join Date: Dec 2016 Location: Womelsdorf
I think they will be the ticket. They are designed to hold oil and they look amazing. We can take it from there with oil weights and different spring combos.
01-24-2017, 07:35 PM | #26 |
| Re: Gmade RSD Suspension? |
01-24-2017, 10:42 PM | #27 |
I would guess scx10 Springs fit but not sure.
01-24-2017, 10:56 PM | #28 |
Well, all I know is the Shock Spring Diameter is 15mm, so depending on what that inner diameter is, looks like rc4wd king shock springs would work. Either way though I am no Shock Expert so unless someone has a pair and has some spare springs laying around to test all of the springs and or knows the actual dimensions of everything kind of hard to say one way or the other. Doesn't look like SCX10 would fit, their springs are 12.5mm. |
01-25-2017, 06:51 PM | #29 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Inner shock spring diameter is 13mm on the RSD 100mm piggyback shocks Later, Farmer |
01-28-2017, 04:18 AM | #30 |
01-28-2017, 07:13 AM | #31 |
Sure....... You know that there are several shocks being sold with several springs in production. So....... purchase the dang shocks and we will figure out several excellent options. That's the joy of our hobby IMO. Making it work......
01-28-2017, 07:30 AM | #32 | |
Later, Farmer | |
01-28-2017, 09:49 AM | #33 |
Prick answer? Just the truth. I like to make things work. That's what makes scale rc fun for me. I don't feel that everything should be pure bolt on (cookie cutter). back at ya....... |
01-28-2017, 10:52 AM | #34 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Too small diameter spring isnt going to fit over the shock body, too big isnt going to stay on due to the size of the collar. Axial has some 14mm diameter springs, but I'm guessing they will rub on the body. If the RC4WD King springs work, then that would be great since there is a variety of springs available from those. I really want a set of these. I saw in another thread a guy bought them from Junfac. I was going to do the same but wasnt able to find them for sale. | |
01-28-2017, 11:16 AM | #35 | |
To those who would like to share info. I've spent a month going to various hobby shops and have spent hours looking for something. No go, unless you want to do a hack job and take away from the scale appearance. The only option I see for me is ordering the softs straight from Junfac. Sucks paying the $14.50 again on shipping for $10.00 in springs Does anyone other than me actually have a set of these? Later, Farmer | |
01-28-2017, 12:15 PM | #36 | |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
They are 80mm, non piggy back, destined for my twin hammers. The spring rate on these is too high for an scx 10, but probably about right for the setup i have in the TH. Seem a little under damped, even with the 2 hole piston, but i'll try it on track first before upping the viscosity. My plan is to get a 100mm set for my scx10. I'll maybe buy soft springs from the outset. My rc4wd King 'scale' shock springs DO fit in terms of dia. You need an ID of 12-13mm. Trouble is, you're unlikely to get the twin springs to fit in terms of length. | |
01-28-2017, 12:19 PM | #37 |
Farmer, I meant no disrespect. I didn't say that anything you build was cookie cutter. I was simply saying that I feel that the shocks would be worth purchasing and going from there. I love the challenge of making things work. Again I am sorry and intended no disrespect. You have been around much longer than me.
01-28-2017, 12:19 PM | #38 |
I'm waiting for rpp to get some. I talked to them and apparently the US distributor didn't order any until they contacted them this week. |
01-28-2017, 12:49 PM | #39 |
Sounds like I am going to wait until yall get a hold of them and test out springs . Either way will most likely eventually pick up a set depending on springs and leaks etc. If they aren't leaky and I can get decent springs without having to do weird mods than I will definitely pick up a set lol. For now going to attempt to get the 10.2 kit shocks to stop leaking with some marine grease and hope it works well enough. On another note, are the top pivot balls metal like the lowers, or are they plastic? |
01-28-2017, 04:14 PM | #40 | |
Later, Farmer | |
Gmade RSD Suspension? - Similar Threads | ||||
New G-Made RSD Shock Absorbers | LSXGMC | General Scale Talk | 21 | 01-22-2017 02:08 AM |
Gmade R1 Stealth Cantilever Suspension | bikerzee24 | G-Made Crawlers | 33 | 04-04-2014 08:15 PM |
Titanium Steering and Suspension Links for Gmade R1 | Blue Monkey RC | Chassis and Suspension | 0 | 02-14-2013 01:41 PM |
rustler suspension arms versus bandit suspension arms... | STEEL_CITY_CRAWLER | Non Crawler RC's | 5 | 08-30-2010 11:05 AM |
rsd and wheel speed | nuts5000 | General Crawlers | 7 | 04-07-2008 06:43 PM |
