02-25-2017, 02:18 AM | #81 | |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: Gmade RSD Suspension? Quote:
02-25-2017, 07:47 AM | #82 |
Quarry Creeper Join Date: Dec 2010 Location: Hanford
| Re: Gmade RSD Suspension? The rock krawler springs are in the rear, but they're from the 90mm's I have. I ordered a spring kit for the 110's and a set of beef tips. The stock rock krawler springs aren't all that soft.
02-25-2017, 01:55 PM | #83 |
Newbie Join Date: Sep 2015 Location: England
I have the Gmade piggybacks with the soft white springs and I reckon It Is still too stiff.Not sure where to go next . Think I'll build up the stockers with X ring seal and AE top bladder.
02-25-2017, 02:11 PM | #84 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Gmade RSD Suspension? |
02-25-2017, 02:20 PM | #85 | |
I am now thinking the rc4wd 110mm rock krawler shock springs are the way forward here. Their 'spring assortment' kit might just do it. They should be soft enough, have the right diameter and are just 2mm shorter. | |
02-25-2017, 02:26 PM | #86 |
02-25-2017, 05:37 PM | #87 |
| Re: Gmade RSD Suspension? True. My thinking behind the rock krawler springs are they're sold in a kit for under $15, there's 4 different spring rates to play with, the kit is enough for 2 rc4wd dual shocks which means there's 4 springs in each rate, enough for all 4 rsd's should you want the same rate all around, they're readily available, and the rsd springs are sold in pairs for $5 so the rc4wd kit is only a couple bucks more.
02-26-2017, 07:16 AM | #88 |
Are the traxxas big bores diaphram or emulsion shocks? Do they come with different damper pistons?
02-26-2017, 01:14 PM | #89 |
02-26-2017, 05:22 PM | #90 |
03-01-2017, 04:24 PM | #91 |
Good news and bad news. The good news is that the rc4wd springs fit perfect on the shocks and the beef tips. The bad news is that the beef tips don't fit the 3.5mm shock shaft. Hopefully I can bore them out to fit though.
03-01-2017, 07:08 PM | #92 |
Easily fixed for the beef tips.
03-01-2017, 07:42 PM | #93 |
03-13-2017, 12:03 PM | #94 |
Rock Crawler Join Date: Oct 2013 Location: The Netherlands
Just ordered 3 sets for my 6x6, after i had bad luck with Yeah Racing Lizzard shocks. Ordered the soft green springs with them. My 6x6 is quit heavy so guess a bit sitff springs would be oke.
04-28-2017, 08:28 AM | #95 |
Newbie Join Date: Aug 2012 Location: Brasil
Hello, can anyone tell me the difference in performance of this RSD piggyback and the XD piggyback? I'm concerned about the stiff spring issue. It's worth buying or I shout look somewhere? My plan is to use in my SCX10 for trail and hill climb. Thanks in advance. |
04-28-2017, 08:42 AM | #96 |
RCC Addict Join Date: May 2009 Location: Weston
The shocks are nice you just need to get softer springs.
04-28-2017, 08:49 AM | #97 |
04-28-2017, 09:17 AM | #98 |
I run them in my SCX with 20wt oil and stock springs. I want a bouncy ride but the springs are still a little too stiff. I haven't tried any other springs yet but the XD it a much larger diameter shock. Not as scale looking at all.
04-28-2017, 10:35 AM | #99 |
For a trail truck the stock stiff springs weren't as bad as I thought, but the rock krawler springs made a world of difference with the 0.4 and 0.8 rates.
04-28-2017, 11:40 AM | #100 |
| Re: Gmade RSD Suspension? What "bouncy" means exactly? A kick back thing? Thatīs my actual problem with the chinese shocks that i have in my scx10. If i hit a obstacle, my actual shocks kicks my rc. My friends call my scx10 "goat".. LOL I think that iīm using a very thick oil, but my springs seems to be ok...
Gmade RSD Suspension? - Similar Threads | ||||
New G-Made RSD Shock Absorbers | LSXGMC | General Scale Talk | 21 | 01-22-2017 02:08 AM |
Gmade R1 Stealth Cantilever Suspension | bikerzee24 | G-Made Crawlers | 33 | 04-04-2014 08:15 PM |
Titanium Steering and Suspension Links for Gmade R1 | Blue Monkey RC | Chassis and Suspension | 0 | 02-14-2013 01:41 PM |
rustler suspension arms versus bandit suspension arms... | STEEL_CITY_CRAWLER | Non Crawler RC's | 5 | 08-30-2010 11:05 AM |
rsd and wheel speed | nuts5000 | General Crawlers | 7 | 04-07-2008 06:43 PM |
