04-28-2017, 12:59 PM | #101 |
RCC Addict Join Date: May 2009 Location: Weston
| Re: Gmade RSD Suspension?
If it's kicking back you either have too much preload, springs are too stiff or your oil isn't think enough. What weight are you running?
04-28-2017, 03:16 PM | #102 | |
Newbie Join Date: Aug 2012 Location: Brasil
| Re: Gmade RSD Suspension? Quote:
Are the regular spring of RSD kicking back yours? | |
04-28-2017, 03:46 PM | #103 | |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
I moved to traxxas big bore shocks on my scx10ii- these work with the stock springs and the damping is perfect for me using the supplied 3 hole pistons and 30wt oil. The scale looks are not as good, but the quality is a big step ahead. | |
05-23-2017, 05:13 PM | #104 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
Just read this whole 6 page thread to find out the real world reveiws on these and revitalizing its 7 month status. I got 2 packs of the 90mm piggybacks for my scx 10ii and a pack of 80mm non-piggyback for TH. I'm happy to know that the RC4wd King spring rate variations will work with these. I may get the Beeftips, but not sure if the collar's size will work with these. |
05-23-2017, 09:33 PM | #105 |
Quarry Creeper Join Date: Dec 2010 Location: Hanford
The beef tips will work, but need to be slightly drilled out for the shaft, and you'll need to use the axial rod ends.
05-24-2017, 05:56 AM | #106 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
My set of 90's work great with the soft spring and the 4 hole piston and 35wt oil. I have a set of 80's im selling on the book of faces with soft springs and already built. I bought 80's thinking i could get my truck lower but built it with the 90's and cant change it. Lol |
05-24-2017, 06:32 AM | #107 | ||
Also, I'm sure I'll be wanting a softer spring on these. Do you suggest the Rc4wd "Krawler" spring set thats for the 110mm? Any info on a softer spring would be greatly appriciated. I noticed members had said even Gmades soft springs are still stiff. Quote:
But if you already changed the rod ends to Axials it wouldn't work because I only got 1 pair of the 80mm for my TH's. Was thinking of using a lower mm of shock to acheive a lower stance on my 10ii also because I was running out of options... than I thought of another Idea. Last edited by MattySlimz1987; 05-24-2017 at 02:21 PM. | ||
05-24-2017, 06:42 AM | #108 |
I just listed them yesterday. And they are all stock. I havent changed the rod ends yet. I will for the rear of my 90's to add beef tips. But also beef tubes say they are making a brass rear lockout for the 10.2 Kinda waiting on those. |
05-24-2017, 06:46 AM | #109 |
They'll sell.. I wanted to get a Pre- Beeftubed housing but axial hasnt had parts available in so long.. so I decided to get rid of the rotating mass and replace the patties with a brass DLUX knuck/c-hub setup.. the brass rear lockouts from Beeftubes sound great too, when were those going to ready if you don't mind me asking? |
05-24-2017, 07:42 AM | #110 |
They just said they are working on them. So who knows. |
05-24-2017, 02:46 PM | #111 |
Rock Stacker Join Date: Mar 2009 Location: N/A
anyone who have these shocks know if the piston cartridge on the piggyback side slides on the aluminum body? or does it ride all the way up into the plastic body on the top?
05-25-2017, 12:38 AM | #112 |
[QUOTE=MattySlimz1987;5711080]Thanks for the tips on what needs to be done in advance. Also, I'm sure I'll be wanting a softer spring on these. Do you suggest the Rc4wd "Krawler" spring set thats for the 110mm? Any info on a softer spring would be greatly appriciated. I noticed members had said even Gmades soft springs are still stiff. The 110mm RK kit works great, I'm using the 0.4 and 0.8 rates. |
05-25-2017, 04:45 PM | #113 |
| Re: Gmade RSD Suspension? |
05-25-2017, 06:04 PM | #114 |
05-25-2017, 10:14 PM | #115 |
| Re: Gmade RSD Suspension? Plastic inside the threads that hold the aluminum body. The aluminum body has a spring which pushes the piston up or let's it slide down depending on your setting.
05-25-2017, 10:44 PM | #116 |
| Re: Gmade RSD Suspension? Actually, what I wanna know if the piston's o-rings moves up and down inside the plastic section or the aluminum section. I think just based on the video they have, it sits in the plastic section.
05-26-2017, 11:18 AM | #117 |
The piston has 2 grooves that the o-rings sit in, kind of like a 1:1 2 ring piston.
05-28-2017, 07:48 AM | #118 |
| Re: Gmade RSD Suspension? This might answer your question. The rings stay in all areas of the aluminum bodies. Shock and piggyback housings. |
05-28-2017, 08:03 AM | #119 |
^^^Step 6 shows the piggybacks piston and the pistons o-rings which seat inside the plastic cap. The o-ring seals stay in the aluminum housings.
05-28-2017, 01:20 PM | #120 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
What top mount bushings fit these?? Bought some used and need these
Gmade RSD Suspension? - Similar Threads | ||||
New G-Made RSD Shock Absorbers | LSXGMC | General Scale Talk | 21 | 01-22-2017 02:08 AM |
Gmade R1 Stealth Cantilever Suspension | bikerzee24 | G-Made Crawlers | 33 | 04-04-2014 08:15 PM |
Titanium Steering and Suspension Links for Gmade R1 | Blue Monkey RC | Chassis and Suspension | 0 | 02-14-2013 01:41 PM |
rustler suspension arms versus bandit suspension arms... | STEEL_CITY_CRAWLER | Non Crawler RC's | 5 | 08-30-2010 11:05 AM |
rsd and wheel speed | nuts5000 | General Crawlers | 7 | 04-07-2008 06:43 PM |
