02-22-2017, 04:42 PM | #61 |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: Gmade RSD Suspension?
I swung by RPP yesterday and snagged a couple pair of the 90mm piggybacks. Will build tonight and report back. |
02-23-2017, 05:42 AM | #62 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
My non reservoir 90mm's came in last night. What weight oil comes with them? I have some 30wt from the kits I have built, that prolly wont be enough will it? |
02-23-2017, 06:13 AM | #63 |
RCC Addict Join Date: May 2009 Location: Weston
I have some 90mm piggy backs on my SCX cherokee. It's not a II but I like them. They seem to hold oil well and are very smooth. I'm only running 20wt with 3 hole pistons as its not fast at all and I want it to absorb as much as possible to look more "scale" when running. So far so good.
02-23-2017, 07:21 AM | #64 |
Quarry Creeper Join Date: Dec 2010 Location: Hanford
Mine were scheduled for tomorrow, but are here at the post office so should get them today. Hopefully they're waiting for me when I get off work. I might try 55wt til the spring kits are in stock.
02-23-2017, 08:11 AM | #65 |
Junfac's site has the springs in stock. Can get soft medium and hard |
02-23-2017, 10:28 AM | #66 |
| Re: Gmade RSD Suspension? |
02-23-2017, 11:36 AM | #67 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
What is everyone using for the top mount bushing?
02-23-2017, 01:53 PM | #68 | |
Rock Stacker Join Date: Dec 2016 Location: Norway
| Re: Gmade RSD Suspension? Quote:
Are you sure about that? By adjusting the piggy back volume, you are changing the pressure of the damping oil in the shock chamber, which should effectively give the same result as changing the weight of the damping oil. | |
02-23-2017, 03:39 PM | #69 |
Rock Stacker Join Date: Jan 2017 Location: On RCC Studying
02-23-2017, 03:46 PM | #70 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: Gmade RSD Suspension? Pretty sure. The pressure on the oil won't change it's viscosity, so cannot change it's damping effect. Adjusting the piggy back screw will apply more pressure resisting the damper rod being pressed in, hence increasing the overall spring rate. |
02-23-2017, 06:09 PM | #71 |
02-23-2017, 09:29 PM | #72 |
| Re: Gmade RSD Suspension? I think you're correct here. I just built 2 off my shocks with the 3 hole pistons and 35wt oil. I bench tested them side by side in my hands with one screw all the way in and one out. I even switched hands til feel the difference. Dampening felt pretty similar, but the one with the screw all the way in felt like it had a harder spring rate. I'm gonna try 55wt in the other 2.
02-24-2017, 01:32 AM | #73 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
I'd rather have a dummy piggyback than this useless system with inversely proporsional compression to rebound dampening ratio. Those regular RSD's looks very interesting though. |
02-24-2017, 06:42 AM | #74 |
The springs on the normal RSD's are insane stiff.
02-24-2017, 07:15 AM | #75 |
| Re: Gmade RSD Suspension? I wouldn't say useless. Maybe with the stock stiff springs, but with softer springs I think they'll work great to fine tune.
02-24-2017, 09:57 AM | #76 | |
Ok fair enough. I am tring to extrapolate my understanding of how motorbike damping adjusters work. These seem to adjust the pressure of piggy back or external chambers. However I guess the design is more complex than what can be achieved in a 1/10 scale shock. | |
02-24-2017, 10:02 AM | #77 |
| Re: Gmade RSD Suspension? Can anyone confirm if the RSD piggybacks come with the stiffest (red) springs as standard? If I order some I will probably order a set of mediums (white) and softs(green) at the same time to allow future tuning options.
02-24-2017, 11:45 AM | #78 |
Put my second pair together with 55wt and the 3 hole pistons. This feels much better to me for the rear end on my truck. While setting everything up to build them I glanced over and noticed my rc4wd rock krawler shocks on my mud truck and had a thought... ...After building the rsd's I pulled a spring off my rk's and it fit the rsd's bodies, collars, and cups. Next I searched my spare parts for a stock cup and the rk springs fit them too. Point there is that the beef tips for scx shocks will work. I searched for spring sets and the 110mm rk springs are 44mm long and since they're a dual spring setup you'll only need one set. Here is a side by side of my rsd's with the stock springs and rc4wd springs from 90mm rk's. Sorry for the long write up, but this might help others... [IMG][/IMG] |
02-24-2017, 07:20 PM | #79 |
Hopefully I can get it out tomorrow for a decent test, but I can tell on the bench the springs are too stiff. Also I'm almost wishing I would've went with the 80mm's. I don't have stock shocks anymore, but these 90's are taller. I'm running scx10 limiting straps and depressed the shocks a little otherwise it would sit higher. [IMG][/IMG] |
02-24-2017, 09:42 PM | #80 |
Pebble Pounder Join Date: Mar 2016 Location: westminster
Too bad those shocks aren't threaded further so you can back the preload off more. That has always been a turn off for me regarding these shocks.
Gmade RSD Suspension? - Similar Threads | ||||
New G-Made RSD Shock Absorbers | LSXGMC | General Scale Talk | 21 | 01-22-2017 02:08 AM |
Gmade R1 Stealth Cantilever Suspension | bikerzee24 | G-Made Crawlers | 33 | 04-04-2014 08:15 PM |
Titanium Steering and Suspension Links for Gmade R1 | Blue Monkey RC | Chassis and Suspension | 0 | 02-14-2013 01:41 PM |
rustler suspension arms versus bandit suspension arms... | STEEL_CITY_CRAWLER | Non Crawler RC's | 5 | 08-30-2010 11:05 AM |
rsd and wheel speed | nuts5000 | General Crawlers | 7 | 04-07-2008 06:43 PM |
