06-14-2012, 05:39 PM | #21 |
Pebble Pounder Join Date: Sep 2011 Location: USA
Very nice Ty! Looking forward seeing it all done. What gearing will you be running? I am also using rx8 pro3300 but the fan will always run if purely crawling. Keep up the good work. Sent from my iPhone using Tapatalk |
06-14-2012, 06:16 PM | #22 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
| Re: Recon Wraith Build
I've been very happy with the Pro4 in my wraith it does it all very well.
06-14-2012, 07:41 PM | #23 | ||
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Recon Wraith Build Quote:
Got some more work done tonight, will post up pics in a bit. | ||
06-14-2012, 07:49 PM | #24 |
Sorry it runs for awhile then turns off but it only takes a few minutes to kick back on. I think it stays between 2-3 LEDs. Love it though great products! Sent from my iPhone using Tapatalk |
06-14-2012, 10:08 PM | #25 |
| Re: Recon Wraith Build Gotcha, I didn't even put a fan on mine, can't fit it with the way I ran the wires!
06-14-2012, 10:16 PM | #26 |
So tonight I tackled the spare tire mount, which was stupid easy! I took a piece of the cage and bent it to shape with heat, screwed it to the top of the RX box and drilled a hole for a body clip. Voila! I also cut some lexan panels, wrapped them in carbon.... Installed them to better hide my wiring! They are screwed to the RX box and the chassis. Started adding some scaleness for the G6! I know, one of my screws doesn't match, I lost the other one lol. M16, just in case.... Then I decided I needed a panel to fill the void in the tailgate area. Came up with this: Just needs a few more scale pieces and I need to make a tow strap. After that it's paint (in process) and that CKRC winch/battery plate for the front! Last edited by Ty@Tekin; 06-14-2012 at 10:18 PM. |
06-15-2012, 05:15 AM | #27 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
I like the way you mounted the spare tire, hope you don't mind if I barrow that. Also nice build.
06-15-2012, 08:19 AM | #28 |
| Re: Recon Wraith Build |
06-18-2012, 12:25 PM | #29 |
Winch/battery plate showed up from CKRC today! Got the AS-2 servo winch mounted with the MadDogRC hook and line spooled on. Busted out this quick fairlead mount, going to file it smooth and paint it black. Just need to put a guide eyelet or two for the line under the hood and I'll finally be done with the winch project. Hopefully this servo lasts a little while, it's decently strong and can pick my Wraith completely off the ground. Had to test it out at my desk to see! |
06-18-2012, 10:23 PM | #30 |
Couple pics from a little wheeling tonight while looking for morels. Winch works really good, I just have to get better at using it. Had a PL roofrack sitting around, threw it on. Probably won't last long but it looks good now! Last edited by Ty@Tekin; 06-18-2012 at 10:30 PM. |
06-19-2012, 05:03 AM | #31 |
Newbie Join Date: Sep 2011 Location: Australia
Sweet rig mate, might have to copy some of your ideas on mine
06-19-2012, 10:36 PM | #32 |
Panels fresh out of the paint booth! Found some sweet packs to put in the rack and some barrel thingies. The packs are perfect, even have little grenades and knives on them. Aluminum rear 4-link mount Aluminum drag link and tie-rod They were new but I couldn't resist wheeling last night. I think it's finally kind of ready for Axialfest. Would have been nice to upgrade a few areas first, but we'll see how it does! |
06-20-2012, 05:55 PM | #33 |
It came out great. Paint is killer you got some skills. Are those Proline Titus wheels? I can't find them anywhere Sent from my iPhone using Tapatalk |
06-20-2012, 06:08 PM | #34 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
06-20-2012, 09:22 PM | #35 | |
Thanks! I tried to match it to my EXO, it came out pretty good! They are the Titus, I like them quite a bit on this rig. | |
06-20-2012, 09:54 PM | #36 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
when you wrapped the panels in carbon fiber did u use 3m's di noc vinyl or ebays and did you actually wrap the lexan or just stick it on and cut around it??
06-20-2012, 10:04 PM | #37 |
Rock Crawler Join Date: Jan 2009 Location: Boise
You guys need to get down to Boise,Emmett to do some scale crawls I mean heck you guys go to TQ to race in Meridian lol. The Wraith looks really good also. Sent from my Xoom using Tapatalk 2 Last edited by boisetrucker; 06-20-2012 at 10:09 PM. |
06-21-2012, 07:20 AM | #38 |
| Re: Recon Wraith Build Just stuck it on and trimmed the edges. It's not 3M, I got a 5' roll off eBay for $10.
06-21-2012, 07:21 AM | #39 | |
On my way to Axialfest, about a 9 hour drive today! Got everything crammed in my Subie haha. | |
06-21-2012, 12:29 PM | #40 |
Recon Wraith Build - Similar Threads | ||||
My Wraith build | SFT2 | Axial Wraith | 35 | 05-12-2013 02:58 AM |
1.9 Wraith build | rckjeep | Axial Wraith | 25 | 07-07-2012 02:47 AM |
UK Wraith Build | o0wiz0o | Axial Wraith | 6 | 04-24-2012 12:08 PM |
scx-10/tundra recon build*still going* | sj4x4 | 1.9 Scale Rigs | 2 | 10-22-2011 08:16 PM |
My Recon build..... | FrankyRizzo | 1.9 Scale Rigs | 60 | 09-28-2009 12:46 PM |
