10-09-2013, 07:29 AM | #61 | |
Quarry Creeper Join Date: Sep 2011 Location: hemet
| Re: Apparently "Ultra" wasn't enough Quote:
10-10-2013, 10:23 AM | #62 | |
Quarry Creeper Join Date: May 2012 Location: Baja, Mex / Calexico, Ca.
I have my idea if I ever go for a IFS I may considering a Slash front end, I have seen some custom builds here on 2.2 section that have a slash front end and run awesome, parts are everywhere and not much modifications needed to work with the wraith skid plate | |
10-10-2013, 10:43 AM | #63 |
Quarry Creeper Join Date: Mar 2010 Location: murrieta
Who can tell me what's the advantage of running the IFS over a straight axel system?
10-10-2013, 10:53 AM | #64 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
| Re: Apparently "Ultra" wasn't enough In a go fast rig, the geometry of the 4 link suspension usually fights itself to compress. As the rig is moving forward and hits a bump, the axle must also move forward as it cycles through the arc of suspension travel. The rear axle, unlike the front, moves the opposite direction as that axle hits the same bump. An A arm suspension moves in the same direction as the force being applied to it without having to fight the force until the cycle passes center.
10-10-2013, 11:07 AM | #65 | |
10-10-2013, 12:25 PM | #66 | |
Quarry Creeper Join Date: Jul 2011 Location: Temecula
But the slash arms might be a little short. I just need to get my hands on some parts and start trying stuff out. Last edited by snicklefritz; 10-10-2013 at 12:28 PM. | |
10-10-2013, 12:30 PM | #67 |
| Re: Apparently "Ultra" wasn't enough |
10-10-2013, 03:22 PM | #68 |
Here's some video of "The Doc" Mike Duncan and his beast at the U4RC race last Saturday. It looks kinda like a bigger Twin Hammers, pretty sweet. It jumps well, is fine in the rocks. Just needs better turning. I was reading his thread in the 2.2 section and it sounds like SC wheels are the key to getting a tight turn radius. Mmmmm. What to do? What to do? https://www.youtube.com/watch?v=KgLM...embedded#t=351 I guess I'll stop being a little girl and put my freakin exo front end on already and then drive it. The cool part about the Blue Monkey kit is you don't have to destroy anything to put it together. Pretty much a bolt on. |
10-10-2013, 04:27 PM | #69 | |
10-10-2013, 05:59 PM | #70 |
Original would be revo parts and custom arms tied into a tube frame. Now my gears are turning. Could use the rocker arms or build whatever you wanted. Actually think the rocker arms wouldn't be needed. Since your building your own arms and all |
10-10-2013, 11:54 PM | #71 |
I have an obvious idea for better turning. 4WS. I will have a front axle with STRC gear laying around after I go IFS, right? I should only need it at one or two spots on this particular track, but it seems like a good idea. Any thoughts?
10-11-2013, 05:35 AM | #72 |
| Re: Apparently "Ultra" wasn't enough Thoughts?...yea I think you are out of control |
10-11-2013, 06:29 AM | #73 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
If you can transition between 2ws/4ws while driving it should work fine for certain sections, and not be so squirrelly at speed. But if its just 4ws, I wouldn't do it, too much of a handful around the entire course. The SC wheels are an easy mod, just cut the tires obviously, and depending on which rim, trim the foam to fit the 3.0 portion. I used slw hubs to match width front/rear on exo rear rims |
10-11-2013, 07:51 AM | #74 |
Thanks, Bobby! "Or am I so sane that I just blew your mind!?" Erin, what I was thinking was transitioning using the 3rd channel, so I'd be using 2ws for most of the course and hit 4ws for the tight 180 at the bottom of the hill, the railroad tie step -up, and maybe at the top of the hill,too, if needed. Those are slow sections anyway so I think I could do 4ws smoothly. |
10-11-2013, 09:55 AM | #75 |
go back to bed snickle, all this brainstorming is wearning me out.
10-11-2013, 10:01 AM | #76 | |
That will def work, just build that rear axle tough, as the steering will take a good beating, but probably no worse then a front setup | |
10-11-2013, 11:27 AM | #77 |
I say go for it. If it works you just solved the EXO steering problem. If not, lock it back out.
10-11-2013, 05:34 PM | #78 |
Ok, you have had all day to get this prototype done. Let's see it. |
10-11-2013, 05:46 PM | #79 |
Hey Snickle, I a few DIG's here you can play with |
10-11-2013, 05:59 PM | #80 |
You want him to play with your what?
Apparently "Ultra" wasn't enough - Similar Threads | ||||
Crawler Innovations "Top Shelf" Ultra 4 | Nova's Ark | 1.9 Scale Rigs | 100 | 06-01-2018 10:31 PM |
Gear Head RC "Trail Torch" Ultra Bright LED Light Bar | Gear Head RC | Vendors Electronics | 0 | 02-04-2012 11:14 AM |
Dinky R/C's Ultra 4400, "The Muddauber" | muddauber7 | 2.2 Scale Rigs | 23 | 09-03-2011 05:49 AM |
