10-16-2013, 12:57 PM | #101 |
Quarry Creeper Join Date: Mar 2010 Location: murrieta
| Re: Apparently "Ultra" wasn't enough
Hey Snickle, why the slash front IFS system over the exo system?
10-16-2013, 02:30 PM | #102 | |
Quarry Creeper Join Date: Jul 2011 Location: Temecula
| Re: Apparently "Ultra" wasn't enough Quote:
Well, I went with some $20 CVD's off ebay. I've seen some good reviews for these when used in this application so I went for it. They're also lighter than the MIP's which is good. Ick you were asking about lockers for the IFS so I'll bring it up here so others can chime in. I've seen the heavy duty set ups like Harley is doing. I won't go that route unless I have to, but I was also thinking of JB Weld like you said. Erin mentioned using silly putty and I will try that first. It should lock up nicely but have a little give to prevent snapping parts. If I need less locking for better turning I can always remove it and go to grease for "limited slip". Rainbow should be a good place to do some testing, don't you think? Maybe Sunday if all goes well. | |
10-16-2013, 02:34 PM | #103 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
I run open diff in my TH with 500,000 weight oil...if you want to call it that, it's closer to silly putty. I have plenty if you want to try that first.
10-16-2013, 02:36 PM | #104 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: Apparently "Ultra" wasn't enough |
10-16-2013, 02:48 PM | #105 | |
https://www.tamiyausa.com/items/radi...-1000000-54419 | |
10-16-2013, 07:27 PM | #106 |
Wow, they are proud of both brands lol. Interesting tamiya says its the same as a spool, thats a pretty bold statement for a jar of thick snot. |
10-16-2013, 08:16 PM | #107 |
What are your thoughts on that sweet tekin motor?
10-16-2013, 09:19 PM | #108 |
Sweet is the word. And I've only scratched the surface. I'm gonna gear for a little more speed next time. I had so much torque to spare last time. When I got in a tough spot in the boulders I could goose it and it would just about jump out. And the weather will be nice and cool in November so motor temps shouldn't be an issue. I'm glad I didn't skimp on the motor/esc. |
10-17-2013, 06:00 AM | #109 |
Rock Crawler Join Date: Jun 2012 Location: jville
On my front diff in my wrexo I took all the lube out put the gears back in place and took the two smalll gears from the rears diff there the same gears as what's in the front and put them in so I have a gear on all 4 sides and I filled it up with some diff lube I had from a kit just because...but when u screw it back together u have a locked diff its work so far and hasn't caused me any problems but its a simple free fix if u took apart a whole exo for a $3 locker if u already had the other parts and just needed the gears
10-17-2013, 09:43 AM | #110 | |
10-17-2013, 11:17 AM | #111 |
Nice! Are you getting the 3500 or 3000? On their site they only rate the 3500 for 2s. I've got the 3500 and I haven't tried it on 3s but I may get crazy one day and go for it.
10-17-2013, 11:26 AM | #112 |
| Re: Apparently "Ultra" wasn't enough See that where I'm not sure, jerry runs a 4600kv and says it great, I don't know if I need all that power. 2 cell's on my other cars is faster then my skill level. What do you think?
10-17-2013, 03:50 PM | #113 |
Do you want to drive mine before you order? I think I'll have it put together by late tomorrow.
10-17-2013, 06:25 PM | #114 |
Jerry's RC Garage Join Date: Apr 2010 Location: lake forest
With 4600kv you have to gear down
10-19-2013, 01:10 AM | #115 |
Alright, she's a wrexo. I was able to plug everything in and drive it around the living room. I can tell I'm gonna need a stronger rear servo to keep up with the front. I played a little with the controller and it wasn't too hard to program for 4 wheel steer. That was actually the easiest part of my day. I think 4ws was a good option for improving the steering due to the exo's limitations. The plan is to tweak it a little tomorrow and try it on the track Sunday . . .
10-19-2013, 10:21 AM | #116 | |
10-19-2013, 11:23 AM | #117 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
I run the pro4 HD 3500kv on 3s geared 13/54 in a 12lb wraith. Never gets above 130
10-19-2013, 12:26 PM | #118 |
I got the electronics zip tied in and took it for a little driveway test run. And I like it! The turning is sharp, of course, but also pretty stable. I think I can work with this. I've got it set up for full time 4ws right now and that's how I'll test it tomorrow at the track. I'm guessing if I set up the steering mix right I can run 4ws full time and not have to worry about switching back and forth during a race. I can see trying to switch from 2ws to 4ws and back going wrong and getting all turned around. I'll try to keep it simple. full right I'll need a stronger rear servo and a longer motor sensor cable. Maybe softer springs for these proline shocks. I better put in another order. I'll get some video tomorrow at the track. Stay tuned. |
10-19-2013, 12:51 PM | #119 |
In the 4ws pic, is that full throw on front?
10-19-2013, 01:10 PM | #120 |
Yes, sadly. That's the point where the knuckle hits the caster block.
Apparently "Ultra" wasn't enough - Similar Threads | ||||
Crawler Innovations "Top Shelf" Ultra 4 | Nova's Ark | 1.9 Scale Rigs | 100 | 06-01-2018 10:31 PM |
Gear Head RC "Trail Torch" Ultra Bright LED Light Bar | Gear Head RC | Vendors Electronics | 0 | 02-04-2012 11:14 AM |
Dinky R/C's Ultra 4400, "The Muddauber" | muddauber7 | 2.2 Scale Rigs | 23 | 09-03-2011 05:49 AM |
