07-11-2014, 09:04 PM | #21 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Re: Go fast wraith suspension - Turned build thread
Woah you beat the living hell out of this rig lol Jk Great build, looking forward to some more updates!
07-15-2014, 09:08 AM | #22 |
RCC Addict Join Date: Aug 2013 Location: Missoula
HD gears finally showed up. Anybody running these on the drive side or coast side specifically? The stock gears were straight cut, the HDs are helical, I would prefer to run them on the drive side, but if it makes no difference I won't worry about it. I will be shimming the pinion to set the backlash and end play. |
07-15-2014, 09:48 AM | #23 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
i spoke with someone at Axial about it a while back, and they said it ultimately doesn't matter. if you can, i'd still try to run them on the drive side.
07-15-2014, 11:14 AM | #24 |
Yeah running the gears on the drive side will be your best bet, just curious, what kind of shims are you going to use? I've thought about shimming the gears in my wraith so it doesn't screw up the diffs with all of the power it has.
07-15-2014, 12:04 PM | #25 | |
| Re: Go fast wraith suspension - Turned build thread Quote:
Sounds like I'll run it on the drive side and flip the rear as well. Guess I won't get my daily lunch time session in Got it wrapped up. Good thing those shims are cheap, I didn't use a single one. Held up just fine for the 5 minutes I beat on it. Last edited by maslin; 07-15-2014 at 01:11 PM. | |
07-15-2014, 04:39 PM | #26 |
Oh well thank you, you answered my only question lol. If I need a set of shims then I know what to get now hahaha. Good luck! |
07-16-2014, 12:48 PM | #27 |
Carnage from one lunch session, both in the front. Now its really time for a spool. |
07-17-2014, 01:09 PM | #28 |
Might as well throw the last spare axial locker in there to last the weekend..... |
07-17-2014, 10:59 PM | #29 |
Newbie Join Date: Jan 2012 Location: Crawlerado
| Re: Go fast wraith suspension - Turned build thread |
07-28-2014, 10:35 AM | #30 |
Back in action. Hot racing locker was the first to come back in stock on RPP. I also noticed the locker side of the front shafts were extremely worn, from being beaten around in the broken lockers. New set of universals was also installed. These lockers have no set screws and the shafts slide in fairly easily. They are far from "no slop." We will see how that works out in the long run. I just purchased my first house, and have 1.5 acres of pasture to play with. As soon as I can get one of the local guys to drop the hay, I'll be building a track. Stay tuned for mini excavator action pics |
08-01-2014, 09:37 AM | #31 |
Finally stripped the rear gears. HD set installed and shimmed. RC drag racing at the shop tonight, punch and timing turned up, pics to follow Upon closer inspection.... The front case of the Savox is split in half. Hope it holds through a few drag pulls Last edited by maslin; 08-01-2014 at 03:33 PM. |
08-02-2014, 02:14 PM | #32 |
Axles held up for the first time. ESC burned to the ground. 2s max actually meant 2s max |
08-11-2014, 02:29 PM | #33 |
New ESC on board. Set the throttle trim at light throttle to be very gradual. The cogging is almost completely gone. Now it's time to build a track. |
08-12-2014, 07:40 AM | #34 |
Rock Stacker Join Date: Mar 2010 Location: 934543
awesome build to follow....
08-12-2014, 07:38 PM | #35 |
Pebble Pounder Join Date: Jan 2014 Location: Archdale
damn man carnage everywhere. not sure you even like the wraith that much. I think I like your style. give it hell my friend. Enjoy |
08-13-2014, 08:14 AM | #36 | |
Ordered the Savox case halves, I didn't notice I had split it until the orange sticker flew off, mid donut | |
08-19-2014, 08:05 AM | #37 |
This made a funny noise. |
08-19-2014, 03:33 PM | #38 | |||||
RPM also sells two stage shock piston setups in soft, medium and firm damping. Quote:
Axial Wraith Differential Cover Grey - Vanquish Products Quote:
Locked up RC - FI Spool I love the way you mod your Wraith one thing at a time as it breaks! Slash body looks awesome and I dig your driving style!!! More carnage and upgrade pics please. | |||||
08-21-2014, 03:29 PM | #39 |
I have both the lockeduprc.com spool and hot racing and there's a little slop in both. Hr spool lasted a year under abuse of 6s power. I'd imagine locked will last just as long. Love your build. |
08-21-2014, 04:54 PM | #40 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
Great thread. Mine is setup for strictly slow crawling but I've always though about gettin another designed for speed. But....then I see all your carnage and can just imagine the problems. I know very little about Battery cars. I'll stick with the nitros for go-fast |
Go fast wraith suspension - Turned build thread - Similar Threads | ||||
Lucas's Wraith Build Thread | LucasAutomotive | Axial Wraith | 11 | 09-21-2013 09:20 AM |
Evol's Wraith Build thread | ev0l | Axial Wraith | 98 | 09-17-2013 06:47 PM |
aqwik69's Wraith build thread.... | aqwik69 | Axial Wraith | 23 | 09-14-2013 06:50 PM |
Rapid Rhino Wraith #1 - Build Thread | Kobier | Axial Wraith | 5 | 04-10-2012 09:38 PM |
Looking for a picture/thread for turned down stock shocks | Joat | Tamiya TLT Crawlers | 4 | 06-02-2008 08:15 PM |
