10-24-2015, 07:37 PM | #181 |
Rock Crawler Join Date: Dec 2014 Location: Rhode Island
| Re: Yeti XL Aftermarket Thread
Man you ruined that cookie sheet!!
10-27-2015, 06:22 PM | #182 |
Newbie Join Date: Aug 2015 Location: Australia
I've never baked off tyres before. does it stink ?? May have to do it when wifey is away lol |
10-27-2015, 06:56 PM | #183 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
| Re: Yeti XL Aftermarket Thread |
10-27-2015, 07:04 PM | #184 |
Newbie Join Date: Oct 2015 Location: san antonio
I use the dishwasher to clean full size truck parts....... But NEVER when the wife is home. It does an amazing job Sent from my iPhone using Tapatalk |
10-27-2015, 07:55 PM | #185 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
For anyone looking to balance there rc tires, pick up a dubro prop balancer part # dub499, its 25-30 bucks vs 50+ for an aluminum balancer. Its ridiculously smooth, a tiny push and it takes 5 minutes to settle to the heavy spot. I was definitely impressed with it.
10-28-2015, 08:24 PM | #186 |
Rock Stacker Join Date: Jul 2015 Location: US
Today's upgrades hot racing front piggybacks Sent from a galaxy far far away Tonight's upgrades Hot racing +8mm hub for the kit not rtr Sent from a galaxy far far away Installed Sent from a galaxy far far away Last edited by THX_138; 01-09-2016 at 01:51 AM. |
10-29-2015, 03:03 PM | #187 |
Greg - are you running stock hinge pins in the rpm a-arms? And doesn't the shock bolt need to be longer or something? Mine should be here tomorrow.
10-29-2015, 03:08 PM | #188 |
I am running stock hinge pins mine fit perfectly. RPM gives you a longer screw for the shocks in the bag. Sent from a galaxy far far away |
10-30-2015, 05:09 PM | #189 |
Just installed rpm a-arms and they are awesome and beefy. Stock hinge pins fit good and a-arms fit tight as well. RPM doesn't supply bolts for shocks, so you will need M3x25mm button head for it.
11-12-2015, 08:49 PM | #190 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
Except for a little wider track width what is the benifit of this? Seriously, I really don't know.
11-12-2015, 09:03 PM | #191 |
In the second pic the ring support around the wheel hex will greatly reduce the chance of stripping the wheel. That ring fits really snug. Also after I installed it you really can notice a wider stance. That will help with roll overs and handling. Sent from a galaxy far far away |
11-13-2015, 03:33 PM | #192 |
Newbie Join Date: Oct 2015 Location: Reading PA
11-19-2015, 07:59 PM | #193 |
Put the motor plate in the motor mount then put the top clamp on and see if yours has a tiny gap on both sides between the motor mount and top clamp where the 2 bolts go. Wondering if yours has this gap as well and if it's just how there made.
11-19-2015, 08:51 PM | #194 |
Today upgrades hot racing front shock tower hot racing body mount and aluminum pivot balls Installed Tonight's upgrades. HR motor mount and motor mount plate. HR suspension limit straps 140mm for the rear. Castle link to adjust punch to 80% and bec voltage to 6.2. And some HR super black lube There is a small gap. Looks if I tighten the screws it might get smaller like it should Sent from a galaxy far far away Last edited by THX_138; 01-09-2016 at 01:54 AM. |
11-19-2015, 08:56 PM | #195 |
Yup that's the gap. I haven't installed mine yet to see if tightening will close the gap but doubt it. Maybe its there to keep tension so the bolts won't back out?
11-19-2015, 09:06 PM | #196 |
I'm sure it is there to keep tension. Haven't installed it to tired. Still have to take tranny out install the mount and run the telemetry fan and on off switch threw the new mount. Maybe tomorrow after work Sent from a galaxy far far away |
11-19-2015, 09:09 PM | #197 |
Limit straps installed. Sent from a galaxy far far away |
11-21-2015, 02:20 PM | #198 | |
Newbie Join Date: Oct 2015 Location: New Albany
| Re: Yeti XL Aftermarket Thread Quote:
I have the same issue, wish I would have seen this 2 weeks ago. It really sucks. I am very frustrated at HR. | |
11-21-2015, 06:59 PM | #199 |
HR motor mount and motor plate installed Sent from a galaxy far far away |
11-22-2015, 06:16 PM | #200 |
Greg, did you still put locktite on the 2 bolts for the clamp on the motor mount or is the tension enough to hold the bolts? Wondering if locktite is over kill on that. How do you like the HR shock limiters? How close does the 140mm keep the rear shocks from fully extending? Are you picking up limiters for the front? Im thinking about picking some up too but wanted to hear some feedback. |
Yeti XL Aftermarket Thread - Similar Threads | ||||
Aftermarket springs question/thread | Troublekitty | Axial Wraith | 6 | 11-10-2014 09:20 PM |
yeti 1 week review/ build thread | db450 | Axial Yeti | 0 | 09-10-2014 12:49 AM |
Badger's Axial Yeti Rock Racer disassembly thread | badger | Axial Yeti | 193 | 09-02-2014 11:25 AM |
YETI Sightings Thread | Ty@Tekin | Axial Yeti | 1 | 08-04-2014 03:58 PM |
