01-30-2015, 12:53 PM | #21 | |
Quarry Creeper Join Date: Sep 2012 Location: Orange County, CA
| Re: The RCNetwork's Yeti XL -KIT version! Quote:
Yep, the KIT version includes a 15t 32p pinion for a 5mm shaft motor. I'm hoping its hardened (it's black in color), as the kit has a steel spur gear. I know that Axial is trying to keep the part assortment down, but I wish the XL was Mod 1, as most 1/8th scales are Sent from my iPhone using Tapatalk | |
01-30-2015, 02:09 PM | #22 | |
Pebble Pounder Join Date: Nov 2011 Location: raceland
01-30-2015, 04:40 PM | #23 |
Well, did some late night building, and was hopped up on RockStar, so I missed a few pics....of Bag E, but here's the parts minus a few screws for the rear cage/fuel cell: I got most of bag E complete minus the rear sway bar: Here's a couple of pics of the fuel cell. It's nice and scale, but I doubt I would use it to store anything (light wires, etc) Sent from my iPhone using Tapatalk |
01-30-2015, 04:43 PM | #24 |
Now for the long awaited rear sway bar.....the instructions wanted me to mount the sway bar prior to mounting the rear cage/shock hoops to the chassis.....but I got impatient and learned the hard way! Also, Axial give you metal balls for the sway bar links Sent from my iPhone using Tapatalk |
01-30-2015, 04:45 PM | #25 |
Now for the battery doors. They are nice and Revo style, but the hinge piece is just that plastic antenna wire looking thing in the tree: Sent from my iPhone using Tapatalk |
01-30-2015, 04:47 PM | #26 |
Bag F!!! Now it's time for the rear clip and mounting that massive rear axle to the chassis. Included were the anodized aluminum plays that reinforce the plastic trailing arms similar to the 1/10th Yeti, but larger! And what's in the bag: Here's a compare between the 1/8th and 1/10 trailing arms: Sent from my iPhone using Tapatalk |
01-30-2015, 04:49 PM | #27 |
Now all the rear 4 links put together. The kit included the RTR's plastic sandwiched upper links, which seem decent. The lower trailing arms clearly had too long of screws included: Now a look at the parts installed: Sent from my iPhone using Tapatalk |
01-30-2015, 04:54 PM | #28 | |
01-30-2015, 06:17 PM | #29 |
Rock Crawler Join Date: Jul 2009 Location: roseburg
how big of a streeing servo to go with?
01-30-2015, 06:47 PM | #30 |
| Re: The RCNetwork's Yeti XL -KIT version! I had to re-think my servo choice once I saw how large this thing was. I have a couple of extra Futaba servos that hit about 300 oz/in, but I did t think they would with stand this thing, so I just ordered in a Hitec HSB-9380. High voltage, brushless and right under 500 oz/in of torque. Sent from my iPhone using Tapatalk |
01-30-2015, 11:42 PM | #31 |
I started the shocks tonight. These things are massive, and probably the best shock I've assembled from Axial. Unfortunately, the piggybacks are not functional, but they sure look good! Based on the 1/10th scale Yeti, I was expecting the rears to be longer than the fronts, but they were all the same size with the main differences being spring rate, oil weight and pistons. Here's bag G And the contents: Sent from my iPhone using Tapatalk Last edited by RichMTB01; 01-30-2015 at 11:53 PM. |
01-30-2015, 11:45 PM | #32 |
They assembled nice and the instructions were solid. The KIT comes with the piggyback cap and a non piggyback cap. Here's how they look: It's too bad the brand logo for Icon is covered by the massive dual springs. Also, there's a sticker that's included for the piggyback that has a black Icon logo. And just a compare with a Quarter: Sent from my iPhone using Tapatalk Last edited by RichMTB01; 01-30-2015 at 11:51 PM. |
01-30-2015, 11:57 PM | #33 |
Now onto Bag H: Lots and lots of course screws for the cage system. Instructions got a bit wonky with the number of screws and sizes having a mis print. I did the cage before I installed the shocks, but here's how it looks: Sent from my iPhone using Tapatalk |
01-31-2015, 12:00 AM | #34 |
One of the last bag before dealing with the body panels and wheels/tires. Bag I: Pretty self explanatory, but aluminum hex nuts, serrated on one side Sent from my iPhone using Tapatalk |
01-31-2015, 12:20 AM | #35 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
Shock caps a appear to be plastic, correct? I was hoping to see aluminum with these shocks.
01-31-2015, 12:25 AM | #36 |
| Re: The RCNetwork's Yeti XL -KIT version! |
01-31-2015, 11:21 PM | #37 |
Pebble Pounder Join Date: Sep 2007 Location: Lowell
Any idea on actual shock size may throw a set off my 1/8 scale losi on there Sent from my iPhone using Tapatalk |
02-01-2015, 11:01 AM | #38 | |
I'm not at where my XL is right now........based on size, all four rears of a Losi 8ight might work.......I'll get you sizes on Monday. The Yetis do have a unique rear set up using 10wt oil in the rear with a 6 hole piston with 1.4mm holes. Sent from my iPhone using Tapatalk | |
02-03-2015, 01:50 PM | #39 |
Here's build update 1 of the Yeti XL KIT: http://youtu.be/ovPu864Irlg Sent from my iPhone using Tapatalk |
02-03-2015, 01:52 PM | #40 |
I've gotten pretty far on the Yeti XL KIT build and shot Update 2 today. Just gotta install the electronics, paint the body and glue up the 5 tires! Here's a couple of pics of the build this far: Sent from my iPhone using Tapatalk |
The RCNetwork's Yeti XL -KIT version! - Similar Threads | ||||
The RCNetwork's Yeti Build! | RichMTB01 | Axial Yeti | 172 | 12-17-2015 06:55 PM |
Yeti kit version. | Rockpiledriver | Axial Yeti | 39 | 01-07-2015 08:15 PM |
Axial Yeti: Aluminum Hood version 1 | CarterFab | Axial Yeti | 0 | 07-21-2014 08:23 AM |
