05-07-2016, 05:49 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Pinion Bearing Issues
Lost a rear pinion bearing bashing today after 3 packs and destroyed housing. I bash dirt no water or mud. Bearings were NEW AVID and I put extra grease in them before installing them. Had 14 6S runs on these gears with BHB mod no problems. I think I need to design a boot or something to seal the pinion. It is the lowest point on the truck and gets all dirt from the front drive wheels thrown at it. I don't think this is a gear issue because the rear bearing is gone but the head or front bearing is perfect. Any ideas? |
05-07-2016, 05:51 PM | #2 |
| Re: Pinion Bearing Issues |
05-07-2016, 06:10 PM | #3 |
Newbie Join Date: Mar 2016 Location: Hustisford, WI
It definitely looks like dirt found its way in there. I check/ replace pinion bearings every 15 runs on 4S. You might need to do a maintenance check after 10 on 6S.
05-07-2016, 06:14 PM | #4 |
I was on my 3RD pack with NEW bearings.
05-07-2016, 06:29 PM | #5 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
VP housing and ceramics. Thats my plan. Just need a VP housing now. Lol
05-07-2016, 07:54 PM | #6 |
I wanna be Dave Join Date: Jun 2013 Location: Ramona, CA
That sucks especially with Avids. I thought of using a shock or diff boot from a Losi 5, DBXL or one of the 1/5scale trucks but couldn't find measurements of the boots to see if they would slip over the axle housing. $$ Expensive but lots of spares https://www.amainhobbies.com/losi-de...252017/p272733 https://www.amainhobbies.com/losi-ce...sb3222/p228375 |
05-07-2016, 08:11 PM | #7 |
| Re: Pinion Bearing Issues 5 Piece Heat Shrink Wire Wrap Assortment That comes with a 1" tubing size and I think that should fit over the housing. |
05-07-2016, 08:29 PM | #8 |
Looking at that option. Also thinking of using a automotive freeze plug backwards. Press fit over nose of housing drill a hole and CL glue some foam to it and use some shock oil in the foam to trap the dirt like a K&N air filter. You can remove the foam when dirty and install a new piece. No drag on the drive shaft.
05-07-2016, 09:13 PM | #9 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
I've been running the XL this weekend and the bearings are packed full of mud... Ive gotta do a boot mod !! My gears still look new 75+ runs !!!
05-08-2016, 02:56 AM | #10 | |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: Pinion Bearing Issues Quote:
05-09-2016, 05:54 PM | #11 |
05-09-2016, 05:57 PM | #12 |
Pebble Pounder Join Date: Feb 2016 Location: Stillwater
That's a great idea! Should help quite a bit for dirt/mud. I'm sure water will still find a way but at least it won't be being forced in there like it was before! Sent from my iPhone using Tapatalk |
05-09-2016, 05:58 PM | #13 |
Still have full shaft articulation and being its open in the back if stuff gets in it SHOULD fall out. Plus it cost nothing. Hopefully get some testing this weekend. Don't do water here.
05-09-2016, 06:13 PM | #14 |
Awesome mod Pro Mod !!! I'm gonna have to try this one out !! That plastic looks lite & soft !! Awesome !! |
05-09-2016, 07:03 PM | #15 |
Put it all back together with same gears and still smooth as glass. Guess I got lucky. New housing of course.
05-09-2016, 07:10 PM | #16 |
That's awesome Steve! Looking forward to your findings! Got my batteries today by the way. Can't wait to try em out Sent from my iPhone using Tapatalk |
05-09-2016, 07:51 PM | #17 |
Nice work to you and your coworker. Sometimes it is the simple things that actually may work. Look forward to seeing if it holds up.
05-09-2016, 08:25 PM | #18 |
Thanks everyone. Hoping this is something simple that can help everyone. Come hell or high water I am going to own this beast and beat it like it owes me money and get change back.
05-10-2016, 05:32 AM | #19 |
Nice job! I'm quite curios how well will keep the dust away. I was thinking of even a more waterproof solution by installing a bearing on the shaft and some kind of flexible hose from this bearing to the rear axle. I am still thinking I don't think a shrink tube will work, it's too stiff, especially at this diameter.
05-10-2016, 02:41 PM | #20 |
Newbie Join Date: Mar 2016 Location: Kingsville, On
Hell of a idea Steve! I did something similar but I like your idea better if it works. I used this.. https://www.amainhobbies.com/align-l...60064b/p207449 It looks like an oversized rubber O ring. I slid the O ring over the drive shaft so that it almost touches the diff housing. |
Pinion Bearing Issues - Similar Threads | ||||
Pinion carrier bearing issues | arnesto | RC4WD Trail Finder 2 | 21 | 02-14-2017 08:58 AM |
Just blew inner rear pinion bearing and... | twisted | Axial Yeti | 18 | 08-01-2015 08:52 PM |
Anyone have bearing/diff issues? | Patella | Rally | 12 | 11-27-2012 05:22 AM |
Axle Pinion Bearing pushes out | r34sklnnsn | Axial SCX-10 | 9 | 02-05-2011 09:40 PM |
Pinion Bearing Walk? | sickfab | HPI Wheely King | 12 | 08-29-2007 01:28 PM |
