11-29-2014, 05:21 AM | #61 |
Quarry Creeper Join Date: Oct 2014 Location: Barre
| Re: Project RoadRash
I know that some have their own remote - which I assume eliminates the need for an extra channel? I think those are pricey too. I had just started looking around. Do you have a place lined up to install it? |
11-29-2014, 05:34 AM | #62 | |
Rock Crawler Join Date: Oct 2011 Location: Fairfield
| Re: Project RoadRash Quote:
There are some mounts that places them right behind the front tower/bulkhead on the top plate and the line runs right through the front tower | |
11-29-2014, 05:44 AM | #63 |
Aha. Very cool. At least it's a straight shot.
11-29-2014, 07:02 AM | #64 |
| Re: Project RoadRash Here is a option from gear head rc But I would almost rather go to a servo winch seeing it isn't going to be visible. Stronger, more powerful and more line. Like this... This one is from TCS Crawlers. Only issue with this is you defiantly need a 3rd channel. Both can be had for $15 |
11-29-2014, 07:11 AM | #65 |
$15, or $115????
11-29-2014, 07:13 AM | #66 |
| Re: Project RoadRash |
11-29-2014, 07:15 AM | #67 |
RCC Addict Join Date: Jan 2010 Location: Vermont
I'm definitely going servo winch with that Gearhead mount. Pretty slick. |
11-29-2014, 07:15 AM | #68 |
11-29-2014, 07:16 AM | #69 |
11-29-2014, 09:57 AM | #70 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
Good work coma...I'm about to see if I can shave weight somehow on my rig..it's starting to get a bit heavy (like it matters with the pro4) with all the aluminium lol
11-29-2014, 10:13 AM | #71 | |
Thanks Dasco!! Yeah I have had weight in the back of my mind as well. Think I'm not gonna upgrade until it breaks type method once I get the new power plant in and some better wheels and tires. Speaking of wheels...just scored these locked up RC wheels with all the hardware and rings (only axial rings) for $50 Even have the scale hardware for the hubs | |
11-29-2014, 10:31 AM | #72 |
12-02-2014, 06:01 PM | #73 |
My wheels came in today, they are beautiful! With them being reversible I semi mounted them on the yeti and looks like I will be able to run the same hubs just flip the rears for more offset! I also went through and started working on suspension stuff. I found that you can't flip the stock a arms. Opie sent me a pic of his lower side of his rpm ones and doesn't look like they have the same issue. The most outer cross brace interferes with the hub carrier. Also I found a bent hinge pin as well. I see someone used a 1/8" drill blank with a collar clamp to upgrade the weak stock ones. I'll hafta dig up that thread and post the link in here for reference. I also went through and refreshed the shocks. The shocks sounded like there was a bunch of air in them and I had no clue what oil weight was in there. Defiantly needed some new oil I decided to try 30 wt in there for now. I also gonna try some old tmaxx springs I have kicking around, I also have some honcho springs so maybe I can setup some dual rates in the rear. Won't really know much until I get the new motor esc in to test different shock setups out. Might make a small order for some items tonight and tomorrow I'll rebuild the trans and probably go through the diffs, see how motivated I am haha |
12-02-2014, 07:05 PM | #74 |
Which wheels did you end up getting? I'll be curious to see how the springs work out. I was able to improve my rear suspension with some of the stiffer springs. But now it seems to bounce a bit much on straight shots across the large, bumpy grass at my buddy's place. Gonna try a set of some gmade shocks I picked up cheap. People seems to like them, so we'll see. I got the axial diff locker to try out too. Found I needed it on some terrain, but of course not on others. Unfortunately it's a b*tch to get in there - but should be interesting to compare the locked front. |
12-02-2014, 07:30 PM | #75 | |
I believe they only put 15wt in the rears from the factory. Some heavier oil like 30wt should help to get rid of the bouncing. What was in the front before? Stock? I'm gonna try the heavier diff fluid first. I should have a big for sale post next week. Should help fund the yeti stuff. | |
12-02-2014, 07:33 PM | #76 |
Let us know what you have for sale here first. I have 30wt in the back and front. I think 30 was the stock front already. I may need to set them up again. No bleeder hole doesn't help. |
12-02-2014, 07:35 PM | #77 |
Oops I didn't answer your 1st question haha. I got a set of used "Locked up rc 2.2 Iconic" wheels. These are full aluminum, slw, easy mount (mount up like the non slw axial Beadlocks). I got the scale hardware with them for the hubs but only got axial rings. I will like to add a set of locked up rc rings eventually. Just haven't decide what ones yet haha. I received them today, felt like I stole them. They are like new and even got extra scale hardware and a spare locking ring. No stripped holes. All for $50 |
12-02-2014, 07:39 PM | #78 | |
Yeah it took a little while to get them right. It was definitely messy haha. Mine barely start getting hard at full compression and when cycled quickly no bubble sounds. Should be good. I'll hafta see what I'll have to sell. Might be a lot of "scale" items. I do not know yet. Hehehe | |
12-03-2014, 11:05 AM | #79 |
Well I'm not gonna be using the Locked Up RC wheels for the yeti. I'm gonna save these for a wroncho project that I'm starting to gather parts for. Just ordered a set of the Mayhem Engineering 2.2 Monsters for a little more bling haha. I CANCELED THE ORDER...DIDNT REALIZE THE HUBS WERE DIFFERENT THAN VP'S AND THE SMALLEST HUB IS A .450 TO WIDE FOR MY LIKING. Last edited by 802coma; 12-03-2014 at 05:50 PM. |
12-03-2014, 03:43 PM | #80 |
Very sweet.
Project RoadRash - Similar Threads | ||||
Tire project for pede project | Mdlopez1 | Non Crawler RC's | 2 | 04-21-2013 06:30 PM |
