10-24-2015, 06:46 AM | #121 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD Rear Axle
The new shafts will be an upgrade made from a new stronger material and new hexes. We have removed the hex pin from the design so new hexes will be included.
10-24-2015, 05:15 PM | #122 |
Pebble Pounder Join Date: Mar 2015 Location: france
| Re: SSD Rear Axle |
10-26-2015, 08:28 AM | #123 |
Pebble Pounder Join Date: Feb 2013 Location: Canada
| Re: SSD Rear Axle
I am checking this thread everyday day, even though I am subscribed, to see if the HD shafts have been released. My Yeti is so sad sitting on the shelf.
10-26-2015, 11:54 AM | #124 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
| Re: SSD Rear Axle |
10-26-2015, 01:15 PM | #125 |
| Re: SSD Rear Axle
The sound of moving the pin outta there sounds like it should solve the issue |
11-20-2015, 02:21 AM | #126 | |
Pebble Pounder Join Date: Sep 2013 Location: Portugal/Lisboa
| Re: SSD Rear Axle Quote:
Do you mean that the yeti version will make the rear width the same as the front wraith or the front of the Yeti? | |
11-20-2015, 02:35 AM | #127 |
| Re: SSD Rear Axle |
11-20-2015, 03:57 AM | #128 |
| Re: SSD Rear Axle oohhh ok, I just ask that because I made the ax10 to the xr10 axle mod on the front since I have the ax10 axles on the wraith frame. And now I have to do the rear mod, at this moment the rear axles are the same lenght because I have spacers, but I would like to take them of and make the rear mod, so in this case I should go or for the SSd wraith axle shafts our for two stock wraith short shafts. |
11-20-2015, 09:18 AM | #129 |
Pebble Pounder Join Date: Dec 2014 Location: Duluth
| Re: SSD Rear Axle
^ idk, but i bet you would get more help outside of the yeti forum, so I hope your asking this else where.
11-21-2015, 07:33 AM | #130 | |
11-21-2015, 09:47 AM | #131 |
| Re: SSD Rear Axle
In confused by what he is trying to do...
11-21-2015, 10:10 AM | #132 |
| Re: SSD Rear Axle
^ that's cause he is talking first gen AX10 and SCX10 stuff.
11-21-2015, 10:43 AM | #133 |
| Re: SSD Rear Axle
I figured that much but what does the SSD wraith/yeti axle have to do with it.
11-21-2015, 04:39 PM | #134 |
| Re: SSD Rear Axle
trying to match the rear axle width to the front i believe.
11-22-2015, 02:58 PM | #135 |
| Re: SSD Rear Axle Yes thats it, trying to set the rear axle as the front. And if I could find a rear axle shaft the same size as the universal xr10 shafts it would resolve my douth. I did the front by looking at photos here on the forum, but as for the rear there isnt that many information. |
11-22-2015, 03:05 PM | #136 |
| Re: SSD Rear Axle
I really dont get why you are posting in this thread. you are clearly not talking about a Yeti.
11-22-2015, 03:14 PM | #137 | |
No, just was asking if the yeti axles shafts would be the same lenght of the front xr10 mode. But I got my aswer. I made a project of the ax10 axles with a wraith cage, so thats why I made the ax10 to the xr10 axle mod. | |
11-22-2015, 03:17 PM | #138 |
| Re: SSD Rear Axle |
11-22-2015, 03:21 PM | #139 |
| Re: SSD Rear Axle Yes I now thats why I made the front xr10 mod with the universal axles, it makes the ax10 axles the same lenght as the wraith this for the front, now I have to get some shafts for the rear, and was thinking the the ssd yeti axle shafts would get me the same lenght, but as said the yeti is wider then the wraith so I have to look for another shaft.
02-01-2016, 05:14 PM | #140 |
Quarry Creeper Join Date: Nov 2014 Location: WA
| Re: SSD Rear Axle
What's the size of the pinion bearings? Same as a stock? I can't find it anywhere. |
SSD Rear Axle - Similar Threads | ||||
New SSD Wide Axle Kit for Yeti | SSD | Axial Yeti | 28 | 02-19-2017 08:17 PM |
SSD New wraith axle housing | Szczerba | General Crawlers | 180 | 03-01-2016 08:19 PM |
New SSD Narrow Rock Shield Rear Bumper for SCX10 | SSD | Axial SCX-10 | 15 | 06-13-2015 07:01 PM |
