10-09-2015, 05:51 PM | #41 |
Rock Stacker Join Date: May 2015 Location: central PA
| Re: Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR
The blue accents on the shocks gotta go. I think they make the shocks look cheap. That's just me though. Give me black caps/collars/spring cups at least.
10-09-2015, 05:55 PM | #42 |
Newbie Join Date: May 2015 Location: CA
I'm not sure yet. I'm still on the fence on this one. And I am saying this as Axial Yeti fan #1. The Yeti is known to be very front-end (nose) heavy. I don't know if Axial did anything to resolve this issue. I don't want a nose-heavy short course truck. |
10-09-2015, 06:01 PM | #43 | |
| Re: Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR Quote:
10-09-2015, 06:46 PM | #44 |
Rock Stacker Join Date: Aug 2015 Location: jackson
you better keep it rubber side down . a truck this heavy is going to eat bodies with no real cage .
10-09-2015, 07:28 PM | #45 |
Quarry Creeper Join Date: Mar 2009 Location: western ny
| Re: Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR Funny thing is if they followed all of our designs we have the full cage . In fact mine is still using the stock Yeti one . All I have to do is remove the body posts I made , reinstall the stock tires and shocks and I can go right back to the stock Yeti .
10-09-2015, 07:41 PM | #46 |
Quarry Creeper Join Date: Nov 2014 Location: WA
SCT bodies are "disposable" ... the amount of tire rubbing, crashes and everything else this bodies get, not will last long. But it's know fact. Nothing new about it. |
10-09-2015, 10:29 PM | #47 |
Quarry Creeper Join Date: May 2015 Location: RRW
Was going to build a wraith but changed my mind to the yeti as it seemed a better platform for racing with the independent front suspension. Now there is this which I like the looks of a lot better. Please release this as a kit before the new year and I'll buy it.
10-09-2015, 11:07 PM | #48 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
To me still looks like a Yeti with a SCT body but longer in the rear and shocks and it looks like EXO front end...It will be no time before somebody combine this with the Yeti...Or why would you still looks like a Yeti Looks nice and I'm i die hard Yeti fan... Forgot to mention would have been nice to put the pumpkin in the middle,just to change things up. Great job Axial.... Last edited by rustneversleeps; 10-09-2015 at 11:34 PM. Reason: info |
10-10-2015, 12:03 AM | #49 |
Newbie Join Date: May 2009 Location: CA
I for one am THRILLED with this new truck. For anyone that thinks this is going to be as nose heavy as the standard Yeti, you need to remember that this trophy truck version has the spare tire, cage, and full lexan body... most of which hang over the rear axle. This is going to create a lot of leverage (that the standard Yeti has none of which is why it bounces around at speed) and should keep that rear end planted. If not, you could easily add some weight inside the spare tire to give it the proper amount... i know I plan to experiment with this for sure. Not only is Axial's trophy truck badass, hopefully it's a sign of what's to come in this industry. Let's face it, the world has plenty of short course trucks already... it would be nice to have some trophy truck variety! I plan on preordering this trophy truck as I have wanted a production based truck like this for years with the solid rear axle. I am also very happy Axial used the existing Yeti platform. Not only will parts be readily available, but those of us that have Yetis already will easily be able to turn them into trophy trucks. I would much rather have a Yeti trophy truck than a regular Yeti... I know they have separate uses but still.. the Trophy truck is badass. Cant Wait! |
10-10-2015, 01:59 AM | #50 |
Pebble Pounder Join Date: May 2014 Location: Floriduh
I got the XL over the standard Yeti. This truck, or kit form (retro body you say) shall see this platform become a member of my stable for sure. I really want to see what my racer friends can do with a scaled out trophy truck against run of the mill SCTs at the track!
10-10-2015, 02:24 AM | #51 |
Seems there is a new 2.2 Walker Evans wheel AX31326 as well...
10-10-2015, 06:14 AM | #52 |
Quarry Creeper Join Date: Oct 2014 Location: Boston
Preordered mines.
10-10-2015, 06:32 AM | #53 | |
Pebble Pounder Join Date: May 2015 Location: UK
10-10-2015, 07:40 AM | #54 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
I was thinking same old stuff, but after reading this, I see people have some real good points about the truck. Glad to see the excitement out of some people and the fire to defend axial for doing minimal in upgrades. But that being said I would like to see a little more creativity out of that elite company. I Really enjoy driving my yeti,and people will enjoy this to |
10-10-2015, 09:34 AM | #55 |
| Re: Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR they should have done a full cage or no cage . that stuff they bolted in the back of the body is going to rip it apart after a few crashes . then people will be driving a sc truck around with no body and just a spare tire mounted on the back . the sc theme is gone then . i have a sc8 with full cage it does help . you say disposable . i say expensive . when they did the yeti cage they got it wrong to i think . they mount the cage to the chassis in the back and up front they mounted it to the lex on body then the chassis . they should have mounted it to the cage up front and then to the chassis like they did on the back .
10-10-2015, 10:59 AM | #56 | |
Quarry Creeper Join Date: Dec 2013 Location: Atlanta
10-10-2015, 11:06 AM | #57 |
Rock Crawler Join Date: Dec 2013 Location: Norway
For those who wants more weight in the back, put some brass beef tubes in the rear axle. Or change it to a heavier axle. Sent fra min HTC One via Tapatalk |
10-10-2015, 11:15 AM | #58 |
Cage or not cage, body breaking or not I'm totally getting at least the "conversion kit" for my Yeti. Maybe even get a full Kit when they release it. Yeti it's so much fun in a truck. |
10-10-2015, 11:55 AM | #59 |
Newbie Join Date: May 2015 Location: USA
Anyone know of the wheelbase is the same as the regular Yeti? Would be nice if it was shorten to fit existing short course bodies. Sent from my iPad using Tapatalk |
10-10-2015, 12:10 PM | #60 |
Quarry Creeper Join Date: May 2013 Location: no-water-no-trees-country
Maybe they did just half a cage with spare tire in the back because of the balance. I know, an entire cage wouldn't add that much weight to the front, but on the other hand every ounce counts. My crawlers don't have a roll cage and took some mighty rolls and drops without breaking. In fact, the SC8e body I used on my Yeti is so tough, I went through two pairs of lexan scissors to cut out the windows. That thing is not going to break. And last but not least: This is meant to be a "scale" trophy truck meant to be racing out in the desert not in a circle like a short course truck - they drive on flat dirt with only a few bumps and jumps. Maybe you should get a Slash if you want to compete against others on a track... I do like, that Axial is doing this. There will be plenty of fans and aftermarket parts in the future - just like there is now for the original Yeti. |
Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR - Similar Threads | ||||
New Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR | DenisLM | Axial Yeti | 2 | 10-09-2015 11:56 AM |
Axial Racing - Yeti™ 1/10th Scale Electric 4WD - Kit | Jeff True | Maine | 0 | 12-01-2014 01:18 PM |
In Stock! Axial Ram Power Wagon 1/10th Scale Electric 4WD - RTR | RPP Hobby | RPP Hobby | 0 | 09-25-2014 11:31 AM |
Axial SCX10 2012 Wrangler Unlimited Rubicon 1/10th SCALE ELECTRIC 4WD - RTR | RPP Hobby | RPP Hobby | 32 | 01-19-2013 08:19 AM |
