Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR
Old 10-10-2015, 12:27 PM   #61
Default Re: Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR
I'm going to add(I'll figure a way if not a direct fit) that rear cage to my existing Yeti with my current spare(2.2 vanquish slw wheel, 1.9 Tepador tire). Ive been wanting to set my spare back and down some. Thanks Axial, spot on!
KRAWL is offline   Reply With Quote
Old 10-10-2015, 12:45 PM   #62
There is a "fuel cell" on the chassis, which should be a weight box since the Rx has its own watertight box in the tub, correct? I know hardcore dudes are gonna be mounting up SSD and Currie axles on the rear, that should help out with the weight. The body does seem a bit floppy, but that is my only real complaint from the running video they posted. People seem to hate all over Axial and their licensing and releases but I bet playing by corporate rules with licensing and dealing with the vendors that manufacture and supply their parts and dialing those in proper takes time and money. I
Dextroyer is offline   Reply With Quote
Old 10-10-2015, 12:58 PM   #63
Oh I'm sure the licensing was a nightmare. I knew this rig was coming as soon as they signed with SCORE.
So I guess the main question arises now: Will there be a SCORE type race series coming soon??
JRapid is offline   Reply With Quote
Old 10-10-2015, 01:47 PM   #64
Im Brandon
Brandon's Avatar
Originally Posted by mugenteg View Post
Anyone know of the wheelbase is the same as the regular Yeti? Would be nice if it was shorten to fit existing short course bodies.
The wheelbase is the same as the Yeti, body is longer (compared to SC bodies). Much better proportions this way. In addition, shortening the rear links would have hurt the performance.
Brandon is offline   Reply With Quote
Old 10-10-2015, 01:50 PM   #65
I really like the body curious about the retro body listed on the manual and those 2.2 KR2s...
fr8cture is offline   Reply With Quote
Old 10-10-2015, 03:12 PM   #66
Originally Posted by fxman View Post
Maybe they did just half a cage with spare tire in the back because of the balance. I know, an entire cage wouldn't add that much weight to the front, but on the other hand every ounce counts. My crawlers don't have a roll cage and took some mighty rolls and drops without breaking. In fact, the SC8e body I used on my Yeti is so tough, I went through two pairs of lexan scissors to cut out the windows. That thing is not going to break.
And last but not least: This is meant to be a "scale" trophy truck meant to be racing out in the desert not in a circle like a short course truck - they drive on flat dirt with only a few bumps and jumps. Maybe you should get a Slash if you want to compete against others on a track...
I do like, that Axial is doing this. There will be plenty of fans and aftermarket parts in the future - just like there is now for the original Yeti.
the spare tire is just going to raise the center of gravity . that's not a real fix for a car that jumps noise down . I hope you did not buy the same scissors the second time . lol !!
nickyszoe is offline   Reply With Quote
Old 10-10-2015, 10:32 PM   #67
I was wondering for wheels as I like the green and blue color scheme and was wondering would 1.9 methods look good and work better for this one? I'm thinking about ordering some goodies and getting it
Mitchell72 is offline   Reply With Quote
Old 10-10-2015, 10:37 PM   #68
anyone know of the wheelbase is the same as the regular yeti? Would be nice if it was shorten to fit existing short course bodies.
Sent from my ipad using tapatalk
14.25 360mm
rustneversleeps is offline   Reply With Quote
Old 10-10-2015, 10:44 PM   #69
Originally Posted by bpare207 View Post
I just saw this on my FB news feed, this is wicked! It's basically a 1/8 scale solid axle trophy truck right?
No 1/10 scale
Sent from my SM-N910P using Tapatalk
Blazer72 is offline   Reply With Quote
Old 10-11-2015, 08:13 AM   #70
Originally Posted by rustneversleeps View Post
14.25 360mm
Also it wouldn't take much to shorten the wheel base just use shorter rear lower links....
Old 10-11-2015, 07:51 PM   #71
So if it uses the stock flip back mounts for the rear, in theory it should also be a good body for scx10 builds as well.
I'd like to see it draped over a wraith in the near future also.
klampykixx is offline   Reply With Quote
Old 10-11-2015, 10:16 PM   #72
Question Re: Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR
Anyone know if the rear diff is locked or not?
BigStick is offline   Reply With Quote
Old 10-11-2015, 10:56 PM   #73
AR60 axle so yeah it's locked up.
FloridaCrawler is offline   Reply With Quote
Old 10-12-2015, 12:02 AM   #74
Originally Posted by Blazer72 View Post
No 1/10 scale
It says 1/10th but it's way closer to 1/8th . I even had to use a 1/8th scale body ( associated sc8 ) on my project .
sb4pro is offline   Reply With Quote
Old 10-12-2015, 12:03 AM   #75
Cool
Old 10-12-2015, 07:48 AM   #76
I think it's inevitable that we'll see an XL version in the very near future. I was really hoping/assuming their next release was going to be a scale, solid axle monster truck.
chino is offline   Reply With Quote
Old 10-12-2015, 08:59 AM   #77
ACR
As a test, I used the body of the Traxxas Slayer Pro 3.3 also fits the Yeti.
ACR is offline   Reply With Quote
Old 10-12-2015, 09:27 AM   #78
Originally Posted by fr8cture View Post
Since day one everyone was saying the yeti was the perfect platform for a TT and now that they did it everyone complains? I don't get it. Ask and receive and then complain? So there has been alot of talk about a Axial MT if they come out with one is everyone gonna complain because it shares parts with another axial or Oh its just a wraith with a tube chassis?
The trophy trucks I worked on were all two wheel drive with a lot of wheel travel. This is neither, I think axial could have done something special with this and made a true trophy truck. instead it's a yeti with a different body and sct tires and wheels.
Cork is offline   Reply With Quote
Old 10-12-2015, 09:29 AM   #79
I was thinking about this a bit ago. Can you imagine the fit people would throw if they came out with a real 2wd trophy?
Truck looks awesome though will be picking one up "for the kid" lol
adamargue is offline   Reply With Quote
Old 10-12-2015, 09:53 AM   #80
Hey Casey Currie said it drives realistic.
Sent from my VS986 using Tapatalk
Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR - Similar Threads
New Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR DenisLM Axial Yeti 2 10-09-2015 11:56 AM
Axial Racing - Yeti™ 1/10th Scale Electric 4WD - Kit Jeff True Maine 0 12-01-2014 01:18 PM
In Stock! Axial Ram Power Wagon 1/10th Scale Electric 4WD - RTR RPP Hobby RPP Hobby 0 09-25-2014 11:31 AM
Axial SCX10 2012 Wrangler Unlimited Rubicon 1/10th SCALE ELECTRIC 4WD - RTR RPP Hobby RPP Hobby 32 01-19-2013 08:19 AM
