11-10-2015, 06:20 PM | #21 | |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
| Re: Imaguy unboxes the Axial Yeti Trophy RTR Quote:
Sure does. All stock electrics from the RTR, no tricks other than great driving. | |
11-10-2015, 06:22 PM | #22 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
Saw one in person at Sema last week, solid truck!
11-10-2015, 06:24 PM | #23 |
Hows the new tire compare in height to the stock yeti tire?
11-10-2015, 07:46 PM | #24 |
| Re: Imaguy unboxes the Axial Yeti Trophy RTR |
11-10-2015, 07:50 PM | #25 |
11-10-2015, 08:37 PM | #26 |
Goodness those are tiny. Good to know
11-11-2015, 05:54 AM | #27 |
11-11-2015, 06:54 AM | #28 |
The tires off the bomber (same bfg as these) will be good for the normal yeti or c3 rig. |
11-19-2015, 02:21 PM | #29 |
Rock Stacker Join Date: Mar 2014 Location: North Bay
Saw the running video last night and I am soo happy that there is finally a real Scale Rc Trophy that can be made even more awesome by the Aftermarket Companies. I have my fingers crossed that someone (vanquish or Rc4wd) will do a Hardcore axle Version 2.0 to add that extra touch of realism. Sent from my LG-D852 using Tapatalk |
11-19-2015, 02:37 PM | #30 |
The Currie F9 Wraith width will be an excellent replacement when it comes out - and what I'll be going with.
11-19-2015, 03:24 PM | #31 |
Rock Stacker Join Date: Nov 2014 Location: Massachusetts
appears to do good doughnuts.. even for a TT it seems rater wide though |
11-20-2015, 07:52 AM | #32 |
11-22-2015, 02:07 AM | #33 |
Newbie Join Date: Jul 2015 Location: Bacchus Marsh, Australia
Cool video and that body does look nice
11-23-2015, 08:24 AM | #34 | |
Rock Stacker Join Date: Jun 2015 Location: SoCal
Edit: whoops I didn't see the post about the preload Last edited by totallypro; 11-23-2015 at 08:27 AM. | |
11-23-2015, 08:36 AM | #35 |
| Re: Imaguy unboxes the Axial Yeti Trophy RTR Yeah, it's pretty slick. I'm adding more stuff to add some more realism. Preload Preload Preload. Stiffer oil might help too. I've got a few extra long shocks sitting around and I'm going to play with that as well. Cyconxc's stuff got me hyped to try and make this truck handle even better than it already does. |
11-23-2015, 09:04 PM | #36 |
11-26-2015, 08:51 AM | #37 |
Newbie Join Date: Dec 2014 Location: NY
Thanks for the write up. Just got a good coupon from Tower. Time to order one up! Any pics with the lights on? |
11-26-2015, 09:03 AM | #38 |
11-27-2015, 02:34 PM | #39 |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: Imaguy unboxes the Axial Yeti Trophy RTR Ditto this post. Rear needs more spring. Would you be so kind as to treat us to another, running through rougher terrain, I.e. ruts and rolling jumps? |
12-13-2015, 05:46 PM | #40 | |
A small update. More lights! A new GearHead long light bar with some green LED accents. Seemed fitting for the color of the truck. I also added some RC4WD Baja lights in the headlight pods. I like the multiple bulb look. GCM's mini bar looks great in the front grille. Everything is firmly mounted and will hopefully stay put. I added a couple antennas on the top to add a smidge more realism as well. Mounted them with some rubber grommets so they'll bend and not crack the body in a rollover. Some steel trailing arm reinforcements and more shocks. No springs, just looking to dampen things a bit more. Hoping this will bias the weight more towards the front of the truck. Diff protection. Some limiting straps to limit the amount of fun I'm having. It's working. | |
Imaguy unboxes the Axial Yeti Trophy RTR - Similar Threads | ||||
Finally - a 1/10 trophy truck built in the axial yeti | joerc2013 | Axial Yeti | 169 | 10-04-2016 05:44 PM |
Axial AX90050 Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR | Brandon | Axial Yeti | 269 | 07-30-2016 08:20 AM |
New Yeti™ SCORE® Trophy Truck® 1/10 Scale Electric 4WD – RTR | DenisLM | Axial Yeti | 2 | 10-09-2015 11:56 AM |
