02-28-2012, 07:13 AM | #21 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* THIS is what I like from my first run with the closed cell inners! . You an actually feel the outer foams when squeezing the tires.
02-28-2012, 07:21 AM | #22 |
One video of the foams running Khaos-Rovers (almost 2 year old tires). Soft outers up front and medium inners out back. Closed cell narrow inners all around. 5.5" setup 1 inch wide wheels. Truck is 5lbs 4 oz, rtr. As you all know some of the benefits inlcude reduced bounce, better sidewall support and improved forward traction. Last edited by Szczerba; 02-29-2012 at 12:50 PM. |
02-28-2012, 07:52 AM | #23 |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* |
02-28-2012, 08:35 AM | #24 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* What caused you to try that? And now that you've stayed with it, what do you find for pros and cons?
02-28-2012, 08:43 AM | #25 |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Not at this time. Some details here. Post 170 on last page. Was mainly for weight reduction. Crawler Innovations Khaos-Rover Comp Tire |
02-28-2012, 09:08 AM | #26 | |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Quote:
02-28-2012, 02:02 PM | #27 | |
Rock Crawler Join Date: Feb 2009 Location: LaGrange
you wont be sorry , these foams are so consistent at how they work ...no more hopping once i put these in my tires ....thanks Eddie for another great product | |
02-28-2012, 04:46 PM | #28 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
Question for those guys running weight inside the wheels. Are you channeling the inner foam??
02-28-2012, 05:01 PM | #29 |
02-28-2012, 06:03 PM | #30 | |
Ok, thats what I was wondering, I used to run the Mayhem Ultimate Comp wheels with that large support ring on my old Novas. I used to channel the inner foam to go around the support. I just wasn't sure if I should just leave the foam alone on these or groove them out a bit so the foams can do their job without the weights pushing out on them. Thanks for the advice Shane!! | |
02-28-2012, 06:09 PM | #31 | |
You can channel, or you can drill holes like Krawlfreak did in his latest XR10 build. | |
02-28-2012, 06:17 PM | #32 | |
02-28-2012, 07:11 PM | #33 |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Don't worry about that, just make sure to drill the holes small enough for a press fit. The slugs are a great idea. I was thinking about picking some up but regular lead weights work well too.
02-28-2012, 07:35 PM | #34 |
DH or little harry weights may be an option as well.
02-29-2012, 08:07 AM | #35 | |
The new inners helped a lot with this...A LOT, but I still prefer a firmer outer ring. I will say that I will run a Medium outer in the rear to break it in before running it in the front. A "new" Medium outer is too firm for what I'm looking for, but one with a little run time on it works much better. I ran my rig last night with the skinny Khaos tires with the new inners and a soft outer with a medium outer tuning ring and so far they seem to be working the way I want them to. They're slightly softer than the medium outer by itself. | |
02-29-2012, 10:06 AM | #36 |
what is the actuall width measurement of the narrow and wide inner foams? and would you recomend the 5.5 or 6.0 for the new 5.75" Iroks? |
02-29-2012, 12:29 PM | #37 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
It seems the current trend for most is soft front with medium rear. I'm going to use Sedonas on 1.35" Vanquish SLW wheels and also ahevRovers on 1" SLW's. The Bully currently weighs 5.8lbs but would be lighter soon. (say 5.5lbs) Would the soft/firm be correct for both tyre wheel combinations? Thanks Rudolf |
02-29-2012, 01:00 PM | #38 | ||
Do not quote me on that ! I bought some of the 6" setup inners for the 2.2 Two-Face tires but sold the tires before I mounted them up. I am not sure. Eddie can chime in on that setup probably. Quote:
When I ran sedonas, I ran soft up front with a med outer and firm outer tuning ring. Here is soft front / med with medium outer tuning rings in rear on a 5lbs 2oz clapped rover sportsman. Closed cell inners, of course. ARCC SZCZERBA SPORTSMAN COURSE 1 - YouTube I would say start with the soft front and med rear and get a few pairs of medium and firm outer tuning rings to adjust to your liking. I like a soft front outer foam on all my rigs. and med-firm rear tire setup. That is just me. The firm outer foams are pretty firm (not the tuning rings). But I do have some in my foam arsenal though. Last edited by Szczerba; 02-29-2012 at 01:04 PM. | ||
02-29-2012, 01:56 PM | #39 |
Quarry Creeper Join Date: Sep 2010 Location: too close to LRC.... Jealous????
I recieved my set of 5.5s last week as well....mounted them in ripsaws on a set of mayhem wheels, cant get them to stay seated in the bead, but i will say for an all around speed, crawl, bash rig they did great and dont fold under speed! I cant wait for the 1.9s to come out...and an tips on successfully mounting these would be great! sent from my damn phone |
02-29-2012, 02:25 PM | #40 | |
-Install the ring and screws to the wheel with tire and foam but only tighten them enough to where the ring and screws don't fall out *try a little dab of shock oil on your finger and rub it around the tire bead OR bead lock channel -Set the wheel and tire on a small jar, such as a artichoke heart jar. Whatever you pick out needs to be about the same diameter or smaller of your 2.2 wheel. -Push down on the tire evenly as it sits on the jar (the jar keeps the wheel in place but the small diameter allows for the tire to stretch down) This will stretch out your tire but in a downward motion making it easier to seat that bead. It works like a charm with my closed cell inners and my Mayhem Evo beadlocks | |
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* - Similar Threads | ||||
Double Deuce foams for HB Rovers on XR10? | Rock Spider | Axial XR10 | 6 | 06-01-2011 04:49 PM |
Deuce Nova's and Lil Nova's Dual stage foams! | bigflex | Tires and Wheels | 6 | 10-06-2009 10:50 PM |
