05-07-2009, 06:59 PM | #101 |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
What guage wire have you guys been using to wire up the dig? I usually use 12 guage but the wire does not seem to fit.
05-07-2009, 07:22 PM | #102 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
05-07-2009, 07:42 PM | #103 |
05-08-2009, 07:40 AM | #104 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
14 gauge is fine for our trucks. I used to use 12ga on the switches, but with 14ga now on the dig switch I notice no difference. I bet if you could solder very very expertly you could get 12ga to fit... |
05-08-2009, 07:47 AM | #105 |
05-08-2009, 07:58 AM | #106 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
Big Bear fit 12g is his, and he's no expert Just giving you a hard time Mike I've been running 14g. |
05-08-2009, 08:13 AM | #107 |
Pebble Pounder Join Date: Apr 2005 Location: Destination Hobbies, Ut Where The Fun Begins...
| There is no problem running 12 gauge if you are carefull. The wires don't have to pass trough the hole. They just need to be solid on the board. After soldering on the one side I simply turned it over and filled solder in from the back side to insure a solid joint. That being said I don't think you need to run 12 gauge for any reason it is just what I had on hand at the time.
05-08-2009, 08:18 AM | #108 | |
05-08-2009, 08:24 AM | #109 |
Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
anyone have a delay between switching from a dig position to 4wd?
05-08-2009, 08:27 AM | #110 |
RCC Addict Join Date: Dec 2007 Location: Ward, SC
Wired mine up last night. Ran out of 14AWG... so it has 14 to the motors and 12 to the ESC; works like a charm. BTW I am no soldering expert at all..
05-08-2009, 08:28 AM | #111 |
05-08-2009, 08:42 AM | #112 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
05-08-2009, 08:58 AM | #113 |
05-08-2009, 09:30 AM | #114 |
05-08-2009, 09:35 AM | #115 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
I got mine in the mail and tonight on RCCtv we will be installing it and testing it throughly Last edited by Mr Glassman; 05-08-2009 at 11:54 AM. |
05-08-2009, 05:40 PM | #116 |
just ordered mine off punkrc.com, can't wait!
05-09-2009, 07:13 AM | #117 |
What a great product I can now say that micro switches are so last year! To all that was watching last night on RCCtv I found the problem with the radio not operating the switch on model 1. It was set at 5.5 frame rate and after I switched it to 11 it worked flawlessly! Taking it to a local comp today I will update on it's performance! |
05-09-2009, 07:43 AM | #118 |
Rock Crawler Join Date: Apr 2006 Location: I hope you SHUT UP!!!
I just ordered one as well! right now my switch setup works great, hopefully this one is even better! thanks punkrc! |
05-09-2009, 09:52 AM | #119 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
Got mine ordered up as well. I am just getting all the parts for my miniclod build and I think this will be a great addition. Now once everythiing gets hear I can start my build thread. |
05-09-2009, 11:49 AM | #120 |
Rock Crawler Join Date: Aug 2008 Location: Alamogordo
Its the 9th! Mine should ship today!
