02-01-2012, 02:51 AM | #1801 |
Rock Crawler Join Date: Oct 2007 Location: south of France
| Re: Futaba 4PL Setup, Tips, Tricks & Help
I have some trouble w/ my rear motor (XR w/ brood motor) I add some capacitor on the motor, but glitch is still here... and I have some trouble w/ my servo, can't have the ful travel even w/ EPA to 120.... |
02-01-2012, 06:57 AM | #1802 |
02-01-2012, 07:00 AM | #1803 | |
Servos don't go full physical travel, it's not in their design. | |
02-01-2012, 08:22 AM | #1804 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Full travel on the servo (most are 90* stock) or full travel on the steering? If you mean steering, a longer servo arm may help but will also drop torque to the wheels.
02-01-2012, 12:00 PM | #1805 |
thanks for your answer Harley, do you mean motor or ESC when you say "power" for the servo, I'm using 7980 programmed by HP21+ so I have 180° on the paper and I can't use a longer servo arm cause I made the Egressor mod on the steering... the servo don't go full travel and the steering don't go as far as it possible but except this I'm really really happy w/ my 4PL sorry if my english is not clear |
02-02-2012, 12:01 AM | #1806 |
Quarry Creeper Join Date: Sep 2007 Location: Near my tools
Hi, just a quick question. I have set my 4PL failsafe, but it's only out just 75, I have saw somewhere and it can out 100. Just wondering if how I set the failsafe is right or not...so i hold + and -, then simultanously give throttle to the brake side, is that correct? |
02-03-2012, 11:43 AM | #1807 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
Quick question, Got my 4PL set up for 4WS following Harley's video and it works great, the only thing I need to know is can the order be changed up on what happens when I hit the button? Starts out in FS only, click once it goes to crab walk,click again and you get 4WS, click again and then rear steer only. I would like to change the order in which these come up. 1st front steer only,2nd 4WS, 3rd rear steer only and 4th crab walk. Is that possable? |
02-03-2012, 12:14 PM | #1808 | |
02-03-2012, 11:23 PM | #1809 |
Rock Stacker Join Date: Feb 2006 Location: Brisbane, Australia
| Re: Futaba 4PL Setup, Tips, Tricks & Help I have just picked up a 4PL and it has a serial no of B10200249 and it looks like it hasn't been updated.
02-04-2012, 12:42 AM | #1810 | |
Newbie Join Date: Aug 2011 Location: thailand
| Re: Futaba 4PL Setup, Tips, Tricks & Help Quote:
02-04-2012, 01:42 AM | #1811 |
Another question,thank for information that Futaba R2106GF is compatible with 4PL. It"s a cheap small air receiver, for in door flying. How to connect channels , channel 1 for steering and 2 for esc , the same as surface receiver?.........thanks
02-04-2012, 06:46 AM | #1812 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Yes, same as surface radio.
02-04-2012, 11:47 AM | #1813 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Why not just set one of your Dt buttons to 3 positon,assign a channel for it,plug your rear steer servo into that channel set you endpoints and your done. You will have total control of the steering and can make it do anything you want with one switch. I use one of the lower switches above the throttle. One is my winch the other is my rear steer, you set the winch and steering servo up exactly the same other than end points. No need to reverse order since you have total control over which way the rear wheel turns with that 3 pos switch Quote:
02-04-2012, 12:32 PM | #1814 | |
02-04-2012, 11:18 PM | #1815 |
Yeah, I forgot to add you can add the steps into the set up. I guess it works well for me under all conditions since I used to drive supers and am very comfortable in any situation with this set-up. Thats the nice thing about the 4pl, it is so versital for all users |
02-05-2012, 12:20 PM | #1816 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
Is there any way to make it so that if you have 2 trucks on that are bound to your radio, that both trucks dont do the exact same thing. Heres and example. i can leave on of my scale trucks on and turn anohter one on and when i go to drive it they both go. I thought that if a friend and i had bound are radios to eachothers trucks so we could switch trucks that it shouldnt do that right?(they both dont just follow one radio). I hope that all made sense, so i gess my question is can you make it so only the modle that is bound to the truck can run it? |
02-05-2012, 12:37 PM | #1817 |
Nope, unlike Spektrum who has model recognition Futaba doesn't. You can bind several models (RXs) on one 4PL model selection and send signals to all but not to a model bound to another TX.
02-05-2012, 12:41 PM | #1818 | |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
02-05-2012, 01:08 PM | #1819 | |
02-05-2012, 01:16 PM | #1820 | |
Edit: Think I found it, is it the r2006gs, r2106gs, r203gf and r204gf rx that works fine for 30ish?, seems like it should as they are s-fhss. Edit 2: Looks like the r2106gs is the one to get, is the range the same as the 2104gf? Last edited by kurtus; 02-05-2012 at 01:40 PM. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
