05-15-2012, 11:04 AM | #1901 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help |
05-15-2012, 09:46 PM | #1902 |
Newbie Join Date: Jun 2010 Location: seattle
sorry if this was already covered, how do you adjust the neutral point for the throttle on channel 4 ? my 2nd esc isent arming, im running dual esc mod. thanks
05-15-2012, 10:38 PM | #1903 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help You need to program the throttle position on the ESC first. That most likely your issue. Otherwise you can adjust your sub trims, but the ESC MUST BE SET CORRECTLY.
05-18-2012, 07:32 AM | #1904 |
If anyone is wanting to put a VP 1.9 on their radio (4PK or 4PL) let me know. I banged out a handful of adapters last night. I don't plan on offering these for very long. I was just testing out the mill setup last night. Email me for pricing. Uses the stock wheel's foam. 2 piece setup. you have to drill and tap the larger piece. All holes are spotted .050" deep already so there is no guessing. Super easy. |
05-28-2012, 08:01 AM | #1905 |
Quarry Creeper Join Date: Jan 2010 Location: Pennington NJ
Quick question on the SW1-PSH push button. Is there a way to make it set the rear bias to 100 on push? I have DL1 set to dial the rear bias back on 2% increments. It would be great to reset it to 100% with a single push.
05-28-2012, 10:05 AM | #1906 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help I do not believe so. However I suggest changing your basing to 10% increments. You should never be more then 2 or 3 pushes away from 100% then. There is no reason to adjust by 2%. I have set up 100's of these setups, including most the top drivers in the US.
05-28-2012, 11:29 AM | #1907 |
Thanks Harley. I have a DT set to 10% increments which is what I use most of the time. Just wanted to see if this was possible.
05-28-2012, 11:40 AM | #1908 |
06-03-2012, 12:41 PM | #1909 |
Rock Crawler Join Date: May 2011 Location: SoCal
Harley, a friend thought he had seen a video from you which updated options for MOA button setups. In particular adding a "return to neutral" command for both bias and dig, perhaps on the lower push button. Mine is still set up with the upper DT 1 & 2 buttons per your early video and I'm thinking that there must be a better way. Like changing to DT 3 & 4 and adding that "cancel" button mentioned above. Strike a chord? Or maybe that was someone else's video. You mentioned you set up a lot of radios for the top guns. What's their favorite switch layout? |
06-03-2012, 02:30 PM | #1910 | |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Quote:
06-03-2012, 03:42 PM | #1911 |
06-03-2012, 03:49 PM | #1912 | |
So unless it's only a return to 100% then I see no possible way. If its just a return then a simple DT set to 2p should work. It's not something I find called for. Rarely do I see any drivers that have been running for very long any further then 2 or 3 clicks off 100% on course. | |
06-09-2012, 01:32 AM | #1913 |
Pebble Pounder Join Date: Feb 2012 Location: NTG Racing - San Diego
Harley, have you had a chance to try out a R204GF-E and a R203GF? I seen a few post on the use of the R203GF but nothing on the R204GF-E. I have looked at the specs for all five receivers: size, voltage operation range, channels and "ms" (???). The only things that stood out from all the specs was that the 204 is the smallest of them all and has an internal antenna, the 2104 is the only one rated for 3.5-8.4V and the others are 4.8-7.4V. I'm getting ready to order my 4PL and would like to order a few more receiver to take advantage of my discount but would like to be able to hear from some one who has actually had a chance to compared them instead of just going on specs alone.
06-09-2012, 08:39 PM | #1914 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
Im planning to get a Heyok winch controller and would like to know if the 4PL has a 2 position or a 3 position 3rd channel?
06-09-2012, 08:46 PM | #1915 | |
06-09-2012, 08:48 PM | #1916 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help It is covered in this thread on how to program it, see the first post. The 3rd and 4thvchannels can be see to be 2, 3, 5, 10, 20, etc. It works fine for the Hayok controller.
06-11-2012, 10:49 PM | #1917 |
Newbie Join Date: Aug 2010 Location: Boise
Thanks to all for your posts on the 4PL. I just bought one. |
06-14-2012, 02:19 PM | #1918 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
Hey Harley, I got a strange issue with my 4PL. At some point recently, my transmitter is powering up with the third channel actuated. In my case, this is for my winch so unless I flip the switch to put Ch 3 in neutral, it'll power up my winch as soon as I power up the truck. But I can't figure out why it's doing this. Maybe you can help a brotha out? Here's some images that may be helpful... |
06-14-2012, 02:22 PM | #1919 | |
I'm thinking it could be the fail safe. Another simple fix, start a clean model and give it a shot. | |
06-14-2012, 02:54 PM | #1920 | |
Thanks, man! I hope Futaba realizes how much you help their customers. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
