01-13-2014, 05:22 PM | #3321 |
Pebble Pounder Join Date: Aug 2012 Location: Australia
| Re: GT3B Hack Question and Answer Thread Sorry I can`t help you with that one.
01-13-2014, 05:24 PM | #3322 |
Pebble Pounder Join Date: Sep 2013 Location: Portugal/Lisboa
| Re: GT3B Hack Question and Answer Thread |
01-16-2014, 01:01 AM | #3323 |
Pebble Pounder Join Date: Mar 2013 Location: yucca valley,
sorry for the newb questions you guys. i just bought a gt3b; long story short this is my first aftermarket radio and the reason for purchase is because of? you guessed it; a winch control. currently running no lights so ill just have esc bec and servo and now a winch. does this stock; have a 3 pos swicth?i read around the thread and read you can with the dial trims?
01-16-2014, 02:27 AM | #3324 |
Also will ill be able to run power to the rx from the esc running 2s and 3s? Or do I need an external bec to power the rx. Thanks
01-16-2014, 04:03 AM | #3325 | |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
Sent from my iPhone in the shop | |
01-16-2014, 04:43 PM | #3326 |
Is the gtb have a 2 pos swicth or 3 position? Need to kno which winch controller from heyok to get.
01-16-2014, 04:46 PM | #3327 |
Quarry Creeper Join Date: Jun 2010 Location: Carson City, NV
01-16-2014, 05:19 PM | #3328 |
Thanks! Now obout this hacking what is it regards to like, removing butons installing aftermarkets, sodering and what not? Im more interested and hacking it for a 4 batt modd or single lipo pack? Totally newb but have some soldering skills and of course; common sense
02-03-2014, 01:01 PM | #3329 |
Hi I found this 3,7 6000ahm lipo, would it work on the flysky GT3b our the GT3c, if it will work its just plug and run, our wont it work? https://www.mikrocontroller.com/inde...96&language=en |
02-03-2014, 01:24 PM | #3330 |
Rock Stacker Join Date: Dec 2012 Location: Slovakia
Yes, you can use it but only with GT3C. GT3B needs at least 2S LiPo |
02-03-2014, 01:40 PM | #3331 | |
| Re: GT3B Hack Question and Answer Thread Quote:
Heres another and cheaper botnroll.com - Loja Online Just have one doubt, getting one of this li-ion since it has more mAh could it be charge still in the radio like the normal li-ion that comes in the GT3C our does it need to be tcharge another way? Last edited by PSH72; 02-03-2014 at 01:43 PM. | |
02-03-2014, 02:00 PM | #3332 |
I assume that you can charge it in GT3C but I don't know nothing about charging current of GT3C, it can be small (my guess is cca 500mA) so charging time of new battery can be veeeery long Last edited by IQLogic; 02-03-2014 at 02:08 PM. |
02-03-2014, 02:10 PM | #3333 |
The GT3C comes with a USB cable to charge on the PC, so I think that its just like a normal li-ion like the mobiles, and mayby can be charge in normal corrent.
02-03-2014, 02:16 PM | #3334 |
Pebble Pounder Join Date: Feb 2013 Location: Fresno
a GT3B with the works done to it will have 6 channels correct? 1 for the steering, 2 for the speed control, 3 aux - Now with the 4th-6th channels, will there be added switches to the controller? |
02-03-2014, 02:47 PM | #3335 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
^yes, the hacked GT3B will get you 6ch to play with, even 8ch i believe. no, there won't be any physical changes to the controller in regards to switches unless you do that yourself. the hack kit lets you individually program what all the buttons do, so it's up to you how the buttons function. I just received my hack kit in the mail but wasn't able to buy any receivers at the same time due to them being out of stock. I looked up and found the list of compatible receivers. Looking for an alternative to HobbyKing, I found some Turnigy 9x receivers on eBay -- will I have any problems getting one of these to work? Turngy RX-9X8Cv2 I thought I read those will be fine, but just looking for confirmation so i can buy 2 of them. Thanks! |
02-03-2014, 03:21 PM | #3336 |
Newbie Join Date: Jan 2014 Location: Redondo Beach
This is the best replacement battery for the FLYSKY GT3C radio I know of. Goes from 800maH to 1200maH and only $11 shipped (slow boat from china). It's a direct replacement FS-BA1200 Lipo battery for FlySky iT4 Colour Touch Screen Transmitte - US$11.38 |
02-07-2014, 11:50 PM | #3337 |
Newbie Join Date: Sep 2013 Location: Phoenix / Glendale
Got my GT-3B hacked and configured. Looking forward to some drive time to see how I like it! Running Rear Steer on the D/R slider & Dig/bias via Dual ESC on Ch3 slider. Channel 3 button will reset dig/bias to 0. |
02-08-2014, 03:40 AM | #3338 |
Newbie Join Date: Jan 2014 Location: Ohio soon to be NC
Have a hacked GT3C, couldn't beat the price, I use it more than I use my Futaba now and couldnt be happier with it once i got the hang of programming it
02-08-2014, 05:44 PM | #3339 |
Well just resolved problem, but camed another . Now another problem, I instaled the ch6-0.1.0.s19 firmware, when setting the lower voltage on the instalation manual it says Step 8: This step is for firmware 0.6.1, possibly others. In 0.6.1, defaults are setup for the GT3B. To change the defaults, turn the radio off, then back on. Now press and hold enter for about 2 seconds (LONG-enter). This will open the global setup menu. Scroll until LOW POWER is blinking, press enter. scroll to 3.00v, press enter, scroll to H, press enter, scroll to E_R. press and hold enter for 1-2 seconds. This changes the low voltage alarm to 3 volts and reverses the scroll wheel so it acts normal. but I cant set it to 3.0v it only gets to 7.5v doesn't go down from that , and the it says scroll to H, only appears L,F,r,b has anyone had this problem, my radio is the GT3C but I think that is the same firmware used as the GT3B. Can someone give a help here please? Last edited by PSH72; 02-08-2014 at 05:56 PM. |
02-09-2014, 12:23 PM | #3340 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
Going through the thread trying to find a pdf I had on my other tablet. It was a quick guide type thing that gave you the definitions of each and rough setups. Anybody got it?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
