07-05-2014, 11:49 AM | #3521 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: GT3B Hack Question and Answer Thread
Losikid: Thanks! I bought the kit from you at Overkill RC. So the solder joints are unsoldered. Would you go back a page and take a look at my solder job on the TX Mother board? GT3B Hack Question and Answer Thread Maybe those aren't good? I am running Win 8 and will re-install both the software and the patch. |
07-05-2014, 12:03 PM | #3522 |
Program with the radio on or off?
07-05-2014, 12:08 PM | #3523 | |
| Re: GT3B Hack Question and Answer Thread Quote:
Its hard to tell from pictures, but I'd double check that the SB1 and SB2 solder joints were completely desoldered. You should see a "V" without any solder bridging over it. Off | |
07-05-2014, 12:09 PM | #3524 |
Also, as i mentioned in my reply email to you, windows 8 may be the culprit...but usually this error is because the procedure I outline in the install instructions isn't followed. http://www.overkillrc.com/GT3C/Insta...anual%20v0.pdf |
07-05-2014, 12:10 PM | #3525 |
Un installed all software. Re-installed all soft ware and re booted. Configured to ST-Link, USB, SWIM, STM8S105x6. Connected all wires and programmer before starting STVP. loaded the 6.1 software into STVP. Installed at 08000 and E70F Cannot communicate with the board. Wrong board selection, or Check board power supply or check that previous session is closed. |
07-05-2014, 12:17 PM | #3526 | |
Make sure the polarity of the 4 pin wire is correct on both sides. The radio should be Beeping during this process. (unless its been programmed before) | |
07-05-2014, 12:18 PM | #3527 |
Now getting a message from Windows 8.1 The last usb device you connected to this computer malfunctioned, and Windows does not recognise it |
07-05-2014, 12:53 PM | #3528 |
Does the radio beep when you plug it into the computer?
07-05-2014, 03:43 PM | #3529 |
There is a beep from the computer, but not the radio. There never has been a beep from the radio.
07-05-2014, 03:55 PM | #3530 |
Then there is most definitely a communication error (If the radio has stock firmware on it). Try flipping the 4 pin cable on one of the sides. |
07-05-2014, 04:02 PM | #3531 |
At n oth ends or just the end at the radio?
07-05-2014, 04:09 PM | #3532 |
Doesn't matter which side....just do it on one side though
07-05-2014, 04:49 PM | #3533 |
Losikid: if I can't get it to work would you want to take a look at it?
07-05-2014, 04:51 PM | #3534 |
Another question, will I have to re-bind yhe tx and rx after flashing?
07-05-2014, 05:00 PM | #3535 | |
If you're radio isn't beeping, and its the stock firmware. Then there is something wrong with your setup. Are there any lights on the programming board turned on when its plugged into the computer? Ensure that SB1 and SB2 are completely desoldered (see acouple posts above) Make sure your plugging the radio in correctly. The Long pins of the adapter need to be plugged into the 4 pin cable. The short pins go into the radio port. The green wire needs to be on the SB1 side of the programmer and the steering wheel side of the radio. | |
07-05-2014, 06:21 PM | #3536 |
What order to plug in? Adapter to radio, 4 pin cable to adapter, 4 pin cable to programer USB B to programer and finally USB A to computer
07-05-2014, 07:37 PM | #3537 |
That's right
07-05-2014, 07:39 PM | #3538 |
I can sit here and answer your questions and probably take alot longer to get to a conclusion. Or you can answer my questions and we can get to the issue awhole lot faster.
07-05-2014, 09:56 PM | #3539 |
OK, The USB port on the computer is good as I can transfer data from my phone to the computer and use a Castle Link to program my ESC. When setting up SVTP, I was told that parallel port wouldn't work because the ports were not active on my computer. But I am trying to program through USB, not Parallel port I am not getting a beep from the radio. The only beep is windows when something plugs in to the USB port. I scraped off both SB1 and SB2, no solder on them. No lights on the programming board when plugged into computer. I tried both ways Green wire to steering wheel side and green wire to antenna side. I even took out the battery pack from the radio and still no luck I get the same messages as posted above. Board not communicating, then windows doesn't recognize the device plugged into the port. Maybe the setup program problem? Bad Programmer board? No lights what so ever when it plugs into the port. Do I need to break the board in two? I have read older posts where they were told to break the boar in two. Last edited by DrDiff952; 07-05-2014 at 10:58 PM. |
07-06-2014, 12:10 AM | #3540 |
Don't break the board in two Did the lights on the programming board light up before you re-installed stvp? (Before windows didn't recognize the device) It sounds like you have a bad programmer... |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
