11-05-2016, 09:42 PM | #4501 |
| Re: GT3B Hack Question and Answer Thread
Hey everybody. I finally got started on the key mapping documentation for my websites knowledge base. Hopefully this will help guide ya'll through setting up your switches http://overkillrc.com/php?target=sup...17-key-mapping http://overkillrc.com/php?target=sup...y-mapping-menu I'll try to add the documentation for button type keys here sometime in the next week Last edited by losikid; 11-05-2016 at 09:45 PM. |
11-23-2016, 02:55 PM | #4502 |
Quarry Creeper Join Date: Jan 2016 Location: US
Can the gt3c flash kit be used on the gt3b radio? I've just ordered a gt3c radio and hack kit but also have a gt3b that I will flash as well if it's possible. Sent from my SM-G900V using Tapatalk |
11-23-2016, 06:33 PM | #4503 | |
| Re: GT3B Hack Question and Answer Thread Quote:
https://overkillrc.com/gt3b-4-pin-he...category_id=13 | |
11-23-2016, 11:17 PM | #4504 |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
Is there anything that can be done to improve the trigger on the 3b? I slipped over holding mine and bashed the bottom of the controller and now it doesn't auto centre perfectly and sometimes I find my car creeping forwards. Moving the trigger back a tiny bit stops it. Also I would like to do the bearing mod to the wheel. Sent from my SM-G930F using Tapatalk |
11-24-2016, 01:50 AM | #4505 |
Depends what is preventing it from centering correctly....I would suggest closely inspecting all the mechanical parts for abnormalities
11-24-2016, 01:54 AM | #4506 | |
Sent from my SM-G930F using Tapatalk | |
11-24-2016, 02:08 AM | #4507 | |
Some parts can be found....I have a good collection of parts as well. | |
11-25-2016, 03:43 PM | #4508 |
Newbie Join Date: Nov 2016 Location: McHenry
I just got my gt3b in and when I try to update the firmware it give me an error. I can connect it to the board and start the update and everything, and after about 5sec it says the program has stopped responding and automatically closes. any ideas?
11-28-2016, 01:34 AM | #4509 |
What is the error?
12-09-2016, 09:13 AM | #4510 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
I hacked my gt3c with your kit but have a question. I have several 3 ch receivers but need another input for lights. Is it possible to setup the 4th input on the receiver as a simple on off input for lights (think it's labeled battery) I am using the 3rd ch for front and rear light bars and rock lights but would like to add a winch. The only other option I see is to just simply buy the 6ch receivers even though I'm only gonna need 4 max on any of my vehicles. Sent from my iPhone using Tapatalk |
12-09-2016, 11:40 AM | #4511 | |
Another option will be adding your lights to a manual switch on your crawler. Heyok also sells remote switches that uses a keyfob. Or, I'll have these for sale in February or March Sub Atomic Multi-Toggler | |
12-09-2016, 12:48 PM | #4512 | |
Thanks. I guess I could always run the lights straight off the battery with that cheapie RC4wd inline switch and then forgo the rx all together. Sent from my iPhone using Tapatalk | |
12-14-2016, 02:49 PM | #4513 |
Quarry Creeper Join Date: Nov 2007 Location: Kansass
I bought a "stock" GT3B from a friend and am wanting to upgrade it so I can add lights, winch, dig, etc. to my SCX project. Would there be a way that I could send you my radio and have the mods done and then have you send it back? I know you sell the firm ware and such, but I don't trust myself to be able to do it right w/o messing things up. Sent from my LG-LS997 using Tapatalk |
12-20-2016, 08:24 PM | #4514 | |
12-20-2016, 08:25 PM | #4515 |
Understandable Sent from my LG-LS997 using Tapatalk |
01-02-2017, 09:54 AM | #4516 |
Rock Stacker Join Date: Mar 2016 Location: New Castle
Anyone know what could cause my crawler to loose reverse throttle channel 2? i took the rig apart while back, not sure if i messed somthing up on the radio or not. i have steering, forward but no reverse. its a hacked GT3B Castle Sidewinder 3. Thanks. |
01-02-2017, 10:09 AM | #4517 | |
Currently i have both fwd and reverse with the following settings. motor is not in the truck yet but seems like l have a little more forward than reverse. i can at least drive it today. D/R 75% Trim F99 Does that setting sound right for a crawler? | |
01-02-2017, 11:50 AM | #4518 | |
Newbie Join Date: May 2014 Location: Canada
Have you tried calibrating your esc? https://youtu.be/cwnnw2ZH06w Envoyé de mon iPad en utilisant Tapatalk | |
01-02-2017, 05:56 PM | #4519 |
Not yet.
01-03-2017, 03:42 PM | #4520 |
Pebble Pounder Join Date: Sep 2015 Location: Germany
Anyone know DASMIKRO? Dasmikro Customized 6 Channel 8 Channel Flysky GT3C Transmitter Sale - Banggood.com Does it work? |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
