04-15-2012, 09:30 PM | #41 |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
| Re: esc for winch control
you take it out if your rx is being powered already by another esc or a bec, you don't want to feed too much voltage into the rx
04-15-2012, 09:35 PM | #42 |
Rock Crawler Join Date: Jun 2011 Location: Vancouver
| Re: esc for winch control |
04-16-2012, 06:16 AM | #43 |
bukwylde, you did calibrate the winch ESC to the radio, correct? Also curious to see if you have it wired backwards....battery to the motor leads, not the ESC input. Hope you get it figured out & that it's not a dud ESC. |
04-16-2012, 06:46 AM | #44 |
| Re: esc for winch control The reason to lift one of the ESC's red wires is so that only one source of receiver power exists. If both ESCs are trying to power the receiver, it might cause a problem as one of the ESC's built in BEC might be a slightly higher voltage than the other and cause current to flow the wrong way and maybe overheat one of these built in BEC. To make sure this doesn't happen, we just remove (slide out and insulate one of the red pins) a red wire from one ESC.
04-16-2012, 08:21 AM | #45 |
Rock Stacker Join Date: May 2011 Location: tenino
i would also contact the place you bought it from and see if they happen to know which set of wires go to what....i would hate to see you swap them around and have that esc go up in smoke.....
04-16-2012, 09:36 AM | #46 | |
thanks Al by the way, one more question here is that, how can I calibrate my winch ESC? I have FXR ESC for my rig, and trying to use B1R esc for my winch, so I basically just follow the manual to calibrate my B1R, right? but do I also plug in the FXR when I calibrate the B1R?? Quote:
04-16-2012, 09:54 AM | #47 | |
| Re: esc for winch control Quote:
I do not know how it needs to be calibrated though, do you have a manual for it? | |
04-16-2012, 09:59 AM | #48 | |
04-16-2012, 10:15 AM | #49 |
04-16-2012, 11:07 AM | #50 |
04-16-2012, 04:00 PM | #51 |
| Re: esc for winch control I think you should plug away man, I know your stuff is great and it doesn't hurt that its canadian made too I only used this because I had it kicking around but my advice too is to get your controller for a much better experience. |
04-16-2012, 04:02 PM | #52 |
Quarry Creeper Join Date: Jan 2010 Location: Rocky Hill
Just got home from work and am about to head out to the garage! And Heyok I've seen your MIGHTY FINE winch controllers but I'm trying to run on 3s and I don't think yours are able correct?
04-16-2012, 04:10 PM | #53 |
| Re: esc for winch control You know the miniqlo is only good for 2s lipo if you are direct wiring it, thats why I chose to supply power to it from a cc bec out of the rx. This allows me to run the whole system on 3s, that was the reason why I never ended up buying a heyok at the time cause his controllers required the use of a battery and doesn't work well on a bec.
04-16-2012, 04:13 PM | #54 | |
I'm glad you asked. This controller: http://www.rccrawler.com/forum/vendo...ontroller.html Will work fine up to 2S But for more voltage handling, one of the controllers listed here would fix you up: Those controllers are described in this thread: Winch Controller - Relay Driven - External Power | |
04-16-2012, 04:16 PM | #55 | |
04-16-2012, 04:23 PM | #56 |
04-16-2012, 04:52 PM | #57 | |
I don't do winches, but if I did and had issues....I would swing your way. | |
04-17-2012, 01:35 AM | #58 |
04-17-2012, 06:46 AM | #59 | |
Well, it was some month that started with an "M"... just not that one. Wow! Thanks for catching that | |
04-17-2012, 06:48 AM | #60 |
| Re: esc for winch control Any of these controllers will work with 3S Winch Controller - Relay Driven - External Power |
esc for winch control - Similar Threads | ||||
Winch Control | DustyfX4 | Electronics | 9 | 12-06-2011 06:43 AM |
winch control | djmikeb | Electronics | 4 | 03-07-2011 08:25 PM |
3 racing winch control | redjeeper | General Crawlers | 4 | 01-13-2010 01:44 AM |
3R winch and control | msd44 | Scale Accessories | 4 | 05-03-2009 11:42 AM |
