Thread: Glitching question
Old 03-04-2013, 05:32 PM   #1
I joined the Band!
Default Glitching question
Ok im running a castle sw, holmes 35t, hitec 645 , and dx3e on 3s on my daughters rig and every time i turn right it goes nuts...everything is normal unless u turn right???? Anyone ever had this issue?
TNCrawler is offline   Reply With Quote
Old 03-04-2013, 05:35 PM   #2
Jerry's RC Garage
Try a different servo
jerry2575 is offline   Reply With Quote
Old 03-04-2013, 05:37 PM   #3
Default Re: Glitching question
Make sure the steering EPA is set correctly, if you bind the servo (steering is maxed out, but servo is still pushing)) you will mess with the radio and likely brown it out.
Charlie-III is offline   Reply With Quote
Old 03-04-2013, 05:50 PM   #4
I joined the Band!
Hit the nail on the the head! I thought i had it adjusted but barely dialed it back and all is good!!! Thanks. Its amazing the stuff u forget to check when you are frustrated.
Old 03-04-2013, 06:02 PM   #5
I joined the Band!
Well i thought that fixed it. It did not. Could it be the 3s on the sidewinder? I have a extra cc bec , but i didnt think i needed it with the 645...am i missing something?
Old 03-04-2013, 06:07 PM   #6
I'd put a bec on and see if anything changes, as you said I would'nt think you'd need one for that servo but hey if it works.
pajey is offline   Reply With Quote
Old 03-04-2013, 06:07 PM   #7
You need an external bec. The 3s is too much voltage to the servo.
chicklet is offline   Reply With Quote
Old 03-04-2013, 06:11 PM   #8
I joined the Band!
Ahhh i see. I will stick a 2s on it to see if that cures it. Thanks chicklet:thumbup:
Old 03-04-2013, 06:17 PM   #9
No prob, yes-you-need-external-bec. Plenty of info in the stickies covering why you need an external bec.
Old 03-04-2013, 06:20 PM   #10
I joined the Band!
Yeah i run em on all my rigs. Just didnt think i needed on on this rig. I will wire it up.
Old 03-04-2013, 06:39 PM   #11
I joined the Band!
Now question? Should i hook the bec up through the reviever or power the servo directly?
Old 03-04-2013, 06:53 PM   #12
You need to power the servo directly from the BEC.
Here is a nice article on making a bypass cable.
http://axialcrawler.com/post.cfm/bec...bypass-harness
k7zpj is offline   Reply With Quote
Old 03-04-2013, 07:11 PM   #13
I joined the Band!
Old 03-04-2013, 07:14 PM   #14
Only reason to power a servo directly from an external bec is if it's required to have a different voltage than the rx. Otherwise make it easy on yourself, pull the red wire and plug into the rx.
Meatwad is offline   Reply With Quote
Old 03-04-2013, 07:27 PM   #15
I joined the Band!
Just got it wired up for servo direct...oh well
Old 03-04-2013, 07:29 PM   #16
Still works that way too
Old 03-04-2013, 08:28 PM   #17
I joined the Band!
Well hooked up the bec and s9157 futaba and all i can say is....bingo! It turns like a boss now and is much smoother. Thanks for all the help guys!!
Glitching question - Similar Threads
hitec servo glitching and a servo horn question m1009cucv Electronics 5 08-18-2012 11:22 AM
glitching zookiguy Team Losi Comp Crawler 10 10-02-2009 07:36 PM
HS5645 glitching question gta3wheeler Electronics 1 03-19-2008 12:41 AM
HS5645 glitching question gta3wheeler Newbie General 4 03-18-2008 08:14 AM
Glitching Question... BCCrawlerZ Electronics 20 12-16-2007 04:01 PM
