Thread: Wiring two different esc ?
Old 04-29-2013, 07:13 PM   #1
Default Wiring two different esc ?
I'm thinking of getting two tekin br1 for my clod buster but i'm only going to get one now. Can I wire that with the tekin titan i have right now and have it work or do they have to be the same esc ?
builder is offline   Reply With Quote
Old 04-29-2013, 08:01 PM   #2
Default Re: Wiring two different esc ?
I have run 2 different ESC's on a single radio before.
While it will work, they will LIKELY react a bit different (same as 2 of the same ESC's with different firmware or slightly different settings). This may not be a bad thing, just to keep in mind.
What radio?
Is this to be set-up as a "dual ESC" set-up in the radio or a "Y" cable with 2 ESC's off one RX channel?
Old 04-30-2013, 06:42 AM   #3
i'm going to run it with a y-adapter for now then eventually run them separate.
Old 04-30-2013, 06:46 PM   #4
If you find one ESC seems to run the motor faster than the other ESC, use the fast ESC in the front so you have a "sorta overdrive" which will help.
Wiring two different esc ? - Similar Threads
dual esc wiring randyromero Electronics 3 07-06-2012 11:43 PM
esc wiring help boohoo Losi Micro-Rock Crawler 7 03-26-2011 10:45 PM
Dual ESC wiring ??? AdverseCity Electronics 6 05-29-2010 03:46 PM
ESC Wiring jcraw Redcat Crawlers 4 02-25-2010 05:51 PM
Help with wiring new esc 09xD Duratrax Cliff Climber 16 07-30-2009 04:21 PM
