12-01-2013, 11:49 PM | #1 |
Newbie Join Date: Dec 2013 Location: SW IN
| Axial Wraith AE-2 ESC Question
I've been running my Wraith with a couple NiMH batteries I had and it has been working great, but I'm considering switching to Lipo. I've checked all the setup docs from Axial but can't seem to find the one piece of info I'm looking for. Is th AE-2 esc able to be switched back and forth from NiMH to Lipo without reprogramming or is there some type of setup change I need to do? I have a Dynamite esc in another rig that has to be switched before changing battery chemistry but I didn't know if the Axial was the same way. Thanks in advance!
12-02-2013, 04:02 AM | #2 |
Newbie Join Date: Nov 2013 Location: Australia
| Re: Axial Wraith AE-2 ESC Question
I used mine today with both NimH and LiPo batteries and its fine! You have may have to reprogram the LVC, but if you have an external alarm you don't have to worry about that.
12-03-2013, 10:47 AM | #3 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Man you need a Castle link, just go in on the computer and program it to handle 2s voltage or 7.4v, but keep in mind that voltage cut off should be around 6.4 for the entire pack or 3.2 volts per pack. It is very unwise to run a nimh and then running a lipo pack with out reseting the esc. Just do what everyone else does and reset it every time, if you want it to be simple get a esc extension to get to it faster. I run a 3s lipo in mine with a RS tekin and a 10.5t redline motor, so I know what I am talking about, get a castle link and turn the voltage cut off to 3.2 per unless you want to screw up a esc, its you choice, - axial 4x4 crawler
12-03-2013, 11:11 PM | #4 |
Newbie Join Date: Oct 2013 Location: Jackson
I'm think the esc is made by castle and yes it dose work with castle link. But stock settings of that esc are set to auto lipo. With all of castle stuff I have used like the sidewinder the mmp are factory set that way. It can detect witch cell lipo batteries you are using and adjust to the right cut off depending on what cell you are use. For each cell the stock setting in my ae-2 was set to 3.2v cut off per cell. So if you had a 2s batterie the cut off is 6.4v. The esc dose not need to be change from auto lipo to run nimh like you dynamite. I also have a dynamite and know what you are thinking about. The cut off will not come on for a nimh batterie. Castle link is a great tool to have but if you got your esc brand new and know that no one has played with the setting running a lipo is ok. I don't remember if the ae-2 could do 3s but I ran 2s and nimh just fine.
12-04-2013, 01:06 AM | #5 |
I wanna be Dave Join Date: Sep 2006 Location: Anchorage, Alaska
| Re: Axial Wraith AE-2 ESC Question he's right... the CC link is needed to make changes to the ae-2 I run my drag brake set to max... and reverse is instant on. there are other things can be adjusted... but don't remember what they are. again... you would need the CC link to make adjustments to the ae-2 esc. |
12-04-2013, 03:23 AM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Axial Wraith AE-2 ESC Question |
12-04-2013, 05:41 AM | #7 | |
RCC Addict Join Date: Sep 2011 Location: Beavercreek, Oregon, USA
| Re: Axial Wraith AE-2 ESC Question Quote:
http://docs.axialracing.com/instruct...e_AE-2_ESC.pdf | |
12-04-2013, 08:03 AM | #8 | ||
Quarry Creeper Join Date: Feb 2005 Location: Indy-Westside
I'd also suggest picking up a castle link! Very handy tool to have!! | ||
12-04-2013, 08:38 PM | #9 |
Quarry Creeper Join Date: Sep 2012 Location: Seattle, wa
If you go to 3s batteries you need to run a bec. If not everything will see pack voltage which is way more than it should be with out using a bec.
12-04-2013, 09:15 PM | #10 | |
The issue is that at 3S input power, the internal ESC BEC is overworked and will create heat issues with any real load on it. Thus the recommendation to run an external BEC, especially with heavy loads like high torque servos. On 2S input power, the load on the internal BEC is not as great, thus less of an issue. | |
Axial Wraith AE-2 ESC Question - Similar Threads | ||||
Axial Wraith motor and ESC question | 2-shot | Newbie General | 11 | 10-06-2014 02:17 PM |
Wraith Motor/ESC Question | SPNJCARV | Electronics | 5 | 02-01-2013 01:23 PM |
Axial AE-2 ESC Question | HDMM | Electronics | 8 | 08-24-2012 03:11 PM |
Axial XR10 and Axial AE-2 esc stoopid noobie question | shelbyzz | Newbie General | 3 | 06-14-2012 06:34 AM |
Wraith ESC/lipo question | GREEDY GENIUS | Electronics | 3 | 10-17-2011 05:19 PM |
