04-29-2018, 07:28 PM | #381 |
| Re: Have tech questions? Will answer.
Go back to 30 punch control. You should always have that to prevent brownouts.
04-29-2018, 07:55 PM | #382 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Have tech questions? Will answer. Quote:
Sent from my Nexus 5 using Tapatalk | |
04-29-2018, 08:46 PM | #383 |
Rock Crawler Join Date: Nov 2014 Location: Dells
| Re: Have tech questions? Will answer. Most are dishonest about the rating. It's more of a general 'quality' rating now.
04-29-2018, 10:50 PM | #384 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
That servo wiring setup sounds like something that could cause trouble. How exactly is it wired? Where does it get it's power?
04-30-2018, 04:02 PM | #385 |
All of the BL servos I've seen use multiple sets of wires going to the motor vs the normal 3 that I've seen... Is there a way to have a BL ESC control the motor of a BL servo? I haven't attempted anything yet, didn't want to spend $$$ on a servo if there's no chance of it working. |
04-30-2018, 04:39 PM | #386 |
RCC Addict Join Date: Jun 2017 Location: Canada
What? Most brushless servos use the 3 wire plug or 2 sets of wires to Split signal and power. Sent from my Nexus 6 using Tapatalk |
04-30-2018, 05:40 PM | #387 | |
As for his question, I don't see why not as long as you don't over volt it. Sent from my Nexus 5 using Tapatalk | |
04-30-2018, 07:14 PM | #388 | |
Mainly waiting for Mr. Holmes to step in since I can't PM him | |
04-30-2018, 07:19 PM | #389 | |
Also, the pic you posted looks more like a brushed motor to me. Sent from my Nexus 5 using Tapatalk | |
04-30-2018, 07:31 PM | #390 |
| Re: Have tech questions? Will answer. |
04-30-2018, 07:35 PM | #391 |
I answered my own question, I had an old JR brushles tail servo that made it obvious what each of the 8 wires were for...
05-03-2018, 09:54 PM | #392 |
Newbie Join Date: Jan 2017 Location: SC Mtns
Hey John! Is the Castle b-link going to interface with the trailmaster ble pro? Thanks! |
05-04-2018, 06:54 AM | #393 |
Don’t know yet. The lack of interaction with engineering tells me it isn’t likely. We have one on the way for testing.
05-08-2018, 01:11 PM | #394 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
You should look through every firmware version and ensure that every setting is showing up and programming correctly. I don't think we have any custom setting types in Castle Link for your products so everything should be working since they are very similar to the Max Pro or Sidewinder. | |
05-08-2018, 01:26 PM | #395 |
Can you confirm if the AUX wire function to control drag break is a Castle Patent? It seems to be missing from both competitors and 3rd parties like Holmes. Sent from my Nexus 6 using Tapatalk |
05-08-2018, 01:47 PM | #396 | |
No patent on file, Blink patented though... https://patents.justia.com/assignee/...-creations-inc | |
05-08-2018, 01:59 PM | #397 | |
Sanwa came out with an ESC several years ago (and might still make it) that you could adjust nearly every parameter from the radio, the only catch was it required a Sanwa radio. Graupner also had ESCs with similar capabilities from the radio. | |
05-08-2018, 02:19 PM | #398 | |
We've had it on our aircraft controllers for several years now and no one has really copied it. Hobbywing did something similar but it only is used to output the motor RPM to an external governor. | |
05-08-2018, 02:24 PM | #399 |
One last question since you are online, can we expect a new revision of the Mamba X soonish? Just trying to figure out how much longer i can avoid brushless Sent from my Nexus 6 using Tapatalk |
05-08-2018, 02:31 PM | #400 | |
I would like to see something between the mini an the MMx. The big, heavy case, etc is un needed in most applications. | |
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
