05-10-2011, 07:47 AM | #141 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
05-10-2011, 07:53 AM | #142 | |
05-10-2011, 02:35 PM | #143 |
05-10-2011, 02:38 PM | #144 | |
I've done the same thing before, so at least your not alone. You will only do it once though.....haha. | |
05-10-2011, 04:24 PM | #145 |
I wanna be Dave Join Date: Oct 2007 Location: 801
How much of an angle did you have on it before it broke????
05-10-2011, 04:42 PM | #146 |
That chassis is sick!!! Unfortunately for me, it looks a lot like the prototype i drew up about a month ago Can't wait to see it as a roller! That cab design looks incredible all bolted up! I'm subscribed!!! |
05-10-2011, 08:42 PM | #147 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I was bending a ti link with a $12 hand bender from home depot. I also popped the threaded section off, and I am glad I still have sight in both eyes.
05-10-2011, 08:45 PM | #148 |
05-11-2011, 04:38 AM | #149 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
How did the bending turn out Will?
05-11-2011, 04:51 AM | #150 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
| I use a cheap hand bender, too, but I also use a screw driver with exchangeable bits. I pull the bit out, then insert the end of the link into the hole in the shaft of the screwdriver. This way, there's less stress on the end of the link, and if it were to break, it's not flying anywhere. It also allowed me to get my bends a little closer to the end of the link.
05-11-2011, 09:09 AM | #151 |
Putting it in a vise and using the closed end of a combination wrench works too.
05-11-2011, 09:25 AM | #152 |
05-11-2011, 09:38 AM | #153 |
05-11-2011, 10:06 AM | #154 |
The chassis works best with longer rear links per the designer. However all the aftermarket 4 link mounts move close to the chassis, shortening the links, which is something we've found doesn't work properly. So we went ahead and cut our first proto rear 4 link mounts yesterday. |
05-11-2011, 10:56 AM | #155 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Holy crap! Once you clock the case the work point will be way behind the axle cl and the vertical separation will be much less than stock too. Also going to need some really bent uppers to clear everything. I like the idea but think the offsets are a bit much.
05-11-2011, 11:03 AM | #156 |
Hence why its adjustable and not fixed. Have you not seen some of these bent links people are making lol.
05-11-2011, 11:15 AM | #157 |
If you slide it all the way back then clock the case there wont be much of any link separation left. Which is not necessarily a bad thing by itself, it just doesn't pair well with most of the MOA chassis on the market. Are there some blind holes that allow it to move forward? |
05-11-2011, 11:18 AM | #158 |
Quarry Creeper Join Date: May 2009 Location: brentwood
05-11-2011, 11:29 AM | #159 | |
If you look at an XR10 the links are near centered with the axle and it has worked well, some like it one way, some like it another. Now they have options. Sometimes you don't know till you try it. | |
05-11-2011, 12:03 PM | #160 |
