Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Dlux Berg Build
Old 04-29-2015, 09:39 AM   #1501
Default Re: Dlux Berg Build
Can't argur too much with results the narrow sedona and soft rover foam seemed to work well
Curcal is offline   Reply With Quote
Old 04-29-2015, 11:02 AM   #1502
Originally Posted by Erik D_lux View Post
Been running Rovers for almost a year now. After discovering the blue compound, I have a hard time going back to a Sedona.
what kinda foam do you run with??
C-I?? dobble deuce??
FLOKI-81 is offline   Reply With Quote
Old 04-29-2015, 11:42 AM   #1503
2013 2.2P Nat. Champion
SkaldidDog's Avatar
I've had a set of blue rovers for years and never installed them. Glad someone is giving them some love.
J
SkaldidDog is offline   Reply With Quote
Old 04-29-2015, 11:50 AM   #1504
are not the blue rovers the firm`est off all rovers??
I have never tried anything but the white rover,,
and I love the white rover,,but it can be to wide in some situations,, then skinny rovers are perfect
Old 04-29-2015, 11:55 AM   #1505
5th D Owner/Driver
cboggs's Avatar
When I ran Rovers I used to run the blues on the rear, never tried them on the front. Them narrowed Sedonas sure worked good for you over the weekend!
cboggs is offline   Reply With Quote
Old 04-29-2015, 01:12 PM   #1506
Blue rovers in the hot part of the summer on rough rocks are the tits. Still have a set because I couldn't part with them.
Harvo is offline   Reply With Quote
Old 04-30-2015, 07:10 AM   #1507
Wanna get? Gotta want.
Erik D_lux's Avatar
Originally Posted by stubs179 View Post
I've never ran a blue Rover. What do you like about them over a White? I couldn't imagine why you would need to narrow a rover, they are so skinny already, especially once you shave the sidewalls. I have never heard anything good about the Blue's, just that new people bought them by accident not knowing there was a difference.
Its just all about the compound. I think the whites are pushing it, almost too soft but again, that makes them better than the blue in colder weather. Everybodies cars really fall apart in one situation and that is when it gets warm. I know just about every known line I have is not do able when the temps get above 95* but you can crawl them at 60*. Blues help with this.
I think even for 60* degrees the blues are better. I feel the lugs dont want to fold but have more structure to them.
I run Rover foam with Rovers, silly.
Yes, blue is the most firm. This is one of the factors I had when making a narrow set. The 1.9 rovers have a great tread pattern but the red are softer than the white. I didnt go with the 1.9 for this reason. The 1.9 tread could be great in cold weather though....
Erik D_lux is offline   Reply With Quote
Old 08-04-2015, 10:21 AM   #1508
Erik D_lux's Avatar
Man, just mind blowing how busy I have been the last couple of months. Seems like things are finally coming into control, even if it is months late.
Now that I am not completely overwhelmed with work, I am finally getting more time to play and tune again.
Piggy backing off of Skaldiddogs mod Skaldiddog's "Progress" of changing out the Big Bore shocks O rings to Kyosho O rings, I decided to also try the shock shafts.
I never did feel a huge difference from switching out the O rings and I dont feel much by going to the shafts also. So that begs the question, "What makes a Kyosho shock so smooth?"
Is it the piston/valving?
BB 3.75" shaft on the left, Kyosho 50mm shaft on the right.
Old 08-17-2015, 08:17 AM   #1509
Erik D_lux's Avatar
I got a chance to go out and run all of my cars this last weekend. Weather was perfect and traction was good (which can be give or take at this location). I have not been out to this spot in over a year but its the closest thing I have to red rock so its where I will practice till Worlds.
3 weekends left till Worlds! I hope you guys are getting your practice on!
https://youtu.be/pEB1UsOHZxw
Old 08-17-2015, 08:47 AM   #1510
sweet climb, cliffhanging
I love that rock type you crawl on right there..
Old 08-17-2015, 09:21 AM   #1511
Erik D_lux's Avatar
Its some of the weirdest rock I have driven on and out all all the places I have ever driven, its unique. Traction varies at this place more than any other spot I have ever seen. You can go out in the morning when its 80* or so and kill every line and then as soon as noon or 1 o'clock hits and its 90* or so and you cant make anything. For that reason, this spot can be very frustrating and impossible to tune your car with. This is the reason I stopped going out here long ago.
Old 08-17-2015, 12:54 PM   #1512
The twin stick at work. Holy shit was that nice driving.
durrty is offline   Reply With Quote
Old 08-17-2015, 03:50 PM   #1513
you dont need a twin stick for that,,,
I have made climbes almost the same as that with my 4pl
Old 08-17-2015, 10:03 PM   #1514
Where did I say you need a twin stick?
Lets see your video of the "almost the same" climb with a 4pl.
Its not going to be that smooth and dialed in, not a chance.
Old 08-24-2015, 06:49 AM   #1515
Erik D_lux's Avatar
Anybody else out driving?
Here are some small simple vids that may get you threw your Monday.
https://youtu.be/BupO3KTIq7c
Old 08-24-2015, 07:02 AM   #1516
Erik D_lux's Avatar
https://youtu.be/U9JhwyhclmI
Old 08-24-2015, 07:34 AM   #1517
Sick lines as always. Car is just sticking to the rocks.
Bbbeeep bbeeep bbeeep bbeep...... awe outta time prawgress through 9.
Old 08-24-2015, 07:53 AM   #1518
Erik D_lux's Avatar
Its a fun place to drive. Lots of transitions and grip is really good.
Getting pretty pumped for Worlds....
Old 08-24-2015, 08:56 AM   #1519
Yeah thise transitions were pretty gnarly. I especially liked the ine where you floated front tire and then dropped your whole car in the hole..... so sick.
Old 08-24-2015, 09:12 AM   #1520
I don't know the car is not working you need to change it all up
donzx12 is offline   Reply With Quote
