05-14-2013, 06:59 PM | #61 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
Package arrived now I can dial these voodoo's more to my liking... |
05-19-2013, 10:26 PM | #62 |
Got some RC4WD gears for testing, it's great to have more gear options on the market for bergs, but I'm really keen to get some RCBros ones. |
05-20-2013, 05:23 AM | #63 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: Bergsta
Nice cones |
05-20-2013, 05:58 AM | #64 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
| Re: Bergsta
I agree! Loving these gears but my front locker seams a bit sloppy. Just ordered an RC bros locker to finish the gear swap
05-20-2013, 07:18 AM | #65 |
| Re: Bergsta
Yep RCBros locker is the only way to go |
05-20-2013, 01:24 PM | #66 |
Newbie Join Date: Oct 2010 Location: SALEM
| Re: Bergsta
nice berg |
06-30-2013, 04:41 AM | #67 |
| Re: Bergsta
Something else in the design/testing stages is lightweight hubs Losi ones Losi & Axial hubs... axial left Some other parts ive made is CNC CF gearbox plates from 1mm CF |
06-30-2013, 04:42 AM | #68 |
| Re: Bergsta
My delrin hubs are holding in sweet, they are the best hubs ive ever had on a crawler! Since running them I have NOT had to re-tighten my wheel nuts each run! In the lead upto the Aus Nats I was trying some voodoo's as you know but I just cant like them enough, the thing I don't like is the lack of side wall support as seen in these pics... I haven't given up on them but I wasn't happy enough to run them at the nats.. Traction is awesome though... |
06-30-2013, 04:45 AM | #69 |
| Re: Bergsta
Rear axle.. less motor And the front axle.. Ti tubes (10mm) and lexan/pollycarb mounting + a polly servo mount for something different... After testing im not 100% happy with the polly mounts for the tube and im tossing up weather to go alloy or scrap it and go for one piece billet alloy tubes with a 10mm OD |
06-30-2013, 04:48 AM | #70 |
| Re: Bergsta |
06-30-2013, 05:41 AM | #71 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
| Re: Bergsta
Hey mate one thing I noticed is that you changed the design of the part that connects the tube to the gearbox. Dunno what to/its called(mayby flange). Also the front one is made out of polycarbonate or something? Are they just glued on? Looking good.
06-30-2013, 05:57 AM | #72 |
| Re: Bergsta They are pollycarb/lexan.. they screw to the berg gearbox as normal, the Ti tube is theaded and screws into the polly (just noticed these are old pics before I threaded them, i'll follow up some current ones) which has a thread cut into it too, then ones its all set on place I drilled a hole down through the polly into the tube to lock the tube in.
06-30-2013, 09:23 PM | #73 |
| Re: Bergsta
Servo mount looks sweeeeeeet!
07-14-2013, 09:21 AM | #74 |
New Ti tubes after the last set didn't hold up to well.. This time it's got alloy mount and the Ti tube threads into the mount, then a hole was drilled down the side and a grub screw inserted to make sure it goes nowhere |
07-18-2013, 09:13 PM | #75 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: Bergsta
Have you cut the guts out of your VP wheels yet mate?
07-18-2013, 09:53 PM | #76 |
A little.. Not as much as guys are doing, just enough to give good venting and line up holes with the closed cell foams that I found were spinning in the voodoos
07-19-2013, 08:48 AM | #77 |
| Re: Bergsta
You could drop some weight by shaving the cases and lightening the upper link mounts too. Not to mention shaving the cases will provide some smoother transitions.
07-19-2013, 10:09 PM | #78 | |
| Re: Bergsta Quote:
Also ive got another project ive been working on for a while that will make all this redundant Once TCB has worked his magic wiring on the cnc upgrades the Bergsta will be put into retirement | |
07-20-2013, 01:16 AM | #79 |
| Re: Bergsta
Done a bit of prep for this comp.. Yep shocked me too but ive had spare time Got the 300's greased, done them the same way I grease wheel bearing for cars, then I just wiped the excess off... Then I set out to find the glitching issue.. It was in the esc plugs, the salt spray got into them at the cANZ Nats.. so I removed them, also removed the nomadio's RX excess pins to clean it up and soldered the esc's directly to the board, hope this fixes it all now lol |
07-20-2013, 02:31 AM | #80 |
| Re: Bergsta
Hmmm salt spray, I'll have to watch that one. The car looks like its working well.
Bergsta - Similar Threads | ||||
Hulksta's 2012 rig "Bergsta" | Hulksta | EnRoute Berg | 108 | 02-19-2012 06:08 PM |
