01-14-2014, 05:37 PM | #21 |
Quarry Creeper Join Date: Dec 2013 Location: French Riviera
| Re: A new BERG Tracer V3
hi wondering about the chassis thickness, 2mm or 3mm ? |
01-29-2014, 01:53 AM | #22 |
Pebble Pounder Join Date: Jun 2011 Location: Le Mas Petit 81 France
Hi ! Not at all This is 5/32" aluminium sheet. I milled axle fixations at 1/8" to keep original width. The next step is to reduce aluminium chassis weight |
03-20-2014, 03:29 PM | #23 |
Hi! More news It's done, I have installed 4 voodoos with double deuce CI foam, soft at front and medium at rear Another change: shocks The berg are too heavy, so I put 3racing I recycle old springs, shorter and more flexible. I find them very progressive now And I turned delrin hubs to reduce axle and wheels (i don't know the right word, sorry ) width by turning the wheels I am really surprise by the delrin toughness The battery pack moves on front axle, with homemade( as you can see) aluminium protection So I can remove weights on front wheels and earn 180g to be at 60/40 repartition The next step is to be on podium at next (friendly) competition |
03-20-2014, 07:29 PM | #24 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Really nice build! Been waiting for someone to really dive into the V3! What's your skid height, that's some serious clearance! |
03-21-2014, 03:27 AM | #25 |
| Re: A new BERG Tracer V3 |
05-16-2014, 03:14 AM | #26 |
Hi Some news, because a crawler is never finished I made new axle: with new supports Waouh! I changed upper link support by 2 aluminium parts After a run where I loose spring support, I turn 2 aluminium parts I will never lose them I'm working on new universal joint The right wheel with new universal joint and left wheel with original part And I can't get more, because tire touches gear box I'm really satisfied because I find this is really "the" problem of berg V3. This is a prototype and I need to optimize it, but it's a good thing I began to turn pinions to earn weight, but it's not finished. I can do better New front wheels too, made in aluminium, with delrin hubs (8mm): After a crawler meeting at "La couronne" in south of France (a wonderful rocks beach, with a phenomenal grip), the PACA (www.rccrawler-france.com: Forum Dedié aux Crawler et Scales Radio-Commandé en France, Conseils, Astuces pour Créations Chassis Complet, News, Galeries Photos, Liens Utiles • Afficher le sujet - P.A.C.A!!!!!!!!!!!!!!!!!) with many sponsors ( a big big thank to them) I decided to shave a part of front tires to get better stearing. Next step is unpackage fxr, Rx and minimize wires weight, without forget universal joints and pinions |
05-23-2014, 01:43 AM | #27 |
Hi Thank you So the next step is to finish to turn gear box pinions. I leaved 1mm of metal against 3.5mm before. I could earn more but I don't want order new pinions set during a run And I milled rear wheels (1.5g earned by wheel ) but I find they have better look I need to lighten more the rear axle if I want stay under 2kg. I still work |
05-23-2014, 03:40 AM | #29 |
Many people will be happy It's a good deal, because you don't loose CrV protection. Do you know how many the set weights ? But, I prefer homemade, when I can |
05-23-2014, 04:04 AM | #30 |
DravTech Join Date: Aug 2012 Location: Sweden
Yeah, I made short comparison when I first found them.
06-30-2014, 10:38 PM | #31 |
Pebble Pounder Join Date: Sep 2008 Location: n.e.pa
just found this thread and am even more inspired to finish my v3. some very nice fab work you have done. |
07-02-2014, 05:23 AM | #32 |
Hi Some news, after a long time So first, I changed berg rods end by some traxxas and the difference is really big I modified front hubs. They are 8mm more and now I have 290 mm of axle width I made the last version of my CVD ( miss the second, but it's many work ) And i turn the rear wheels to have 275 mm axle width I modified steering to turn more, without move servo I put a brass ring between screw and plate |
07-09-2014, 07:51 AM | #33 |
07-16-2014, 03:20 AM | #34 |
Hi ! So, I'm gone to try it. It's just a part of happiness Enjoy test cardans homemade 55° - YouTube |
07-22-2014, 09:23 AM | #35 |
Hi Last finishes before the "BIG", our crawler and scale meeting . First, I glued every screw of my berg (I don't know why, but berg screws loosens) After, I milled and polished the front axle where is striped( where is striped, where is touching) And I changed bottom big screws by some flat (I haven't picture, but I took savox servo screws ) I hope that will be good |
07-29-2014, 02:38 AM | #36 |
08-03-2014, 01:14 AM | #37 |
08-07-2014, 03:24 AM | #38 |
Hi New internal rings P13 (dedicated to his inventor) ultra light version to exchange the beadlock inernal ring. 25mm width for the rear I made some rings for voodoo, but too for HB, really more efficiently on wet terrain. (each year, we have one raining day for the BIG ) 17mm width for the front and the wheel complete, with hub and steel screws It's really easy to turn. It's just disgusting And It's done. The Berg goes under 2 kg A friend has a CNC milling and cut my chassis replacement in carbon(2.2mm) and 15g earned Now, I had to be at the machine level, that will be hard |
08-16-2014, 02:00 AM | #39 |
Thank you.
08-16-2014, 02:12 AM | #40 |
Thank you. |
A new BERG Tracer V3 - Similar Threads | ||||
My new Berg Tracer 2.2 | Grump | EnRoute Berg | 28 | 11-06-2013 06:29 AM |
new berg tracer v3 | jaxandjokers | EnRoute Berg | 11 | 02-27-2013 12:23 AM |
Berg 2.2 vs tracer ? | NullMind | EnRoute Berg | 5 | 05-05-2011 02:13 AM |
Berg Tracer 2.2 | gon4lo | EnRoute Berg | 9 | 12-10-2009 08:18 PM |
