01-21-2017, 12:35 PM | #201 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: 5Th Dimension Mark ll Chassis Swap.
Haven't finished gluing tires yet, ran out of glue waiting for some Loctite 406 glue.. So no I haven't ran the tires yet. I'll either run these tires on my spare berg or my sporty. I'm leaning towards the sporty. Hopefully I'll run tires @ BLC's next comp Feb 18th horsemans park. Mean while I was looking at all the cool looking proline BFG tire tread. So I grabbed some krazy glue and my phone case. Last edited by tapped-out; 01-21-2017 at 12:37 PM. |
01-21-2017, 12:53 PM | #202 |
| Re: 5Th Dimension Mark ll Chassis Swap to Dominator.
Love that !!! Hang up and Drive |
02-05-2017, 01:05 AM | #203 |
Update on my attempt at building tires. I received my loctite 406 glue and glued all tire parts together. then used my belt sander to sand ribbing off from inside and thin sidewalls a bit. Not perfect by any means. anyways a few pictures below. Sidewalls could be better but I'm afraid of sanding a hole thourgh the tire. Last edited by tapped-out; 04-02-2017 at 07:21 PM. |
02-05-2017, 12:01 PM | #204 |
Rock Stacker Join Date: Jun 2016 Location: Southern California
Wow those look amazing! Sent from my iPad using Tapatalk |
02-05-2017, 07:27 PM | #205 |
Thank you LeePin. Here's a mounted picture of my set of finished tires.. the other set is for mjyjxj. BTW here's my deal of the yr. Picked up this hitec a.c. plus charger x4 charger for $50.00 Last edited by tapped-out; 04-02-2017 at 07:22 PM. |
02-05-2017, 10:01 PM | #206 |
A big shout out to Paul at Pro-Line and mjyjxj (Don) for hooking me up with 8 BFG KR2 in a M4 compound and 8 truggy suppressor tires in a special compound of the G8. Thank you for the project, I'll get some action footage of tires on course. It's definitely a learning curve building your own tires. Last edited by tapped-out; 04-02-2017 at 07:24 PM. |
02-06-2017, 02:34 PM | #207 |
Rock Crawler Join Date: May 2007 Location: Corona, CA
your phone cover idea is awesome |
02-07-2017, 12:11 PM | #208 |
I had a chance to test these proline hybrid tires out yesterday. They were hooking up really good.. Foam set-up was the norm. CI close cell comp cut inner and soft outter foams in front. Rear CI close cell standard inner and medium outter foams. Because this rig is 4p 11oz the soft outter foams felt to soft. So I swapped rear outter medium foams to front. And front outter soft foams to rear. I'll see if this works my guess is I'll end up medium outter foams front and rear... Pictures from yesterday Look at that tire wrap (above) this is with soft outter foams. A little to much wrap hopefully medium outter foams will help. Above was a big hole picture makes it look smaller.. tires had plenty of traction |
02-07-2017, 12:54 PM | #209 |
Nah those arent gonna work, send them over here and Ill get rid of them for ya Do you think the inner ribbs you sanded off could have helped with the truck being heavier? Just a thought. |
02-07-2017, 01:24 PM | #210 |
It's possible, but it seemed wrong to leave the ribbing there.
02-07-2017, 01:58 PM | #211 |
| Re: 5Th Dimension Mark ll Chassis Swap. |
02-07-2017, 07:28 PM | #212 |
Question about Holmes Hobbies puller motors. If I was going to buy a set of 16t puller motors for my Berg 400 or 500's? I'll probably just get crawl masters pro 16t motors. what's the difference between regular puller motor and puller Team motor? Thanks guys. |
02-08-2017, 07:30 AM | #213 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Re: 5Th Dimension Mark ll Chassis Swap. The team motors have thicker wire for more power. I'm looking at the 400's myself. The 400 I think are 2 ounces less weight then the 500. So a 4 oz ounce drop!
02-08-2017, 08:24 AM | #214 |
Thanks Matt.
02-24-2017, 02:37 PM | #215 |
Hey Matt what motors did you decide on getting?
02-24-2017, 03:03 PM | #216 |
I bought the Crawl Master 16t motors. New Version of the motors I was already running. I just had a had time dropping 260.00 on motors right now.. |
05-22-2017, 10:44 AM | #217 |
06-24-2017, 10:49 PM | #218 |
06-25-2017, 04:58 PM | #219 |
I have a question for guys who have built Dlux super lite berg axles. I'm grinding/shorting the Tangs on my FBA universals. How long are your FBA universals Tangs after you grinded them to fit your super lite berg axles. I'm at 6mm on ea FBA tang and don't want to remove to much thanks for any info. Area with red line is where my 6mm is at. Last edited by tapped-out; 06-25-2017 at 05:53 PM. |
06-25-2017, 06:36 PM | #220 |
5Th Dimension Mark ll Chassis Swap. - Similar Threads | ||||
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Axial AX-10 Scorpion | 109 | 08-11-2015 03:17 PM |
5TH Dimension Minimal berg rebuild | tapped-out | EnRoute Berg | 70 | 10-01-2013 02:40 AM |
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Videos! | 0 | 08-11-2013 01:37 PM |
