Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: 5Th Dimension Mark ll Chassis Swap.
Old 09-28-2017, 09:38 PM   #281
Default Re: 5Th Dimension Mark ll Chassis Swap.
Originally Posted by tapped-out View Post
5TH Dimension Minimal berg rebuild
Rig specs:
5th Dimension chassis
Berg axles
*front*drilled gears, Rcbro locker, turned down alum tubes, super 300's.
Rear drilled gears, Rcbro locker, Dlux tubes, CreeperBob ti inner axles.
ShocksSCX10 W/losi green F/R
MotorsHH red label 16T motors.
Elec.Holmes Hobbies br-minis esc x2, CC BEC, 5995 servo, 4pl radio.
wheels
VP DH & V4
Did it work for you?
tech54K is offline   Reply With Quote
Old 06-30-2018, 05:44 PM   #282
Default Re: 5Th Dimension Mark ll Chassis Swap to Dominator.
Border line crawlers season 4 is over thought I'd share a pic of our trophies.
Thanks to 5th Dimension for the killer chassis...
Sent from my SM-J727VPP using Tapatalk
tapped-out is offline   Reply With Quote
Old 06-30-2018, 10:25 PM   #283
nicely done, congratulations. Did you change your chassis? I could have sworn it used to be carbon fiber.
Dezertdirt is offline   Reply With Quote
Old 06-30-2018, 10:30 PM   #284
Yes a newer version of 5th Dimension Dominator MOA chassis.
It's cut from G10 this way it gives us a choice of color.
Old 07-03-2018, 10:03 AM   #285
Congrats Matt! Cars working good.
d-wray is offline   Reply With Quote
Old 07-09-2018, 01:16 PM   #286
3-D printed Shock Slider for comp crawler
Made by
Handsome Bandit Garage
https://www.shapeways.com/product/5R...li=marketplace
Here's TSK's shock sliders I modified the sliders a little-bit.
slotted the shock mounting hole. Then drilled a 3 mm hole into back side of the meaty part of the slider to secure it firmly to the chassis plate.
A few pics.
Old 07-13-2018, 04:09 PM   #287
That's some nice rovers you got there!
They've seen plenty of rock, that's for sure!
xkill is offline   Reply With Quote
Old 07-13-2018, 07:06 PM   #288
Rovers work very well in our area.
Yea they've seen a lot of comp courses.
Old 12-16-2018, 11:03 AM   #289
Quick up date on my rig.
I've been wanting to pick up a set of Holmes Puller Motors for a few yrs (just didn't want to spend 250.00) I stuck with my 540 16t crawlmasters.
A few weeks ago I picked up a set of team puller motors 500's 13t xx wire (dropped about 2oz of weight).
Not wanting to scratch my 500's I cut some lean covers for them hopefully they don't get ripped off on the 1st course.
Sent from my SM-J737V using Tapatalk
Old 12-16-2018, 11:36 AM   #290
My other update was swapping most of my hardware. I've been running carbon & stainless steel screws and nuts since day one. Chosing not to listen to D-wray advising me to swap to aluminum & titanium hardware.
So I bought 2 bags of 7075 alum screws and nuts. Thought I'd share my weight loss so far With swapping almost every screw with 7075 alum I lost 35g.
I still need to buy some titanium hardware for a few spots.
To lose 35g so far cost 44$ 7075 alum
titanium hardware guess 50$ (haven't ordered yet)
Plans for titanium hardware
lower links @ axles
Upper link @ axles
3per wheel hubs
Steering screws.
Old hardware
Old 12-16-2018, 11:55 AM   #291
With updates in above post and playing with knuckle weights my RTR weight is 4lbs 6.6oz with 6oz KW ea side still not a feather weight. Looking forward seeing how it does @ our next comp.
Old 12-16-2018, 05:31 PM   #292
no talent hack
I’ve been using the protek ti hardware with good success lately. I found some other brands cut the hex too deep and the heads sheer off.
Nabil is offline   Reply With Quote
Old 12-16-2018, 05:53 PM   #293
Thanks Nabil, I'll look into protek.
Old 12-17-2018, 04:24 PM   #294
What was the deciding factor choosing 500's over 400's?
House is offline   Reply With Quote
Old 12-17-2018, 06:55 PM   #295
Just a fear of the 400's draining to many Amps from my batteries and causing esc's to brown out. Thinking because 400's are smaller they'd need more amps from my batteries under load or on my lid. My opinion isn't based on any facts just a fear of not knowing.
Plus 16t 400's weren't in stock when I ordered my 13t 500's.
The extra weight loss of the 400's would have been nice though.
Scott in our club runs 400's in his berg and seems happy with them... but he drives really slow as if he's scared of his rig.. JK Scott...
Actually because Scott was happy with his 400's. I'm not sure if I made the better choice.
If I was a high roller like D-wary I would have bought both 400's and 500's test both sets and keep the better set.
I'm looking forward to hearing how you like your 13t 400's.
Old 12-17-2018, 08:26 PM   #296
If I was a high roller like D-wray I would have bought both 400's and 500's test both sets and keep the better set.
Old 12-24-2018, 03:35 PM   #297
Hey guys, what pinion's are you guys running with your
Holmes Hobbies 500's 13t team puller motors with D-luxfab SAF standard berg gears.
I'm running 48p 14t pinion front & 48p 13t pinion rear.
Thanks.
5Th Dimension Mark ll Chassis Swap. - Similar Threads
Tapped-out's 5th Dimension Sucker Punch tapped-out Axial AX-10 Scorpion 109 08-11-2015 03:17 PM
5TH Dimension Minimal berg rebuild tapped-out EnRoute Berg 70 10-01-2013 02:40 AM
Tapped-out's 5th Dimension Sucker Punch tapped-out Videos! 0 08-11-2013 01:37 PM
