12-20-2011, 06:14 AM | #81 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: DRV KRAWLER FOFF'en Formula Offroad When I purchased the shocks, they originally came off a Revo. Those springs where to heavy to even consider. I went with the Jato springs (0.7 spring rate)as a starting point. I do prefer a softer suspension with the area I will be driving this rig. The nice thing about these particular shocks, theydo have a great selection of springs. |
12-20-2011, 07:15 AM | #82 |
Quarry Creeper Join Date: Nov 2011 Location: In the woods
Do you run a full sized battery? Like a 2c 5000mah? or more of a compact lower mah battery?
12-20-2011, 07:38 AM | #83 |
I have not purchased a specific battery for this build as of yet. I am planning on running a 3s 1500 on the inital run due to that is what I have. I have installed it to check weight distribution. seemed pretty spot on for now.
12-20-2011, 10:07 AM | #84 | |
Rock Stacker Join Date: Mar 2011 Location: SW Ohio
| Re: DRV KRAWLER FOFF'en Formula Offroad Quote:
Thx for the reply. I have the same shocks, I may start at 1.0 on the spring rate. | |
12-20-2011, 01:27 PM | #85 |
| Re: DRV KRAWLER FOFF'en Formula Offroad I thought that 0.7 was a great rating to start for my needs . I have really been trying to keep this rig as light as possible. When it is all said and done I may have switch over to the heavier spring rate. |
12-22-2011, 11:35 AM | #86 |
I had to post up a Christmas story that I received yesterday. I posted up in the want adds the need for a Axial Spur gear cover Ax80078. Shortly after posting up my need for it I received a P.M. from Drail. He is sending me one for a Christmas gift. Is that Awesome or what ? I will be posting this up in the pay it forward section also. I just had to share what a Great present to receive from another Member. I love what we have going on at this site. Thank you, Thank you, Thank you Drail ! MERRY CHRISTMAS TOO ALL ! ! ! ! |
12-23-2011, 07:40 PM | #87 |
Care to share your link lengths? Im getting ready to make some up in a few min and cant decide if i should make the rear slightly longer. Also, how much spline engagement are you getting with the Wraith shafts? I got a set made by CKRC, thay havnt arrived yet tho.
12-23-2011, 10:35 PM | #88 |
I will need to take some measurments tomorrow for the links.( Rigs are in the closet of my 3 year old and I am not wanting to wake him) I did extend the rear out also ( I believe the lowers are 106mm ). If I recall on the Wraith shafts I had 4mm left until the full extention was met. I will also check that and post them. I hope tomorrow to be given enough time to do some wiring. I received the Castle creations BEC the other day. I wish to get it wired up to the servo. That way when I finally purchase a receiver for it. I can through a Lipo at it and hear it Roar. |
12-24-2011, 07:50 AM | #89 |
All right got some lengths to post. I was correct 106mm on the lower links not including the additional length the Traxxas rod ends add. and the uppers are 96mm front and 95mm rear. These lengths are for use with the BWD Foff servo mount and rear 4-link plate. And as far as the MIP Driveshafts 3.7 mm remaining until maximum length. |
12-24-2011, 06:47 PM | #90 |
Thx for the reply. I recieved my CKRC wraith shafts and they look sweet for the money. I think im going to run the rear as long as possible and the front a touch shorter.
12-25-2011, 07:35 AM | #91 |
| Re: DRV KRAWLER FOFF'en Formula Offroad I went to the CKRC site to look at those shafts. They look like Junfac shafts from the picture. They don't show the splining on them. I am curious to see what they look like . Besure to start a build thread for all to see. |
12-27-2011, 08:08 AM | #92 |
On a positive note, I received the Axial #ax30401 (2) Heavy Duty O/D Beveled gears. It is true Axial has updated the pinion gear to take Axial Wraith drive shaft pins AXA0175. Ordered the pins from RPP hopefully will arrive soon. Also finally got the chance to place a order to Highlandcrawler for some Axial XHD no slop lockers a pair of the steel with the new standard hardware. So, I will soon be getting to beef up the axles internally. The only things I won't be upgrading inside are the drive axles. I need to leave something to break. Oh ya, I hope the Axial Spur gear cover will arrive today from Drail. It would have been here sooner but, the holiday created a delay. Thank you again Drail for the pay it forward. I am hoping to post up some kind of updated pictures just for the H#!! of it. Last edited by DRV KRAWLER; 12-27-2011 at 08:21 AM. |
12-27-2011, 11:52 AM | #93 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
I WANT PHOTOS!!!! I WANT PHOTOS!!!! I may have to get a set of the new OD gears, hope the Wraith pin won't cause issues with my stock yokes Now you got the fire under my behind to get Hobbes worked on more If you need any last minute stuff let me know but im hurting without a bandsaw to cut things... so far |
12-27-2011, 08:25 PM | #94 |
Here you go Calvin, I did not realize till I went to take photos of these. They come with the drivshaft pins. Sorry the picture quality is low. here is also a photo of the front frame brace I made up real quick yesterday. |
12-28-2011, 06:04 AM | #95 |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
[QUOTE=DRV KRAWLER;3471406]Here you go Calvin, I did not realize till I went to take photos of these. They come with the drivshaft pins. Sorry the picture quality is low. Have you fitted them yet ? Did you get them little EorC clips as well.. |
12-28-2011, 06:13 AM | #96 | |
[QUOTE=West Cork Basher;3471849] Quote:
I have installed these gears in both of my crawlers ( OD / UD ) I am unclear on the clips. | |
12-28-2011, 06:22 AM | #97 | |
[QUOTE=DRV KRAWLER;3471851] Quote:
there was a little clip that snapped onto the shaft (on the inside) What are Highlandcrawler lockers ? Thanks Sean. . | |
12-28-2011, 11:12 AM | #98 |
These gears no longer require the clip. The pinion gear is one solid piece with the hardened gears. the Highlandcrawler locker is Axial XHD no slop lockers . |
12-28-2011, 11:26 AM | #99 | |
12-28-2011, 12:12 PM | #100 |
| Re: DRV KRAWLER FOFF'en Formula Offroad |
