12-02-2017, 12:36 PM | #501 |
| Re: Coming soon .....GMADE GOM-GR1 Rock Buggy
I had similar luck on my R1. Only issues were the junfac shafts and CVAs Hang up and Drive |
12-02-2017, 02:21 PM | #502 | |
| Re: Coming soon .....GMADE GOM-GR1 Rock Buggy Quote:
Of course, what you guys eventually did would be much easier. I may have to think about that. I also have been thinking about jaybe using some lexan to cover that transmission shifting area to keep it clear of debris. Still working on it. | |
12-02-2017, 02:36 PM | #503 | |
or a rubber shift boot of some sort. There are flexible filaments for 3D printers available now too, that seems like a good route maybe. | |
12-03-2017, 08:17 AM | #504 |
Rock Stacker Join Date: Jun 2016 Location: England
I’ve had a bit of a test run. I can’t get the DIG to engage, 1st and 2nd are fine and everything is setup but it just won’t engage it just free wheels the rear.
12-03-2017, 09:50 AM | #505 |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
| Re: Coming soon .....GMADE GOM-GR1 Rock Buggy |
12-03-2017, 10:01 AM | #506 |
If your wheel bearings explode, that is what is causing that. Hang up and Drive |
12-03-2017, 10:05 AM | #507 |
12-03-2017, 10:06 AM | #508 |
12-03-2017, 10:08 AM | #509 |
12-03-2017, 10:09 AM | #510 |
12-03-2017, 11:33 AM | #511 |
12-03-2017, 01:01 PM | #512 |
RCC Addict Join Date: Jun 2012 Location: Meridian,Id
Same here I had some Fast Eddy kits from other trucks that I used to build it.
12-03-2017, 02:40 PM | #513 |
Appreciate all the replies but I’m looking for someone who had the loose wheels and then fixed it, as opposed to someone who put on fast eddy bearings from the start and never noticed a problem. Maybe some of you have done this, but it’s not clear.
12-03-2017, 03:49 PM | #514 |
I did . What IS the problem on yours ? If it’s the bearings, replace the stock crap ones with Eddies. After my 3rd failure, I bought a full set and swapped all of them out. My Gmade bearings were noticeably junk Hang up and Drive |
12-03-2017, 07:01 PM | #515 |
another easy check is the pin for the hex split in 1/2 ?
12-03-2017, 07:37 PM | #516 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Coming soon .....GMADE GOM-GR1 Rock Buggy Put some shims behind the inner bearing inside the knuckle (pushing the shaft towards the locker). It will get rid of that slop. And better bearings of course.
12-04-2017, 02:35 AM | #517 | |
Newbie Join Date: Jul 2016 Location: Scotland
Did you pay close attention to the dig shift gears orientation? | |
12-04-2017, 04:13 AM | #518 |
12-04-2017, 05:08 AM | #519 |
12-04-2017, 09:22 AM | #520 |
Tags |
gmade, gom |
Coming soon .....GMADE GOM-GR1 Rock Buggy - Similar Threads | ||||
Malin's new Gmade R1 Rock Buggy | BentKa | G-Made Crawlers | 59 | 09-28-2012 06:30 PM |
