02-22-2008, 10:40 PM | #61 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
You need the top gear and all slipper parts as shown, shim the gear equally on both sides to center the top gear to the idle gear. Assemble the tranny and the slipper. The spur gear will be in the exact same spot the stock gear was.
02-22-2008, 10:41 PM | #62 |
02-23-2008, 11:38 AM | #63 |
I am going to do some stuff to the front end. I want the front track width a little wider than the rear High clearance steering link. Aluminum knuckles. You will need Associated #3965 it is the crush sleeve that is in between the front knuckle bearings. |
02-23-2008, 11:40 AM | #64 |
Here is the knuckles I used they fit good; http://thetoyz.com/cart/thetoyz_deta...C3%20&%20NTC3# Assemble it as shown |
02-23-2008, 11:47 AM | #65 |
With the hex on the outside of the pin, the clamping hex helps keep it on the shaft not stuck in the wheel. It needs to have the little lips remove for the long pins that come with the axles. Same thing if you use the plastic hex. A 1/16" drill bit works to remove it. |
02-23-2008, 11:51 AM | #66 |
I just grab any link laying around and attach one side, measure how much longer it needs to be or shorter.
02-23-2008, 12:00 PM | #67 |
Then add what I need to the link length. Here is where a lathe is earning it's keep Cut the new link with the added length, center drill, drill, screw in the long set screw, screw on the link all on the lathe. |
02-23-2008, 12:02 PM | #68 |
To raise the link wheel collars are just about right or a 1/4" spacer. the Aluminum knuckles won't flex as much. The higher clearance will get the links closer to the servo for a better angle. |
02-23-2008, 12:59 PM | #69 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
I just might have to get a set of these bad boys. Black jack, Ti links, Losi shocks and these would be pretty darn nice combo |
02-23-2008, 02:35 PM | #70 |
For the electronics I used another battery tray, (well now it's a radio tray) and mounted it on the rear axle. This let me install the speed control and RX pretty low and fairly simple.
02-23-2008, 02:36 PM | #71 |
Use the battery Velcro strap for servo wire management.
02-23-2008, 02:38 PM | #72 |
Trying to have Fun Again Join Date: Apr 2006 Location: In your fridge stealing a beer
Amazing work Mike. I can't wait till my tuber gets here then I will be building mine.
02-23-2008, 02:56 PM | #73 |
02-23-2008, 03:05 PM | #74 |
On to some wheel stuff, I have used Erickson, MSD, Axial, RC4wd. The MSD are my favorite, they do require drilling out the center hole to 3/16" I don't know why the hole is the size it is, but I am sure it's good for everything else. On all wheels I have needed to add a spacer on the outside of the wheel under the wheel nut. If you have the wide front setup you don't need a spacer. Axial wheels fit with just the spacer under the wheel nut. Last edited by Mike Poulson; 02-23-2008 at 03:34 PM. |
02-23-2008, 03:07 PM | #75 |
RC4wd have a strange hole and need just the right spacer to fit in the hole.
02-23-2008, 03:15 PM | #76 |
I have heard that the size of my nuts has caused problems with some custom wheels.
02-23-2008, 05:54 PM | #77 |
02-24-2008, 11:43 PM | #78 |
RCC Addict Join Date: Dec 2004 Location: Behind the wheel of an Axial R/C
Holy cow Mike. If I didn't have all this SICK Poulson stuff already I'd definitely be ordering some ASAP Great info. Keep up the amazing work. |
02-25-2008, 03:47 PM | #79 |
Rock Crawler Join Date: Jul 2006 Location: Olympia
Just got mine, wow they look great.
02-26-2008, 01:32 AM | #80 |
Rock Crawler Join Date: Feb 2007 Location: weather sucks ,mn
i may have missed price so ? whats the damage to my pocket?
