02-26-2008, 12:49 PM | #81 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
It's posted on his website...http://www.mpcrawlers.com/ | |
02-26-2008, 03:47 PM | #82 |
Rock Crawler Join Date: Jul 2005 Location: Phoenixville
Mike got the new cvd bones and the slipper thx. , nice job on the build thread also.
02-26-2008, 10:15 PM | #83 |
Rock Crawler Join Date: Dec 2007 Location: Shreveport, La
also got mine monday, thanks mike, they look good |
02-28-2008, 11:54 AM | #84 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
Wow those new bones are huge compared to the old ones, don't think you will be breaking any of those. So are those still B2\B3 bones?
02-28-2008, 03:21 PM | #85 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
02-28-2008, 03:52 PM | #86 |
Newbie Join Date: Nov 2007 Location: Allentown
wow that is amazing mike. awesome job
03-06-2008, 07:35 PM | #87 |
Pebble Pounder Join Date: Dec 2004 Location: South Lyon
dibs. No, really |
03-07-2008, 08:15 AM | #88 |
03-10-2008, 09:19 PM | #89 |
Mike, the axles are beeauteeefulll!!! Can't wait to do up the finishing touched to make it complete!
03-12-2008, 07:03 AM | #90 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Quick question on these axles. How is the steering? The AX-10 steering is pretty good, so are the TLT axles with CVD's. Just curious, thinking of possibly getting these axles.
03-12-2008, 10:07 AM | #91 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
This is a great build you have done. I am goin gto be building a tuber also. So I am tossing around a axle idea.
03-12-2008, 09:45 PM | #92 |
03-13-2008, 04:35 AM | #93 |
Quarry Creeper Join Date: May 2007 Location: melbourne, australia
do you guys have any problems with the cvd shafts exposed like that
03-15-2008, 02:43 PM | #94 |
03-15-2008, 02:59 PM | #95 |
Drilling the mounting holes for the Axial trans is easy if you have a template here is one way to make a template. I made one out of lexan then used it to make a little better one using aluminum. Starting with a piece of lexan I sprayed 3M77 on the plastic only and let it dry for a temporary bond to the bottom of the trans. I drilled 1 hole installed 1 screw in it and drilled the 2nd hole and put a screw in it. Then drilled the the other 2. The screws keep the plastic from shifting around while you work on the others. |
03-15-2008, 03:02 PM | #96 |
Trim the plastic nice and square with the holes. Mark a center line where the trans case splits.
03-15-2008, 03:06 PM | #97 |
I am going to be using the template more than once or twice so I used this plastic piece to make another one using aluminum, it will last a little longer than plastic.
03-15-2008, 03:09 PM | #98 |
Set the trans where you want it and mark the spot where the trans case splits, line up the template with the mark on the chassis, temporary bond the template with 3M77.
03-15-2008, 03:14 PM | #99 |
Fits perfect, hope this helps. Mike |
03-15-2008, 04:54 PM | #100 |
Quarry Creeper Join Date: Aug 2004 Location: salt lake city
I will take a set, OH wait I already bought some, Great info mike I really like the rounded off edges. I might have to do that to mine.
