03-16-2008, 04:14 PM | #101 |
Pebble Pounder Join Date: Nov 2006 Location: scarborough CANADA
Excellent thread. almost like an online textbook. |
03-28-2008, 12:24 PM | #102 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
The more I look at these, the more I want some. Maybe in a few months I will have to break down and buy some.
03-28-2008, 10:14 PM | #103 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
03-28-2008, 10:22 PM | #104 |
Rock Crawler Join Date: Jul 2006 Location: Olympia
04-09-2008, 04:48 PM | #105 | |
Thanks Mike... This is what I was looking for. I'm Glad you made this Thread.... | |
04-13-2008, 11:53 AM | #106 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
I have had a few ask about the HH Cobalt motors, having never used one I wasn't sure what would happen in my axles. I scored a 10t in the for sale section and built a chassis to test it out in. 2 things I found out after running it in yesterdays comp. Not only did the axles hold up well, I highly recommend the 10t it had a very smooth controlled power band. I ran a 2cell LiPo with A Tekin FX-R. Very nice set up. (Thanks to Kaetwo for helping me with the drag brake setting) I also tested a 3cell without any problems, I prefer the 2 cell for comps. The chassis I made from leftover 1.0"x.125" from Lowes was pretty easy to make and worked just fine. I cut 4 pieces of 1"x5"x.125" tacked them together with 3M77 and drilled all the holes then I could bolt them together and cut them out. It's a 4 piece chassis all 4 pieces are identical. I call it the 1" chassis 4 of the new Losi shocks and 8 stock Traxxas links. Mike |
04-14-2008, 11:10 PM | #107 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
I just picked up a set of these axles and will start a build thread using a BlackJack chassis with them. I can't wait to get them on the rocks.
04-19-2008, 11:23 AM | #108 |
got a link for those gears?
04-19-2008, 01:32 PM | #109 |
Quarry Creeper Join Date: Jan 2007 Location: US
Maybe I'm missing something, but those LOOK like plastic, and there's nothing that says what they are made of. And, the same part number on Towerhobbies says it's plastic... http://www3.towerhobbies.com/cgi-bin...?&I=LXNZ99&P=7 |
04-19-2008, 02:29 PM | #110 |
04-19-2008, 08:03 PM | #111 |
Anyone running tc3 spools ? Worth the money ?? Assoicated #1703 Also I heard that someone makes aluminum or steel ring and pinion gears,Is this true and who makes them ? |
04-21-2008, 06:49 PM | #112 |
04-21-2008, 07:19 PM | #113 |
I love my axles that I got from you. I have been running them hard, I broke the smaller bones pretty fast but the new beefy ones are the ticket!! Thanks a ton for making these Mike, great work!! Now someone, please!!! Alloy gearsets please!!!!!!! |
04-21-2008, 08:06 PM | #114 |
04-21-2008, 08:24 PM | #115 |
Rock Crawler Join Date: Dec 2007 Location: Shreveport, La
ive been running a 10t cobalt on 3s on my poulsons ever since ive had them. but i do break stuff |
04-22-2008, 06:54 AM | #116 |
Putting Poulsons under a BlackJack chassis. Hopefully the perfect combo of low center of gravity and high ground clearance. Poulson axle BlackJack build thread |
04-25-2008, 07:21 PM | #117 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
Well I was gonna put ax-10 diffs in my sling shot but now I'm second guessing it... by the time you beef them up you could just throw a few more bucks in to get these! Oh and by the way killer thread!
04-25-2008, 07:35 PM | #118 |
Do the ring and pinion need to shimmed to last ?
04-26-2008, 09:42 AM | #119 |
Here are some gear shimming guide lines. Most diffs need 3 shims to properly pre load the bearings. This is the side to side play on the spool, its best if there isn't any side to side movement. With 3 shims on the side show in the picture this moves the gear towards the pinion. |
04-26-2008, 09:45 AM | #120 |
There needs to be at least 1 shim on the pinion input shaft to keep the gear from rubbing the case.
